Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Kenmore 596.77603800 Condensation on French Door Hinge
This is a new fridge about 2 weeks old. The refrigerator and freezer both seem to be working fine (constant 38 and 0 degrees), however condensation builds up on outside of the hidden door hinge that flips out when the left side door closes. I'm not sure if there is a leak in the gasket or if the doors are not closing completely. Or is this just something that's common to all french door style fridges.
  • 958 Answers
SOURCE: friction between the doors
look at the hinge on the top of the freezer door, unloosen the bolts that's holding the bracket, move the door a little bit to the left then tighten the bolts again. that should solve your problem.
Posted on Feb 18, 2008
mikedurland
  • 481 Answers
SOURCE: frost inside freezer door
there is a small electric heater along the door gasket where you see the frost building up, this heater has apparently stopped working. this will also cause the door to pop open due to a poor seal. feel around where the door gasket contacts the refrigerator and it should feel a little warm. if not then a service company can replace those heaters. should not be too expensive.
Posted on Jun 28, 2008
SOURCE: Right Door is making loud popping noise
replace the door cam assy. and door stop.
Posted on Nov 05, 2008
duby1990
  • 370 Answers
SOURCE: Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: moisture on the door hinge seal of french door model MF12569VEM.
You can use cooking oil or wd-40 to go around the rubber seal of the door especially near the hinge to make sure it has a tight closure
Posted on Dec 19, 2008
How do i reset a kenmore elite fridge after installing a new control board?
I wouldn't think that it needs resetting?? Is the fridge not working at all now? Have a close look at the old board and the new one. Some manufacturers leave little "jumper" plugs off new boards and you have to take them off the old board and transfer them to the new one. Look very closely... They are hard to see sometimes.
Dec 24, 2014 | Kenmore Elite 78722 78729 Bottom Freezer...
Our Kemore Elite French Door Fridge is not working. The Freezer is freezing but the fridge is not cooling at all.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 22, 2010 | Kenmore 77552 Bottom Freezer French Door...
Kenmore trio 596.76522500 fridge not cooling freezer works
if you need to assist the evaporator fan motor you need to replace. this should fix your problem.
Oct 13, 2009 | Kenmore Refrigerators
Kenmore refrigerator will not cool. Freezer works
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Kenmore Refrigerators
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Condensation on the strip between the 2 french doors
these fridge have a heater in that black flaper to prevent condensation. It is probably not working or not even plugged...do they removed the doors when they delivered your fridge??? remove the uper left cap of the hinge, the connection is there...... the tech must check that piece if it is well plugged..
Jul 03, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Thermador Freedom T361T70NNP - French Doors - Condensation
I have the same problem, and thermador stated there was a recall on the hinges. They are replacing the hinges to a newer stronger hinge that will pull the refrigerator doors in tighter. It took three different service companies to find the answer to this problem because I was told Thermador does not want anyone to know about this issue they have.
Jun 29, 2009 | Thermador FREEDOMĀ® COLLECTION T30IR70NSP
Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
Dec 31, 2007 | Kenmore 53642 / 53644 Side by Side...
REFRIG SIDE NOT COOLING
The sweating inside is from the door not making a proper seal, and you are getting condensation build-up. The door not shutting is not as unusual as you may think. First check the gasket condition, a new one may not be a bad idea. On these refers with the revisable doors, try removing the freezer door and then loosening the fridge door hinges and adjusting the mounts. Its a trial and error procedure so don't get frustrated. Another trick is to wad up a wash cloth into a ball and wedging it into the door gap after you open it on the hinge side, then close the door. You should have some tension, but not too much. This bends the door a little. If you can get the door to make a good seal it should solve the other problems with the temperature. If not, you are going in the right direction by locating and cleaning the vents. All the cool air in the fridge comes from the freezer.
Nov 13, 2007 | Whirlpool ED5SHAXM Side by Side...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
142 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
