Question about Onkyo HTR500 Receiver
Hookup how 2 hook up my 15 band eq 2 my 7.1 HT_SR800
  • 86 Answers
If ur using it for cd player u take the Right Out an Left Out put it in to Eq Right In an Left IN An next to it there is Right Out Left Out an to the reciver you put Right In an Left In Do that with dvd,tape....
what ever it is your trying to hook up
Right is Red
Left is White
Posted on Oct 15, 2008
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
Could you use the Bose 901 series VI for a pa system?
Actually that's where the bose 800 systems came from.
Old school jazz guys were using their 900 series turned backwards as a pa
Mar 31, 2017 | Music
I have the Nitro BMWX 483 4 channel amp, BMWX 484 2channel amp , and I have the Nitro BMWX 424 4 band EQ !! Now what I'm trying to do is hook up both amps together to the EQ ! So far, I hav the BMWX...
From what I have read about this EQ it is just for subsonic frequencies. You really don't want to run your components through this EQ. Leave the components running off of the 4 channel amp and your sub box on the two channel with the EQ in series between your head unit and the sub amp.
Jun 30, 2011 | Nitro BMW-483 Car Amp
Equalizer doesn't turn on
hookup the remote wire of your EQ to that of the HU or just simply connect it to the positive line but it would make your EQ powered ON all the time. That remote wire of your EQ is to get a trigger signal from the HU so that it will turn the EQ "on".
Apr 20, 2009 | Power Acoustik PWM-19 4-Band Car Equalizer
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
EQ hookup????
Yes I do! I hade the same problem so went to radio shack and got tow Y -RCA splitters with one male and tow female works great!!
Dec 23, 2008 | Sony STR-DE545 Receiver
Onkyo HT-SR800 buzzing noise present then vanishes
The hum a fluorescent light makes is the 50 or 60 Hz hum of the alternating current mains supply. Inside the light fitting is a choke which when less than perfect tends to hum. When the choke is loose internally or externally is when the hum becomes an annoying buzz.
When an audio system has a similar tone of buzzing or humming the source will invariably be the same AC mains but how it got in there is difficult to answer...
It could possibly be poor smoothing and regulation of the power supply or an accidental hum loop caused by careless design and/or poor grounding. It could be caused by being induced in the input by connecting leads that are too long and poorly positioned/screened or it could be caused by mismatch between different components causing a poor signal-to-noise-ratio.
I am not sure why it should come and go but the fact it does would indicate a power supply problem more than the other possible causes.
If the Onkyo system has it's own volume control and it is being used witha tv or similar, it is worth trying to imporove things by turning up the tv volume to near maximum and then controlling the volume with the system control.
May 12, 2017 | Onkyo HT-SR800 System
Clarion eqs746
more info would be nice...
what did you hook it up to?
Mar 23, 2008 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Tivo HD will not record when Onkyo HT-SR800 is off
Do you want to run all your cables thru the receiver? There really is no benefit for you to do this since that receiver doesn't handle HDMI audio nor do any kind of component to HDMI conversion. Might as well connect your tivo box directly to the TV with HDMI. You'll have to switch inputs on your TV between the cable box, but its not a big deal.
Feb 20, 2008 | Onkyo HT-SR800 System
Onkyo HTR500 Receiver Logo
64 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
