Floppy drive ok yes then in that case the BIO's / CMOS. you refer to as pushing a button on start up to get to would be the F1 on a HP like you have kindly listed for me but just to let U know like i have also stated i have done been to the DOS mode..whitch you should then know that DOS mode is BIO's / CMOS. so still no help, I appreciate you keep trying to help tho. plz try again ..ding..
  • j bowser
    j bowser Oct 15, 2008
    sorry was a repeat
    Genius:
  • 1,124 Answers
Ok, sure I will
I wrote an answer in the last question. check it out
Posted on Oct 15, 2008
Desktop wont boot past floppy disk seek failure
There is a menu in the BIOS (set-up) menu that disables the floppy drive. This option enables or disables the floppy drive.
Aug 15, 2012 | Dell Computers & Internet
Emachines D4362 starts only after many button pushes
Sounds like you might have corrupt window system files or the machine might not be recognizing the hard drive.
Press the DEL button to go into the BIOS. Go to the section that shows you the hard drive. If it doesn't show you a hard drive model and shows none then your hard drive is bad and would need to be replaced. If your hard drive is recognized in the BIOS then you'll need to try and reinstall windows. If you can't get windows reinstalled then the hard drive is bad at that point as well.
Jan 18, 2012 | E-Machines eMachines Desktop PC
Ok this is odd. I have a dv2-1030 and every time i put a harddrive in new or use i still get operating system not found. I have tryied installing a new os with no luck because it says there is no drive...
Yes the connector can go bad..
Did you try booting from CD? useing a windows cd?
The cmos may not be setup right, when you first turn it on look for [push f1 to enter setup] maybe f2,
Some time when you unplug a hard drive then turn the computer on it will disable it in cmos
May 16, 2010 | HP Pavilion dv2-1030us Notebook
Strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Dec 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
ASUS A7N8X-E Deluxe Motherboard supports 1TB SATA2 HDD?
1) Grab a blank floppy, and a computer running Windows with a floppy drive.
2) Download C18E1013.zip (A7N8X-E Deluxe Latest BIOS, from Asus), AWDFLASH (Also from Asus), the latest Silicon Image SATARAID BIOS (from Silicon Image), and CBROM 2.15 (Alternative CBROM 2.15 download link)
3) Extract all the contents of everything into an easily accessible folder, preferably something like C:\bios
4) Make sure you have no other folders in this new folder. Everything must be within C:\bios, so for example there shouldn't be anything in C:\bios\BIO-003112\
5) Open a command prompt (Start -> Run, type "cmd" and hit enter, without the quotes)
6) Navigate to the folder you just created using the command "cd" (For example, if you used the folder I suggested above, you would type "cd C:\bios", without the quotes, and hit enter)
7) Now type "cbrom215 c18e1013.bin /pci 4284.bin" without quotes, and hit enter. This will take the latest BIOS for your motherboard, and merge the new SATARAID BIOS into it.
8) To make sure everything went correctly, type "cbrom215 c18e1013.bin /D". This will show a list of the modules in the BIOS. At the bottom should be a line with PCI(A), and should have "4284.bin" at the right end of that line.
9) Now put the blank floppy into the computer with the floppy drive.
10) Open My Computer, right click on the floppy drive (probably A:), and select "Format"
11) The formatting window should pop up. Check the box labeled "Create an MS-DOS startup disc" (which should disable all the other options), and click Start.
12) Click OK and close the format utility when the process completes.
13) Copy the modified BIOS file c18e1013.bin and the file AWDFLASH.EXE to the floppy disc (simply a drag and drop).
14) Close everything on the computer with the A7N8X-E Deluxe motherboard and reboot it. Make sure the computer is set to boot to the floppy drive, and that you have put the floppy in the drive.
15) Type the command "awdflash c18e1013.bin /py /sn" once you get to the "A:" prompt.
16) Press enter to confirm that you wish to overwrite the current BIOS.
17) Wait.
18) Once it says it is complete, remove the floppy, press F1 (as instructed), then reboot the machine (which should happen automatically once you press F1). Now the computer should detect the 1TB drive upon booting.
Jul 02, 2009 | ASUS Computers & Internet
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to continue,...
Press F2 to enter the Bios, on the first screen navigate to the floppy A: drive select disable and the error should go away.
From the sounds of it your Floppy drive is damaged or just bad. you can take it for repair or purchase a new one fairly cheap and replace it yourself. But just disabling it should do the trick since floppy's are pretty much obsolete.
the recovery Disk wont help you unless its an error you get in windows itself btw.. (unless its a OS start problem which this doesn't seem to be)
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
F1 floopy diskette faliure seek faliure
Make sure it is not disabled in the boot order, there is also an option for the drive itself (Diskette Drive) that must be disabled
Jan 05, 2009 | Dell Dimension E310 PC Desktop
Bios hagging help
i think problem with your BIOS
http://downloadcenter.intel.com/download.aspx?url=/12687/eng/SC1-032P.BIO&DwnldId=12687&ProductID=2441&lang=eng
Download this .BIO file from intel Web site & Copy it to floppy disket & remove your CMOS Jumper, insert your floppy & turn on your pc after few beeps pc will automaticall turn off. replace your CMOS jumper & turn on & load BIOS default valus.
* use Good working condition floppy drive & full formatted high density floppy disket (new one) & UPS for backup.
Oct 25, 2008 | Intel D865GBF Motherboard
Floppy drive
You're talking about My PC and device manager and I'm talking about Bios.
The BIOS (stands for Basic Input/Output System) is system software inside your computer that helps the computer start up, even before Windows does. It also contains key settings about what the computer has on board.
In newer computers, it exists on a special chip called CMOS (stands for Complementary Metal Oxide Semiconductor).
You can go into the BIOS to edit or change the technical information about key components of the computer like disk drives, keyboards, and display settings. It also keeps track of the date and time.
The BIOS can normally be accessed when you start your computer. You may see a reference to "Setup" when you turn your computer on. That’s your opportunity to get into the BIOS. It usually requires the push of a function key, such as F10, to get access to it. That "F" key varies between computers. Sometimes it’s not even one of the Function keys, but the ESC key or DEL key.
If a logo screen—like HP or Dell—is displayed during the start up process instead, then you may want to check with your computer maker for a command to turn off that screen and display the start up information, which is listed when a computer is powered on.
A partial list of BIOS access commands by brand is listed at the end of this article.
The BIOS also contains the boot-up sequence. Normally, computers are configured to boot from a hard drive.
Before you do anything to your BIOS, it’s always a good idea to record the original settings on a sheet of paper that can be kept in a safe place so you can reference it later if you need to reset it.
Here is a list of key sequences for various brand-name computers. If yours is not there, check with your manufacturer or watch for info flashed on-screen when your computer first starts, before Windows begins. It may say
"For setup hit..." That will be how to get into the BIOS on your machine.
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or Ctrl+Alt+Esc
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl+Alt+Esc
Award BIOS: (Del) or Ctrl+Alt+Esc
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during boot up.
Aptiva - Press F1
IBM PS/2: Ctrl+Alt+Ins after Ctrl+Alt+Del
IBM PS/2 with reference partition: - Press Ins during boot
Some PS/2s, such as 75 and 90: - Ctrl Alt ?
Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or Ctrl+Alt+Esc
Phoenix BIOS: - Ctrl+Alt+S
Phoenix BIOS: - Ctrl+S
Phoenix BIOS: - Ctrl+Alt+Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl+Shift+Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift+Ctrl+Alt + Num Pad Del
Miscellaneous PC’s: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl+Alt+Ins
Let me know how it is going!
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Computers & Internet
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
