I HAVE A TVIEW IN DASH DVD PLAYER MODEL DVD787TS I CAN NOT FIGURE OUT HOW TO SET THE RADIO STATIONS ON IT , IT IS MISSING THE REMOTE I SHOULD NOT HAVE TO HAVE THE REMOTE TO SET THE STATIONS SHOULD I?
If it is touch screen you should be able to tune to the frequency required and then press and hold on position 1-7 or wherever u want the station stored and it should store it i hope this helps
If radio has save button then tune your station push save button then push a number on preset you want it saved to. The radio automatticlly stores the strongest station in your area.
I would assume that this Jensen should store stations much like other cars. Find the radio station you want, press and Hold the button in until you hear the radio start again. Note- If you installed the radio your self and didn't hook up the power correct, the programed radio stations will be lost when the vehicle is shut off! Hope this helps!
You want to pick a frequency where there isn't an existing station, so the radio will have a clear signal from the dvd player.
If the DVD player only has a few frequencies to choose from, then tune the radio to each one (with the DVD player turned OFF) and see which one has the most static and the least signal from radio stations in your area.
If the DVD player can be set to any frequency, then just pick a frequency (usually down on the "88" side of the FM band) with the least local signal, then set your DVD player to use that frequency.
Does this make sense? Feel free to ask questions with the "add comment" link. If this solves it for you, please be sure to hit the "thumbs up" for me!
I just spoke to tech support. They said not being able to set the radio station to 96.1 is a PCA hardware problem. They asked me to get the product exchanged.
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
