Question about Gem Sound CDM-150 Mixer
No sound put my mixer in storage for summer, took it out today but there isn't any sound. the cds are playing, everything is set up properly but i can't hear anything through my speakers or my headphones.
Mixer is not turning on. Control board?
First check the simple things, are the brushes in properly, they are keyed to only fit properly one way. Look in the hole with a torch and line the missing corner up with the blocker right inside. If you have fried something it could be damaged switch contacts on the black control plate or even weaker would be the phase board at the top just under the back cover. Testing for circuits with a multi meter will prove everything except the phase board. If you have circuits everywhere they should be then change that board.
Apr 19, 2016 | KitchenAid K4SSWH Mixer
Kitchenaid mixer motor noise at lowest speed
Hi,have you set you speed of your rotations,maybe it's set to slow.you have to Adjust the screws in the backof the mixer,so the rotation of the motor is a second apart on the speed setting three.i quite sure that's the right speed number,I have it written down somewhere,if I can find it and it's different il let you know.ty hopethatworks.
May 16, 2014 | KitchenAid K5SS Heavy Duty Commercial...
BEM800 speed going flat out
It is likely that the speed control switch is defective.
Nov 30, 2013 | Breville Food Mixer BEM800
I took my kitchenAid stand mixer (md# KSM5PSAC) apart to replace the plastic gear inside of it. When I put it back together it would not start. I took it back apart took a good look at all the connections,...
You need to either re-time the speed control switch at the back or replace it. If it worked great before then it is just an adjustment to get it back to running correctly. YouTube viseo available for timing the switch
Aug 06, 2013 | KitchenAid K45SS Classic Stand Mixer
How do I repair the speed settings It only goes on fast speed.
The screws are roughly 8 turns in from fully out when starting to set the speed. On the lowest speed 13 revolutions of the planetary in 15 seconds is a good speed.
Dec 05, 2012 | KitchenAid Artisan Series Stand Mixer -...
Mixer won't turn on
Just recheck that you really have put the brushes back in the right way, use a torch and look in the hole. The brushes can each go in 4 ways, only one of which will work. Look for the blocker and line it up with the cut off corner on the brush. It's normally at the back, one side at the top the other at the bottom. After that you need to be looking at everything you have done for a booboo. I doubt it will be water ingress. Make sure the switch contacts come together when the lever moves to position 1.
Mar 18, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
The mixer simply doesn't turn on. Worked fine yesterday. Today it seems like it's just dead
HI.Let me jusk ask if yiou also tried to connet to another socket.Let me just clarify that the motor itself did not work /rotate as well.Prior to that situation,have you tried to mix more than what is the capacity of your mixer.If possible motor was overworked/that's why its coil was burnt.There. are possibilities then. First might be that the mixers terminals inside will no longer engaged properly that's why it opens the circuit.Second the motor isn't working because the rotor and armatures coil was burnt because it runs beyond its maximum wattage capacity that's why it draws much current beyond the rotors coil capacity.Did you mixed something heavy.the motor works heavier the last time you used the unit?
Jul 23, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The flat beater is stuck in the mixer and I can't remove it.
oh yes you can.:) pur some wesson oil into the sockets the beaters go into and a little around the button.. Let set a few minutes and work the beaters back and forth as you pull gently. Make sure it is unplugged!!!!!
Oct 27, 2009 | KitchenAid KSM150PS Artisan Series Stand...
525 watt mixers broken
http://www.kitchenaid.com/flash.cmd?/#/page/customer-service here u go. Customer care will direct you to a certified kitchen aid repair shop in your area.
Apr 21, 2009 | KitchenAid KP26M1X Stand Mixer
KITCHEN AID MIXER WILL NOT WORK
If you have had the brushes out (under the big screws on each side) verify the cut corner of the brushes are oriented properly. Look inside the hole with a flash light and you will see where the cut corner needs to be.
Dec 31, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Gem Sound CDM-150 Mixer Logo
20 people viewed this question
Top Gem Sound Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Gem Sound Food Mixer Expert? Answer questions, earn points and help others
