Question about La Pavoni PA-BURR Electric Burr Grinder
La Pavoni Coffee Grinder PA Burr
Grinder will not run. I have tried unplugging the fixture. Problem occurred when I ground too much coffee, which filled the container to the hole where the ground coffee exits the grinder. Is there a reset button? Other solutions? THX
    Novelist:
  • 137 Answers
Usualy reserable termic fuses are attached to body of motor, or inside the winding wires of motor.
  1. if it is attached to motor body than you should reset yourself, usualy they are black, round colour with red reset button on center. it is enough to push that red button and you reset it.
  2. if it is in winding wires it should reset when motor temperature drops, if that is not the case than you should consult winding expert for that, in your region.
Posted on Mar 29, 2009
I'm looking the right part (portafilter or handle and cups) for my La Pavoni Duet PA-1315.
try this link
if not listed use contact us or ask
some parts may have been discontinued
La Pavoni Parts
Oct 11, 2016 | La Pavoni Coffee Makers & Espresso...
Krups burr coffee grinder - When I push the power button it flashes on briefly and then stops. It has briefly ground some beans so it working to some extent. Any ideas what is causing the grinder to...
Empty the grinder and see if it will run with no coffee bean in it. Some times debris will get caught in the grinder because it got mixed with the beans from the factory. If it runs your good to go. If not then the mother connection are not solid and it will run off and on at will.
Oct 14, 2013 | Krups Burr Coffee Grinder
I lost the clear plastic top cover of my la Pavoni MEC-258. Where can I order this part? Believe it or not, this has been a very reliable, well working, if not somewhat messy little grinder. We've...
http://espressocare.com/PDF-Files/PDF-Schematics/LaPavoni/LaPavoniLeverComplete.pdf
Is this the right one?
If not, I would go to http://www.lapavoni.com and find the service center that is closest to you and call them on the replacement part.
Sorry, but there just doesn't seem to be any La Pavoni replacement parts carried by any of the American suppliers.
Jun 05, 2011 | La Pavoni Automatic Burr Coffee Grinder -...
How to change burrs
1 take the bell(bean container) carefully out. 2 disassemble the upper holder of burr 3 you will see now the burrs, clean good coffee remains than disassemble the burrs 4 after disassembling burrs clean good the lower and upper burr holder. 5 carefully switch on the grinder tan switch off(few seconds) during lower plate is rolling touch with marker the surface of burr holder very softly, if it is ok you will have complete circle / if it is deformed you will have incomplete circle( that you must compensate with letter tape ) after each correction you mark the burr with marker to see did you achieved perfect result. once you have lower burr in place you screw bolts in upper bur holder and assemble it back in his place.
Feb 11, 2011 | La Pavoni Jolly (PA-JL) Electric Burr...
How to clean it
Put some rice in it and run it...
heatman101
Sep 30, 2010 | La Pavoni PA-MILL Electric Blades Grinder
Delonghi DCG49 is suddenly quieter and will not release coffee
Had this problem with my burr grinder, coffee (or something else) is clogged between the burrs and the output chute, so new coffee can't feed in from above. You can try a few things:
1. Unplug and try to dislodge the blockage from underneath with a toothpick.
2. Disassemble and remove the blockage.
3. I've had luck with drizzling a little bit of cooking oil on to the burrs,letting it soak in a while, then running it, the clumped coffee came loose. It made a terrible mess in the bin, but I ran a couple cups of beans through and it cleaned up the oil.
Good luck~
Feb 09, 2010 | DeLonghi DCG49 Electric Burr Grinder
La Pavoni Napolitana: the grinder works however
Yes. Inside on the top after you loosen 2 scres the coffee warmer plate comes off there is a reset switch.
Apr 27, 2009 | La Pavoni Napolitana PA-1200 Espresso...
La Pavoni Napolitana Espresso Machine
Try to take of the top and see if you can see any thermostat fuse, on some machines this are on the boiler.
Jul 04, 2008 | La Pavoni Lusso PL-16 Espresso Machine
Cleaning La Pavoni Burr Coffee Grinder
You'll need to remove the hopper and grind out all the beans. Then, with the lock tab depressed (if it has one), unscrew the grind adjusting collar out of the body. Once it's out, there are three screws (sometimes only two) holding each burr. Remove screws and separate the burrs. Clean away!
Be very careful putting it back together so that you don't cross-thread the collar into the body. Clean threads can help this.
Jan 02, 2008 | La Pavoni Burr Coffee Grinder - Black
Looking for users manual
You'll find it here: http://www.lapavoni.com/
Nov 21, 2007 | La Pavoni Automatic Burr Coffee Grinder -...
La Pavoni PA-BURR Electric Burr Grinder Logo
375 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
