Question about One For All Zapper 1 URC-6010 Remote Control
Program TV'S Hi i have a universal remote it is a one for all.Number on remote is URC-6010. I am trying to tune it to a MITSUBISHI TV. Model of TV is CT-201AMS. I also have a EASY ZAPPER UNIVERSAL Remote.Number on that is SBC RU 151. I want them for the above same TV as well please. Thanks
  • yvonnecharli Jan 10, 2009
    L have lost the manual and know that you can flick thru the channels with the remote by pushing the magic button but forget how to do it
5 Suggested Answers
Sparky-UK
  • 129 Answers
SOURCE: universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 21, 2007
Sparky-UK
  • 129 Answers
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
http://www.ofausa.com/remote.php?type=URC3220
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 30, 2007
robotek
  • 1512 Answers
SOURCE: help
Sure you can. Get the any code you need from the owners manual here
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=philips&dv=universalremote&md=sbcru545&kw=RU+545&st=&ar=&dt=&so=&pg=1&file=others/philips/sbcru545-manual.zip
or try these codes directly if you are already up for programming the remote.
Samsung.............0583, 0883, 0064, 0397,
..................................0036, 0244, 0317, 0671
Posted on Jan 28, 2008
jack_daniels
  • 304 Answers
SOURCE: tuning a philips remote to a philips tv
instructions on tuning a philips universal remote sbc ru 440 to a philips tv
Posted on Nov 23, 2008
popsgifts
  • 160 Answers
SOURCE: I have a Phillips Universal remote control no SBC
First, the RU430 model doesn't exist in the Phillips database...but you also chose the PM335 category, and that one we can work with.
To be sure, flip the remote over and look for a model number and hit this link:
http://www.support.philips.com/support/catalog/catalog.jsp?pageFrom=supportHome&navAction=pop&categoryid=REMOTE_CONTROLS_CA1_US_CARE&navCount=1&userCountry=us&country=us&catalogType=consumer&userLanguage=en&groupId=null&title=Remote%20Controls&_dyncharset=UTF-8
Once you've located the model, use the "Code Finder" link on the left to get your TV's code.
> It's a pain, but not as complicated as it is with some other manufacturers...that's why we switched to Phillips remotes all over the house.
***Don't forget to VOTE for the guys who take an interest in helping!
Posted on Apr 30, 2010
Im trying to program a Panasonic universal remote to clear tunes tv
Search Results
    Need codes for ct-300 clear tunes universal remote - Fixya
    www.fixya.com/.../t17341079-need_codes_ct_300_clear_tunes_universa...
    Mar 26, 2013 - need codes for ct-300 clear tunes universal remote Need codes - Symphonic ST419E TV ... Universal remote code for a panasonic ct-27g14a.
    I have a clear tunes tv and trying to program my RCA universal
    www.fixya.com/support/t25649135-clear_tunes_tv_trying_program_rca
    Apr 16, 2015 - ... a clear tunes tv and trying to program my RCA universal remote to it ... "I need to program an old Panasonic TV with a RCA universal remote ...
    I need the codes to a clear tunes remote for a rca - Fixya
    www.fixya.com/support/t3026751-need_codes_clear_tunes_remote_rca
    Sep 26, 2009 - I need the codes to a clear tunes remote for a rca tv. ... "I need toprogram an old Panasonic TV with a RCA universal remote model RCR311St ...
    Radio Shack panasonic remote control codes clear tunes tv ...
    www.fixya.com > ... > panasonic remote control codes clear tunes tv
    ...remote. the panasonic codefor my radioshack 3-in-one remote is 0250 I need a codefor a VCR Durabrand (DCV603) for the Sony universal remote control or a ...
    Clear tech tv 4 digit code - TV - Other Consumer Electronics
Jan 25, 2016 | Panasonic Televison & Video
I can't find the code to so I can program my
Here is an online manual. http://www.manualslib.com/manual/334599/Universal-Remote-Urc-R6.html
Sep 29, 2014 | Televison & Video
I need the code to program a sanyo tv using the one for all untiveral remote URC-2060
If you do not have the code for you Sanyo TV then you can use the remote itself to get the code. It is a bit painful as you have to count the number of blinks it makes.
Follow the steps under getting your code.
Also it would help if you provide the model number of your sanyo TV in the comments section.
How to Program your One For All remote
Aug 17, 2014 | Televison & Video
Please help. I need the code for a urc 11-7130 to tune it to my tv.
What is the brand name to your TV? If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 14, 2013 | Televison & Video
NEED set up CODES FOR MAGNAVOX TV
Many One-for-All remote manuals and code lists are available here: http://www.oneforall.com/support/manual . Fill in Universal Remote Control and then the model number in the drop-down menus. Then click on the link to the manual. (It's a pdf so you'll need Adobe Reader or a similar program.) The direct link to the URC-6131N manual (English version) is http://www.oneforall.com/uploads/support/9e15c67cf9731f8b8e9b376352f23493.pdf .
Try the following codes: 0054, 0030, 0179, 0024, 0186, 0187, 0386, 1254, 1454 for Magnavox TVs. Please note that universal remotes usually only have codes for devices released at least 6 months before the remote was programmed. If your TV is newer than your remote, you may need a newer universal remote. The URC-6131 gives it a date of Feb 2003.
I hope this helps.
Sep 22, 2011 | Universal Remote Control URC-6131N Remote...
I have a one for all universal remote model number URC 4330B01 and I need the code to program it to a Zenith tv
To program your Sony Universal Remote control for a Zenith TV try - one by one - the following numbers: 009, 010
Jun 04, 2010 | Televison & Video
I'd like to know if anybody has the code for the all fo one universal remote urc-4640boo to program to mitsubishi tv
Try the following codes for your Mitsubishi: 0093, 0150, 0178, 1250
I assume you already know the process of how to actually program your remote!
Nov 15, 2009 | One For All URC-4605 Remote Control
Hi i have a universal remote an no manual for it. One for all is the brand URC-3415 is the serial number I need code for Rowa tv
hi
here is the remote support site
http://www.oneforall.com/us_US/support
here is your model manual with rowa tv codes
http://www.oneforall.com/uploads/support/1dda578b9a124e8e63bebd935e52b49a.pdf
good luck
Nov 05, 2009 | One For All URC-3021 Remote Control
My controldosent work with the codes
I can help you with your URC-3220 Universal Remote Control issues.
The URC-3220 codes for Emerson TV's are: 0154, 0236, 0463, 0180, 0282, 0178, 0019, 0179, 0177, 0185, & 0623.
For complete instructions on entering the URC-3220 remote codes, please refer to my posted Fixya Tip One For All URC-3220 Code Entry.
If these don't help, try the One For All URC-3220 Code Search.
I hope that helps.
_______________________________________________
One For All URC-3220 Manual
One For All URC-3220 Code List
One For All URC-3220 Reassign Key
Oct 02, 2009 | RCA RCU300 Remote Control
One For All Zapper 1 URC-6010 Remote Control Logo
196 people viewed this question
Top One For All Televison & Video Experts
Electro Med Services...
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
