Question about Sony KP-53XBR45 53" Rear Projection Television
Sony KP-53XBR45 convergence
Left side of picture, gross misalignment of Blue & Red
Right side of picture alignment OK
Left side picture - convergence controls no effect on left side of Picture
Right side Picture - convergence controls have effect on right side only
why would only the left side be affected ?
Convergence IC replacement?
  • 1 more comment
  • AtlantaX Oct 25, 2008
    Wow, I have the exact same problem. Just started this am, worked fine last night. Would love to know why this is occuring and how to fix without breaking budget. Thanks.
  • FranFreckles Dec 23, 2008
    Cost VarianceI have found have the same part # ( stk392-010 ) cost as low as $6 ea. and as high as $56 ea.
    My question is; What's the difference?? Is there a difference between them?? Does price mean something??
    Thank you
  • VARocketry Dec 25, 2008
    Don't forget to check/replace the pico fuses protecting the ICs as they commonly are affected in the ICs are.
    good article to read:
    http://www.techlore.com/blog/entry/19694...
Hey, found the problem. Your Convergence IC chip went bad. Buy one at Bluestar International Components (bluestar-online.com) - order part number STK392-010 for 6.99. I've read that there are two in the system and replacing them both at same time is a good idea...so, order 2. Now, if you are handy, it will require you to open the back of the TV and solder out the old chip and replace with new. If not, then you might as well call a TV repair person and have them fix. However, every place I've called works on a minimum fee for "large screen TVs" - the cheapest I could find in Atlanta was $399 minimum service fee. So, I'm going to risk the home sodering job .... it's a 10 year old TV and as good as it's been to me, if I screw it up, I feel I've gotten my money out of it. Good luck with your repair. My parts are on order.
Posted on Oct 26, 2008
Sony kp-53xbr45 please let me know step by step how to enter convergence service thank you
To enter into the convergence service of your sony, follow the steps below;
  1. Press "Menu" on the remote control. Use the up- or down-arrow button to move the cursor to "Setup" and then press "Return."
  2. Use the up or down arrow to move the cursor to "Convergence" and press "Return." This will bring up the convergence-adjustment screen.
  3. Press the up or down arrow to move the cursor to the line you want to adjust (either vertical or horizontal for red and blue) and press "Return."
  4. Press the up or down arrow again to move that line until it converges with the center green line and press "Return."
  5. Repeat to adjust the other lines until all three lines converge and are seen as a white cross.
  6. Press "Menu" to exit the convergence menu and return to the original screen.
You can as well follow these steps;
  1. Press the "Power" button to turn your TV on.
  2. Wait at least 30 minutes before you adjust the convergence in your television. This allows your TV ample time to warm up before you make the adjustment.
  3. Turn your TV to a cable channel or to an antenna channel with a picture that you can see. A music channel with a static shot of music notes isn't the kind of picture you need. Instead, look for a picture like what you would see on a movie, sitcom or drama.
  4. Press the "Flash Focus" button located in the front panel on your TV. You may need to open a hidden compartment on the front of your TV to access this button. The convergence will repair itself automatically after you hit this button. It may take several minutes.
Any of the two processes are detailed steps on how to enter your convergence service.
Take care
Jul 03, 2010 | Sony KP-53XBR45 53" Rear Projection...
Out of alignment (red)shadow
Ur tv convergence are dead.U must know how to solder.U must have soldering tools,and solder to fix convergence problems.Must repalced 2 STK convergence ICS and some or all it resistors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 15, 2010 | Sony KP-57WS500 57" Rear Projection...
Need part # KP-53XBR45, convergance IC
The convergence ICs are STK392-010, the locations are IC1601 and IC1602.
Apr 18, 2010 | Sony KP-53XBR45 53" Rear Projection...
I have out lines on left side of screen realy noticable on words and its starting on the right side to what is causing this the bulb or those ic things everyone is talking about
The ICS is dead,the convergence is dead.The 2 convergence ICS control colors misalignments.3D pictures,distorted picture and colors alignments.
Feb 16, 2010 | Sony KP-51WS510 51" Rear Projection...
Double picture & color problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Red is out of alignment
when i go to convergence and align the white cross with the blue its ok ,but when i try the red it doesnt line up and if l get it close enough it get misaligned only with the red ,green and blue fine
Nov 15, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Top left and bottom right images/letters distorted.
I can fix it for $325? 213 880 1795
It was a convergence problem, both chips goes bad bad also look for bad resistors around the circuit? This is not an easy repair for non skilled person? You need to realign it after replacing the chips? Don't be cheap pay someone to do it right?
Oct 02, 2008 | Sony KP-53XBR45 53" Rear Projection...
COLOR OUT OF ALIGNMENT ON LEFT SIDE OF TELEVISION
are you able to adjust the convergence in all 4 directions for both red and blue? If not the Convergence ICs are bad and need replacing. If you ned more info let me know.
Apr 08, 2008 | Televison & Video
Sony projection blue double vision KP-61XBR48 mod #
Joe, did you have a tech confirm it`s the yoke? Not a common problem to have a yoke failure, maybe yoke return resistor(s) or possibly bad convergence IC`s, poor signal from DCU (digital convergence unit).
Nov 29, 2007 | Sony KP-53XBR45 53" Rear Projection...
KP-53XBR45, Sound OK, but no picture
You may have a bad convergence... short will shutdown your HV circuitry leaving just audio?
It has no bulb to change?
Oct 29, 2007 | Sony KP-53XBR45 53" Rear Projection...
Televison & Video Logo
357 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
