Question about Sega Master System Console
BOX THINGY Hey i recently found my sega master system 2 and wanted to play it but i cant find the box thing that you need to switch it from the tv to the game itself... i have no idea what this thing is called.. and do you need it or is there a way i can plug it in without it and be able to play?
  • 52 Answers
The box is a RF switching box
the lead you require is a phono to ariel lead (megadrive, master system or any old computer will do)
or if you get an old video lead and cut of one end and wire a phono plug to it it will also work.
or you try ebay
http://shop.ebay.co.uk/items/_W0QQ_dmptZUKQ5fVideoGamesQ5fVideoGameAccessoriesQ5fVideoGameAccessoriesQ5fJN?_nkw=sega+rf++Master+System++&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=sega+rf&_osacat=0
a basic lead for £2.50
replacments upto £10
both work
Posted on Oct 29, 2008
How to connect sega master system 2 to lcd plasma tv
If your TV comes with a composite video input then this may not be an issue. You need the RCA AV cable. Sega outputs only mono audio so put Yellow in TV video In and White in TV audio In (white connector).
http://www.gametrog.com/GAMETROG/HOW_to_connect_Hook_Up_SEGA_Master_System_Instructions.html
If you still have the RF box for the Sega then you should be able to put RF from Sega and TV antenna to the RF box and connect RF box to TV antenna in.
If TV is only HDMI input then you need a converter like this
Composite Video to HDMI Converter
Sep 04, 2014 | Video Game Consoles & Games
I have just found my old sega master system and would like 2 play it on my plasma tv, however i have found it difficult 2 install. any hits would b helpful
You need to hook it up to one of the inputs and remeber the input being used so you can change your plasma tv to it so when you turn on your sega master system the screen will show up.
Here is a video from youtube that shows you exactly how to do it. Sega Master System plasma hookup.
May 15, 2011 | Video Game Consoles & Games
I need help setting up my Sega Master System, I am unable to attatch it to the tv.
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or want your console modified to connect to a modern TV via AV inlets or S-video visit www.gameoz.com.au they stock a huge range.
Jan 30, 2010 | Sega Master System Console
Needing instructions to set up
If I remember correctly the master system only has one lead that looks a bit like an antenna connection, one goes into the back of the console and the other goes into the antenna input on the tv.
Then you need to plug the console in to mains outlet turn it on and tune in your tv to pick it up. I normally plug it into the antenna outlet and switch my channel on to the same channel that picks up the vcr, and it works
Nov 18, 2008 | Sega Master System Console
I am trying to locate a auto rf switch box for my sega master system 2
Looks as if Nesfixxa400 has never seen athe back of a Mastersystem 2, there is only an rf lead port!
so you are looking for a RF splitter
you can seach for the following
master system rf switch box
Megadrive 1 rf lead with switch box
I also remeber at a 99p shop seeing a 3 way TV switching box
search for MK-3088 on ebay (below) they are compatable
http://search.ebay.co.uk/search/search.dll?sofocus=bs&sbrftog=1&dfsp=1&catref=C6&from=R40&satitle=MK-3088+&sacat=-1%26catref%3DC6&a14=-24&a6=-24&a10244=-24&alist=a14%2Ca6%2Ca51%2Ca10244%2Ca3801&pfmode=1&reqtype=1&gcs=1132&pfid=1621&pf_query=MK-3088+&sargn=-1%26saslc%3D3&sadis=200&fpos=IG7+5BP&sabfmts=1&ga10244=10425&ftrt=1&ftrv=1&saprclo=&saprchi=&sass=&fsop=1%26fsoo%3D1&coaction=compare&copagenum=1&coentrypage=search
Jul 01, 2008 | Sega Master System Console
SEGA 32X SYSTEM
OK HERE's where I found some of those plates and the wire www.ebay.com/electronics
May 18, 2008 | Sega Genesis 2 Console
Sega master system 2 setup - can't get picture
most likely problem is that your tv isn't tuned to the sega - you can fix this by going into the tv menu and tuning it manually
Mar 31, 2008 | Sega Master System Console
Sega Master System Console Logo
308 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
