Question about Cameras
I have a Canon Powershot SD300. It got in contact with water by accident and now I can't turn it on. The memory card is still working. So now I don't know if it's the battery, the camera or both that is busted. I need help!
    Master:
  • 383 Answers
Remove the battery immediately before you short the mother board ......
Posted on Oct 15, 2008
When the camera is switched on the message card locked appears and it is not possible to take pictures
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 21, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
Transfering pictures from computer to Canon PowerShot SD300
If there is a SD card for your camera, you can do that easily by a card reader
Jan 04, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
The camera will not allow me to take pictures. It says=card is locked but I have tried three different memory cards and no luck
Make sure that you are using 2GB or less memory cards for your older camera. 4GB or higher SDHC will not work with an SD300. There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 25, 2010 | Canon PowerShot SD300 / IXUS 40 Digital...
Can you use an SDHC card in the canon powershot sd300 digital elph?
Although it looks exactly the same as a standard SD card, the format the SDHC card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Will sdhc memory card work in canon powershot sd300
SDHC will not work in cannon powershot sd300.. you can try using sd cards..
Nov 22, 2009 | Cameras
Ixus 40 maximum SDHC card
Your camera is not compatible with SDHC type cards. No 4gb cards for you. It looks like 2gb (non SDHC) cards are the biggest you can use.
Feb 25, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Maximum memory size of sd-card for canon ixus 40 ????
Check to see if your 16GB card is an SDHC card. If it is, your camera is not compatible with SDHC. (The SDHC protocol was developed after the SD300 came out in 2004).
Feb 23, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon Power Shot SD300 Broken Screen
pretty easy to replace the screen, i suggest buy SD300 from ebay that has lens problem, but it is known for sure that screen is working, you might find one for $20-30, also look for SD200 you might find it cheaper and it uses the same screen as your SD300
Aug 19, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Memory Card is locked up?
Hi Phatback, There should be a switch on the card, move it in the opposite direction. If this does not work, format it in your PC. Please let me know if this works. Best regards, nightdiver
May 30, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Cameras Logo
49 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
