Question about Whirlpool LER5636P Electric Dryer
Dryer wont work!
I have a whirlpool dyer LER8648PWO
It wont start. We have checked the plug and cleaned out the back of the dryer. We have checked the thermanal fuse(sp) and it still wont work.
It just wont turn on at all.
We even checked the breaker.
What could this be? Is there a restart somewhere?
We just bought it used but it worked at the ladys house.
    President:
  • 1,901 Answers
A couple suggestions: (1) The switch in the front may be bad. It's the switch that turns the dryer off when you open the door. (2) Make sure the door latch keeps the door shut. If it is worn and the door isn't shut tight, the switch will not let it start. Hope this helps.
Posted on Oct 15, 2008
Whirlpool duet electric dryer leaking water
Check and clean your venting from the dryer to the outside. If it is plugged it will trap the moisture in the machine. Remember heat doesn't dry the clothes without air flow to push the moisture out.
Mar 04, 2013 | Whirlpool Dryers
Dyer
Did you check if the motor works? If it never starts that may be the cause.
Apr 03, 2008 | Whirlpool GEW9250P Electric Dryer
Where is the the reset button on roper dyer
There is no reset button on any dryer. Your Roper is a Whirlpool with a different nametag. Depending on how old it is there may be 1 or 2 non resetable fuses. They are in the back behind the rear cover. They blow when there is another problem. Such as a clogged exhaust or a bad cycling thermostat. Don't do any work on it without double checking that the machine is unplugged
Nov 20, 2011 | Roper REX3614KW Electric Dryer
My dyer wont heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 11, 2011 | Whirlpool LER4634J Electric Dryer
Whirlpool dyer will not work, have replaced the board but
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker. I have checked every part in the entire unit. That was over 2 years ago. I still need to get a control panel and see if it fixes mine but after dropping $130 on the control board, i feel i could buy another dryer with the $200 they want for the control panel. Also this dryer seems to streak my clothes with brown or rust colored spots. The dryer is spotless inside. I even took off the rubber seal because i thought the glue is what was possibly doing it when it heated up but that didn't help either....This dryer sucks.
Dec 21, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer works but will not tumble
It sounds like the belt is broken. Take a look a the video at this link and see if it helps you. Sure hope so and best wishes.
http://www.youtube.com/watch?v=9dd1Ac4_pXY
Sep 11, 2009 | Whirlpool LER8648P Electric Dryer
Whirlpool Electric Dyer Problem
most of the time the dryer vent hose,wall vent and dryer vent hole must be clear to allow the dryer to vent,also you can pull dryer hot put you hand on the dryer vent hole turn on and see if it is venting this will let you know if the blower wheel is turning, let me know what you find-mike
Sep 25, 2008 | Whirlpool Dryers
Dryer won't start
Check the door switch, if the switch is bad the dyer thinks the door is open it will not start.
Apr 22, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
296 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
