Question about LG Washing Machines
No power to washer/dyer although power is switched on and ok. If you switch it off and back on the machine bips.
The door catch was not connecting properly.
Posted on Oct 15, 2008
Maytag neptune model mhs2000aww stackable dyer works but washer side not getting power why
test this steps and fix it. God bless you
  • No power to the washerMake sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
  • Lid switchThe washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defectiv
  • Read more: http://www.appliancepartspros.com/repair-help/washer-repair-help.html#1#ixzz2gUeyhEyb
    Oct 01, 2013 | Maytag Neptune Washing Machines
    Whirlpool Ultimate Care II no powerWhirlpool Ultimate Care II no power 1st it would get to the spin cycle and not go any father just hum now no power at all
    this has a kenmore type lid switch, they often break and although seem ok will not allow the machine to spin out. I would replace the lid switch. (you have to remove the two screws at the corners of the control panel and it hinges back to remove the plug to
    the lid switch.) Make sure unit is unplugged first. There is also a 5/16 grounding screw
    under the top of the machine which is in a difficult location. It also attaches to the
    lid switch and must be removed. The plastic channel holding the wiring clips onto
    a lip in the sheetmetal. It takes a bit of patience to get this switch out and skinny arms.
    by reaching between the drum and the top of the machine. Hope this helps.
    Jul 06, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
    When I try to switch it on you can hear the processor go on but nothing happens, the screen stays black and then a very loud bip.....bip...bip occurs; and then..nothing else
    1. Check your power cord & adapter.
    2. If its working then check the battery, reseat the battery & check.
    3. If available then check with another battery
    4. If no, then remove the battery & switch on the PC in AC mode.
    5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
    6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
    Aug 20, 2010 | HP Compaq Presario V2000 Notebook
    My ps3 works with a hdmi cable but it will not display to any tv.
    hold your finger on the restart button(the button next to disc eject button) for 5 sec to reset the settings
    Jun 05, 2009 | Sony Playstation 3 (PS3) Console
    How do you change the output setting from hdmi to the rca cable setings? I have no picture screen on my crt tv.
    you have to reset the ps3 because you have it with hdmi before and the ps3 is looking for an hdmi connection is very easy and there is nothing wrong with your ps3 ok so do the follow
    turn the power switch off on the back of the unit then put your finger in the on/off switch now turn the main switch on the back of the unit you will heard a first bip sound this is when your ps3 turns on ok keep your finger there in the on/off switch until you heard another bip sound now remove your finger from the on/off switch and bingo this will reset your video settings now you can see picture again using regular av and every time you use hdmi you have to do this again
    Jun 05, 2009 | Sony PlayStation® 3 (80GB) Console
    My ps3 doesnt show audio or video
    Hi my name is Juan and let try to solve this did you have try to do the manual reset to the video ok lets do it first turn the unit off and turn the main switch on the back of the unit off place your finger in the on/off switch in front of the unit with your finger there turn the main switch on the back of the unit and you will heard a bip this is when the unit turns on keep your finger there and wait for a second bip once you heard the second bip remove your finger because if you keep it there for too long the unit shufts off and it won't reset the video settings so if you take your finger out at the second bip then just wait about 10 seconds and it should be a picture there thanks and hope this works for you
    Mar 16, 2009 | Sony Playstation 3 (PS3) Console
    The power comes on but the HDMI is not responding?
    did you have try to reset all the video settings ?? ok let's try that my name is Juan and I am here to help you and see if we can solve this with the unit off turn the main switch off on the back of the unit connect the HdmI cable to the unit and to the tv now place your finger on the front on/off switch and keep it there now turn the main switch on the back of the ps3 keep your finger on the on/off switch for about 4 seconds or until you heard one bip (but not the first bip when the playstation turns on ) ok so once you heard the bip after few seconds remove your finger from the on/off switch and this should make your hdmI to work again just wait few seconds for the signal to show up on your tv sometimes it takes about 30 seconds once you see the browser the system will ask you if you want to switch to hdmi click yes hope this can fix your problem and if it does please rate my help thanks
    Mar 11, 2009 | Sony Playstation 3 (PS3) Console
    Toshiba external hard drive 1TB USB 2.0
    I talked to the customer service of the brand. They know what's related to the noise the HD does right now: real damage. The best thing to do is to switch it off and bring it to a professional data recovery place, which is what I will do next week.
    Thank you anyway for your help. I don't need further assistance on this issue.
    Cheers,
    Dec 15, 2008 | Western Digital My Book Office Edition 1TB...
    Dyer on combo won't start
    This could either be a bad start switch or door switch
    May 29, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
    Washing Machines Logo
    26 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
