Question about Dryers
My kenmore dryer turns on but wont stay on. I made sure the door was not loose and it was on the time dry. Can you tell me how to trouble shoot this? i press the button to start the dryer but as soon as i release the button it stops, i kept the button pushed in manually to see if i can dry my clothes but even with the button pushed in, and the dryer was running, it did not get hot. should i still check the board for burnt components or is thier a safety switch that will not let the dryer start?
  • tburd62 Dec 21, 2008
    The ON button turns the dryer on but as soon as I release it the dryer turns off. If i "play around with the other controls" it may work. That means it's not the start button. What else could I look at?
    Thanks,
    Ken
  • h_brooks_17 Mar 20, 2009
    my whirlpool dryer won't stay on all the time. If I turn it on, sometimes it will stay on for 15 mins...then shuts off. The have checked the door, it is not loose. Sometimes it stays on longer, sometimes a shorter amount of time. What is wrong?
  • Dryers Master
  • 19,396 Answers
Check all fuses and circuit breakers , if they are fine, then the problem is with the control timer.
See also the following website: What is wrong with your Dryer?
You can get replacements here.
Posted on Oct 15, 2008
My dryer door won't stay shut while drying
Dryers have a Door latch that is female and the strike that is male. When the door is closed, the door latch hooks up to the strike and keep the door closed. PLEASE inspect these items. Also, make sure that the door is loose from the screws that hold it to the body.
Dec 03, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Kenmore he5 dryer doesn't run, have power, door switch works, thermal fuse, have continuity?
What does the display say? Typically, these Kenmore dryers don't run because of a door latch error. We have had to have our door latch replace 3 times in 3 years. There is a lengthy trouble shooting program to bypass the latch error but it is time consuming.
Oct 15, 2014 | Kenmore Dryers
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
I have a Kenmore 500 model # 110.68532700, sometimes it would work and run for about ten minutes then shut off, after about 10-15 mins you could run it again, sometime it would run fine tell the clothes...
see this possibles causes:
see the diagram attached
1) Test the main start switch for open 2) Test the switch door for open 3) Test any coonector for loose wires, or broken wires, or burn .4) Motor defective repair
Jun 09, 2012 | Kenmore 500 6952 Dryer
700 dryer wont shut off automatically
If it will not turn off on the Timed Dry cycle the failure is in the timer. The timer is the component behind the large knob on the console. If you supply me with the full model number from the front panel inside the door, I can get you a part number and approximate price of the part.
Apr 21, 2010 | Kenmore Dryers
Dryer won't start - how do I trouble-shoot to determine if its the switch or something more complicated?
First trouble shooting is to make sure you are getting 220 to the outlet not 110; We all know that on a 220 outlet there is 110 on each side and if you are not getting 110 from each side, the dryer motor won't turn on. If you are getting 220, then try manual start. Hold in on the door switch and push the start switch. If that don't work then it is the motor.
Nov 20, 2009 | Kenmore Dryers
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
If this is a problem that when you push the start button the unit runs, but as soon as you release the button the unit stops, then I have personally experienced this. It's a problem associated with the microcomputer board inside the control panel. You will need to unplug the dryer first. Then open the control panel and inspect the circuit board for burned components.
May 06, 2007 | Kenmore 64982 Electric Dryer
Dryers Logo
248 people viewed this question
Top Dryers Experts
