Question about Microwave Ovens
The main 10A 250V Fuse keeps on blowing up everytime I use my Microwave function. This does not happen when I use the Convection Oven.
I have a National Microwave/Convection Oven Model NN-C988W. The Main SICHERUNG Fuse keeps on blowing up within a sec from turning on the Microwave function. This does not happen when I use the Convection Oven function. I looked around on the control panel but could not notice any blown components.
Thanks in advance for your help
  • BilalHabash Oct 22, 2008
    Ground checked to be ok. But what I have noticed that the Antenna on the Magnetron is damed (melted all around). The test readings of the Magnetron was ok. but the fuse still gets burned as soon as I turn on the microwave. Is the damaged Magnetron Antenna doing this?
  • abdemello Dec 09, 2008
    fuse blows off when going to microwave mode ,
  • 99 Answers
Possibly magnatron to earth fault.Needs testing profesionaly.(microwaves can kill even when unplugged.)Regards grandadfixer
Posted on Oct 15, 2008
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
I have a panasonic microwave with convection oven, grill and steamer. When I switch on the microwave, the house fuse (16 amp) cuts out. With the other functions of the oven, it works fine. Do I need a new...
you have a short circuit.
test the a) HV rectifier b) Capacitor HV c) HV transformer d) Magnetron e) test the swich for door for short.f) circuit board main is short.
see the diagrams and proceed.
10_2_2012_12_41_44_pm.jpg10_2_2012_12_42_15_pm.gif10_2_2012_12_42_35_pm.gif10_2_2012_12_43_09_pm.jpg
Oct 01, 2012 | Panasonic NN-C994S Convection/Microwave...
The food in the microwave is not heating up I have tested the fuse (F8AH250V) and found that it has blown. Is it safe to replace this fuse (F8AH250V) on my microwave.
Fuses seldom just go bad on their own, but it's safe to replace. Before you replace the fuse, squeeze the tabs of the fuse holder clips together a bit. Sometimes they don't grip the fuse tightly enough, and this can cause heating which damages the fuse. If the fuse blows again there is a bad part in the oven that will need to be located and replaced. For a small countertop oven, it's probably more economical just to replace the oven than to repair it.
Jan 02, 2011 | Sharp Microwave Oven Microwave Oven
What size fuse is a 250v 10a drawing fuse inside my microwave would a 6.3 32mm fuse be ok.its a lg ms-283 mc microwave
Chances are it is a standard 1/4" x 1-1/4" (6.3mm x 32mm) but I would suggest measuring it to be sure.
Here's an exploded view of that oven to help in disassembly.
May 28, 2010 | LG LMV1650SW Microwave Oven
Microwave blows fuse in microwave mode grill function ok
It is most likely the capacitor has shorted or the rectifier has shorted. Check with ohmeter, but make sure it is discharged first by shorting the capacitor with a wire.
May 21, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
Oct 24, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave Oven has died
Hi.
Check continuity of this 10A fuse to see if it's blown.
What is most likely to have happened, is that an internal short has happened inside the main transformer. These cannot be rectified, and often means scrapping the complete item due to cost of replacement.
However - if you can find another microwave with a different fault - just remove the good transformer.
Checking the transformer for a short at high voltage is not recommended.
You could try a spare 10A fuse as a start point (probably a leaded type) - but expect it to blow again. DON'T go higher or omit !
Sep 30, 2009 | Microwave Ovens
Microwave doesn't work
the outer casing has to be removed, inside you will find a large fuse 10A> this protects the transformers and magnetrons, also you will find some smaller control circuit fuses, they are normally mounted on the circuit board at the rear of the control panel.
Feb 23, 2009 | Sharp R-820B Convection/Microwave Oven
Sharp R-9H66C Microwave Convection blowing fuses
check high voltage transformer and high voltage diodes, condencer, and magnetron.,
Oct 27, 2007 | Sharp R-963 Convection/Microwave Oven
Microwave Ovens Logo
752 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
