Question about Rohl Plumbing
Rohl 3810 faucet nut not engaging threads
I have replaced a leaking Rohl cartridge in my kitchen faucet, but when I
replace the nut holding down the cartridge, the threads of the nut do not
engage. I have tried to push hard down on the cartridge while I turn the nut,
but to no avail.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi murphygm,
I'm Harvey the Master Plumber.
Your problem is: You have replaced a leaking Rohl cartridge in your kitchen faucet, but when you
engage. You have tried to push hard down on the cartridge while you turn the nut,
but to no avail.
Assuming you have the correct cartridge, I find it helpfull to take pictures with my cell (easily deleted later) as I disassemble to make sure I'm getting the new one in exactly right because there are only two reasons why the new cartridge won't go all the way in. 1 It's the wrong cartridge or
2 something's not right. Take the new one out and check that everything is correct, it's easy to make a small mistake. That's it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
I just did the same repair project on my Rohl R3810 using the updated cartridge kit that Rohl supplied under warranty. The new cartridge is a bit different than the old one, and one of the O rings needs to be compressed to fit. You need to press hard on the cartridge nut to get it to reseat (it took me several tries to get it to catch). The cartridge design makes it hard to crossthread the nut but you should be careful to not do that, since that would likely destroy the threads.
Posted on Feb 20, 2014
The handle on my rohl kitchen faucet won't hold its position, how do you adjust or tighten the handle?
under the counter there is a nut that needs tightened . usually need a swivel head faucet wrench to get them tight .
Feb 14, 2015 | Rohl A3608LMPN Single Lever Country...
Rohl single lever kitchen faucet sprayer is working but faucet has stopped. Cleaned out the cartridge area but water has stopped diverting back to faucet. Have used faucet for years but now having trouble...
Can you post a picture or reference the model of faucet you have, also it may be quicker to call Rohl directly as warranty may apply and they may cover cost of repair parts and send them to you at no cost. Rohl 714-557-1933
Jul 23, 2014 | Plumbing
Would it be cartridge or something else
Not the cartridge. There are O Rings around the spout that wear out. These need replacing. Call Rohl for replacement parts
www.rohlhome.com/warranty.aspx
Jul 07, 2014 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
How do I replace the hose on a rohl 3810 faucet pullout pray head faucet
contact ROHL customer Service, request a new hose (part number R45158), detach the end on the underside with a wrench and pull it out. Insert new hose through the topside guide neck and reconnect on the bottom connection.
Nov 02, 2013 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
My rohl A3608 is leaking from the lower swivel on the faucet, how does the faucet above this swivel come off for repairing the leak?
there is a 2mm set screw on the back of the neck. Contact ROHL customer service 800.777.9762 to get replacement o-ring set to repair leak.
Sep 16, 2013 | Rohl Plumbing
Sprayer leaks on my Rohl single lever faucet
The spray head will need replacing, it unscrews and the new one will fit right on
Jun 27, 2010 | Rohl A3608/11LMAPC Single Lever Country...
I'm going tobe replacing the cartridge in my Rohl
It is highly suggested to use the grease. The purpose of the grease is for (break-in Period). Without the grease, gaskets and seals rub dry and hard against the metal surfaces and could distort or wear uneven and fail prematurely. The grease helps ease the initial wear and give a better life. Also, it isrecommended toopen a faucet and clean and grease seals and gaskets before they are bad;sort of a preventive maintainance every 2 to 3 years. Good luck, Macgivor
Jan 16, 2010 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Rohl 3810 kitchen pullout faucet leaks under the sink
ouch sadly im sure it was pricy to have him out  so my suggestion would be to call him back and have him take off the price of what he charged you or have him fix it for no charge could be just need some plumbers putty around the faucet to stop a little water that may seep threw under the faucet good luck
Mar 26, 2009 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Plumbing Logo
606 people viewed this question
Top Rohl Plumbing Experts
Donni Steen
obsteiner
john h
Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
