Question about Krell Home Theater Standard 7.1 7.1-Channel Amplifier
Home theatre amplifier right speaker not working even with any other speakers.
  • 4 Answers
I have 20 year exp. with Krell. Contact me directly.
Steven Leckrone
The Service Department
203-331-0671
sleckrone@snet.net
Posted on Oct 22, 2008
Want to add external speakers that are mounted in my ceiling. They are a good quality household speakers
How do I Connect Multiple Speakers to my HiFi Amplifier
geoffthegreygeek.com/connecting-multiple-speakers-to-amplifier/
Understand connecting multiple speakers to your hifi. ... In a home theatre amplifier with surround sound, there may be 5, 6, 9 or 11 amplifiers ..... Two 4 ohms speakers in parallel totals 2 ohms, not good for an amp designed for 4 ohms or more. .... I have 6mounted ceiling speakers and I want the same sound on all of them.
Home Audio Installation: Install a Whole-House Audio System
www.familyhandyman.com > Skills > Electrical
New high-tech components make it easier than ever to install your own ... what to buy and show you how to run the wires and mount the speakers and controls. The rest is simple plug-in hookups. ... Run wire and install speakers and distribution modules so that you can .... Put it right next to the audio equipment if you want.
In-wall and ceiling speakers buying guide - Crutchfield
www.crutchfield.com/.../home/speakers_inwall.h...
Crutchfield CorporationHome Speakers / ... In-wall and in-ceiling speakers have become some of our best-selling ... about audio quality, and are also a great solution for folks who don't want to... But instead of being attached to a cabinet, it's mounted in a frame and set ...They're a great way to add background music to small or awkward spaces, ...
Dec 28, 2015 | Audio Players & Recorders
Yamaha home theatre system RXV 350 amplifier
Check it without speaker connection. If the set does not go to protection mode, check all the speakers by connecting one by one at a time and switch the set ON; to find the faulty speaker. If the set goes to protection mode even no speaker connected, check and replace damaged components at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Yamaha RXV-350 Receiver
Onkyo HT R520 Home Theatre reveiver/amplifier problem
If you have isolated the problem to the receiver/amplifier, it will be necessary to find out why that output is dead
Oct 04, 2012 | Onkyo Audio Players & Recorders
I dont know how to connect my gem sound trf152 speakers
Looks like it takes regular home theatre speaker wire. If this is a powered speaker (like a JBL eon g2), then all you need is a passive mixer, and connect the speakers to the mixer. If this is not a powered (amplified) speaker, then you will need an amplifier to boost the sound source and drive the speakers, so you would connect the mixer to the amplifier, then the amp outs to the speakers.
Apr 14, 2012 | Gem Sound TRF152 15 Pro DJ PA Speaker
Hi i am having problems with my lg home theatre system. The front right speaker will every now and then make a loud distortion noise like static and its annoying. I,ve tried new speaker wire, new contacts...
Hi.
First make sure all connections are firmly in place. Not only speakers, but any other inputs too.
swop the left and right channels over at the amplifier end. If the sound happens on the other speaker now, you have a faulty av receiver. If it's still on the same speaker, that speaker is "broken" and requires replacing.
Jan 14, 2011 | Audio Players & Recorders
Left Speaker not working
if you swap the speakers and the dead one moves,than it is the amp that is missing a channel,in your case,it is the speaker.
if you try the good speaker in both speaker outputs,it should work on both to confirm the dead speaker theory.
there may be a broken wire in the speaker from shipping.
Sep 04, 2009 | Bose 3·2·1 II System
Instalation instructions required
Uhmmm. . .okay. . .I would use nothing less than 16AWG speaker cable. Do not run the speaker cable parallel in close proximity to any AC wiring. Speaker cable rated to run through walls with usually be color coded red and black. Connected the red to the red on the speaker and red on your home theatre receiver. Do the same for the black. If speaker cable insulation is clear, look closely for subtle markings or writing on the insulation. The writing will only be on one of the two wires. Designate that as the POS or PLUS or + or RED. Connected it to the red on the speaker and the red on the back of your home theatre receiver. The other is by default the black and connect it to like colors. Repeat for all 5, or 7 speakers in your theatre. Your subwoofer probably has a seperate amplifier, so it gets it's power from it's own AC power plug. . .so plug it in. The sound coming from the Home Theatre receiver will be low-power and will carry on an RCA cable. Look for the subwoofer output on the home theatre and connect it to the input on the subwoofer. There may be a right and a left input on the woofer. . .it doesn't matter which you plug it into. . .either one will do.
Mar 09, 2009 | Audio Players & Recorders
Can i connect JVC SXXSW6000 home theatre to my pc...if so how?
You need a receiver. A surround sound receiver is a 5-channel amplifier with a line-level subwoofer out. These are available at electronics stores. Receivers usually have digital inputs like optical and coaxial that you can use with the S/PDIF output of your PC.
Nov 06, 2008 | JVC SXXSW6000 Speaker
Krell Home Theater Standard 7.1 7.1-Channel Amplifier Logo
131 people viewed this question
Top Krell Audio Players & Recorders Experts
80stech
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Are you a Krell Audio Player and Recorder Expert? Answer questions, earn points and help others
