Question about RCA TH1602 MP3 Player
My player wont turn on and wont connect to my computer, what can i do?
  • 4 more comments
  • XxMuFdVrXx Oct 17, 2008
    wont turn on and wont connect to computer
  • baha_mut_0 Nov 15, 2008
    my batteries went dead and when i replaced the battery all it does is come on and says pearl thats all it does need to see how to reprogram it?
  • bncglvn Nov 19, 2008
    My battery died, I put in a new one. Now it wont turn all the way on, the screen shows "pearl" then it shuts off. It won't connect to my comp either.
  • laethen08 Nov 19, 2008
    the name "pearl" comes up then does nothing, is there any way to fix it?
  • domino86 Nov 27, 2008
    pearl shows up and goes off and it wont connect to the computer
  • DebDerra3 Dec 25, 2008
    My computer keeps saying it doesn't reconize the usb cable and does nothing. DD
As you plug the device into the computer, hold down the Play button. Leave it held until you see that it is installing new hardware (something like ROM initializing). If this doesn't work, you may need to add devmgr_show_nonpresent_devices=1 to your environment variables (search that variable to find how if you don't know) and then in the device manager go to view and show hidden. Make sure the device is not plugged in and then remove all references to it in the device manager (any grey USB MSD or HID is what I removed). Now plug in the device while holding in the play button. I had to reboot to complete this part. Now you should be able to load the firmware (this was required here, it will format the device so there will be no files on it, including the ones that it shipped with).
Posted on Dec 09, 2008
My player wont turn on it shows pearl then shuts off and it wont connect to my computer all it does is make a sound but nothing pops up
Posted on Dec 22, 2008
Posted on Nov 07, 2008
RCA TH1602 MP3 Player won't connect to computer
when you do the plugging in and play button action does it delete all your music from the device?????
Apr 06, 2013 | RCA TH1602 MP3 Player
RCA pearl th1602-a with new battery will not power on. Old battery will power on, but freeze at pearl logo. Player dosn't power on when plugged into USB of computer
Try a firmware recover. Download the firmware update from the RCA website and install the app. Start the updater and connect the player holding the PLAY button until it gets detected.
This is a similar player with the recovery procedure explained:
Oct 28, 2009 | RCA TH1602 MP3 Player
My mp3 player turns on but frezzes it shows pearl?
Follow these instructions to fix your RCA TH1602 MP3 player.
Whenever your player acts up, the best solution is to reflash/upgrade the firmware.
Download the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and follow all the troubleshooting instructions that popup when you start the program:
  1. start the program,
  2. remove the battery,
  3. hold the play button while plugging the RCA player into your computer's usb port,
  4. release the play button when the term "initalizing" replaces "searching",
  5. check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
  6. click the start button to replace the firmware.
This solution will fix your player.
I hope that helps.
Jun 18, 2009 | RCA TH1602 MP3 Player
Computer not recongize the rca th1602 mp3 player
The first time I tried to restore the firmware in my Pearl it would not recognize it. I had to follow all the troubleshooting instructions that popup when you run the software. Basically, try taking the battery out and waiting 10 seconds or so. Run the software and read all the instructions at the bottom of the popup window. then hold the play button, plug your player in, and keep holding that button until the software recognizes it. It works.
May 05, 2009 | RCA TH1602 MP3 Player
When i put mp3 player on the computer it wont come up
If device not recognized at all:
Try removing the battery, insert Pearl WHILE SIMULTANEOUSLY PRESSING and HOLDING the "PLAY" button. Windows Device Manager should see the device under "Human Interface Devices"as a "USB Human Interface Device". Run the latest firmware update, it will see the HID device and initialize it as a "Disk Drive", "_Generic MSC Recovery USB Device". Once the firmware update is complete the Pearl should work again. The trick was to remove the battery and hold down the "Play" button while inserting to force recovery mode.
Apr 03, 2009 | RCA TH1602 MP3 Player
RCA Pearl TH1602 MP3 Player i can not get my songs on it
It depends sometimes some songs may be copyrighted and cannot be played on the Mp3............ But as u say ur able to play 67 songs............ Just format your Mp3 player...... Formatting the Mp3 Player: Connect the Mp3 player to the Computer.......... Go to My Computer> Right click on the Removable Disk and click on Format and click on Start..... Know reload all the songs back to the Mp3 player..... Good Luck............
Jan 19, 2009 | RCA TH1602 MP3 Player
I can't charge my RCA TH1602-A MP3 player....this is really a problem because its out of charge!! HELP PLEASE!
Check the following:
  • Battery is empty.
  • Ensure the keys lock is not activated.
  • Reset the player by removing and re-installing the battery.
  • If the player still cannot be turned on after resetting, perform a firmware upgrade to restore it.
Jan 15, 2009 | RCA TH1602 MP3 Player
Downloaded software from my rca flash mp3 player series th1602-a. I tried to download the updated version and it is not allowing me to download. I have tried plugging in the mp3 into the computer by...
when it says download updated version, ignore. Better yet don't use RCA software at all. Use your windows media player(version 10 or better). Click on file wanted to start media player. Then click on "now playing" and display item or all chapters if audio book is being played. Plug in RCA and drag item(s) to working area of Media Player. Hit sync. and finito!
Dec 16, 2008 | RCA TH1602 MP3 Player
RCA TH1602
potential battery issue
Sep 29, 2008 | RCA TH1602 MP3 Player
RCA TH1602  MP3 Player Logo
162 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
