Question about KitchenAid KBMS1454R Microwave Oven
Microwave turns off and on repeatedly
I have a KitchenAid KBMS1454RSS microwave that turns off and on repeatedly on its own (after pushing start). All door switches check ok with multimeter. I tried it with the magnetron disconnected and it acts the same. Can I assume this means that the magnetron is not the problem? Any ideas what could be wrong? This started suddenly last week, and we haven't tried to use it much since.
  • uriah37 Nov 10, 2008
    I have the exact same problem with mine. It was installed in July 2005. It will continue to heat but shuts off and on continuously until timed out. Is is a leaking magnetron? Warranty will cover parts cost for magnetron replacement until 5 years.
  • tseind Dec 11, 2008
    We have the same problem with the same KitchenAid model. Had it looked at several time, they clean it, put it back together and it may work when their there, but as soon as they leave it starts acting up. At times it can work fine for several months, but the problem always comes back.
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: GE microwave replacement magnetron
At first I was concerned but then I realized what it was.
Congrats on their sending you the mag!
How did you convince them to do that? Did they make you sign a waiver?
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 28, 2008
  • 579 Answers
SOURCE: Fuse location on a KitchenAid Microwave
To check the internal fuse. Unplug the oven, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it for continuity with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Hope ya fix it!
Posted on Jan 30, 2008
reg501
  • 413 Answers
SOURCE: F9 error
Your Microwave uses "UltraWave technology"
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
The Magnetron sells for about $78.00 and is simple to replace. Check your owners manual for limited warranty on the MAG and electronic parts.
Posted on Jun 12, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: KitchenAid Superba Microwave/Oven, Microway Door message
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 27, 2008
How to replace clock display on #KBMS1454RSS
You can find helpful exploded view diagrams here.
Dec 10, 2012 | KitchenAid Microwave Ovens
Kitchenaid microwave mondel #KBMS1454RSS seems to have a short somewhere
see the information attached and test the main component for SHORT. God bless you
Sep 24, 2012 | KitchenAid KBMS1454RSS Microwave Oven
Right side off of touch pad not working
On some models you can order separate keypad, on others you have to order the control panel frame, which has a keypad already installed.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven
here.
Let us know if we can help further.
Dec 04, 2011 | KitchenAid KBMS1454RSS Microwave Oven
How do I replace the lightbulb on the Microwave ? 1454SSS
The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
Mar 26, 2011 | KitchenAid KBMS1454RSS Microwave Oven
The power is on to my Kitchen Aid microwave convection oven, but the microwave will not heat up? Any ideas as to how I can fix this?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 03, 2011 | KitchenAid KBMS1454RSS Microwave Oven
The door is very heavy. The "spring" has
Sorry to read about your problem, I hope this helps you out.
it is not easy to work on door spring issues, I suggest you contact a service company.
it should be well under a 1 hour service call.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | KitchenAid KBMS1454RSS Microwave Oven
How do I channge the bulb?
Its a built in microwave and the bulb is inaccessible according to manufacturer which really means If it is past warranty you need to remove the unit. This is the document for proper installation: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208205303.pdf
So just follow the steps in reverse, then you will have to take the top of the unit apart here is a link to an exploded view of you'r microwave along with the parts list http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208205649.pdf
I guess they think the bulb will last a long time you probably got a dud;)
Jul 03, 2010 | KitchenAid KBMS1454RSS Microwave Oven
The door handle on my microwave broke off at bottom of the door. The screws holding the handle on are not visible from the back of the door. How do I access the screws to replace the handle. GE Profile...
The back of the door will have a moulded surround that will be fixed with allen heads or small screws. Remove the inside cover of the door and you will see the holes for the handle.
I have a kitchenaid model kbms1454rss-o and the pin that makes the turntable turn is gone. i need a new one where can i buy one without having a repair man come out
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 07, 2009 | Kenmore 64002 Microwave Oven
KitchenAid KBMS1454R Microwave Oven Logo
55 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
