Question about Canon imagePROGRAF W6400 InkJet Printer
I have the canon w8400 and when i try to print it comes up error E0200D Size undetected. Pleas explain i have the same problem! it says ERROR EO2OOD. WTF?
Could be that the button for Sheet / Roll has been pressed. This is a popular error caused by the machine expecting a sheet when you are loading a roll. Make sure the light is located on the roll option rather than the sheet.
If this is the problem, you must first remove all media, then lower the covers and lower the media release lever before the printer will allow you to change between roll & sheet.
Posted on Dec 05, 2008
  • CPCEYE Jun 16, 2011
    Problem solved, saved a very expensive call out from cannon, Thanks
  • anton gnanam
    anton gnanam Oct 31, 2013
You have to tell the printer (Printers information panel) what paper/type, size, how long is roll exc. And when you print you have to choose exatly same type, size, in your PC or Mac... (Some software which helps you: Problems to find right paper type? 1. Download canon media confirquration tool software. It´s usefull to update paper types in your printer. 2. Garo Device Agent Manager is good too because you can change settings: Paper, Colour, Cutting, Maintenance exc. with it, because it´s obtain information regurlarly to printer and it tell you, if you have a wrong paper type and you can change it right away.)
But main thing (job) that you have to do is, put paper information direct to printer information panel, because your main problem is that printer have different information than your PC. It´s little bit tricky to put information direct to printer, but when you get the idea it is simple...Don´t forget put your printer "No, Online" (No green light on) I´m sorry, about my english, and i hope you get what i mean.
Posted on Nov 03, 2008
What does Error Code E02813 mean for a Canon W8400 printer please
How can i do with the error code E02813 on canon machine W8400
Dec 22, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Error code E0200D Have powered off and on says size undetected - any suggestions
danieljudge Thank you!!! You were right! Problem solved. I managed to see that was the problem but didn't know how to change the sheet with the roll. Thanks again!!
Nov 24, 2010 | Canon imagePROGRAF W6400 InkJet Printer
ERRORE E0200D plotter canon W7200
Hi. I have a problem printing the bar code symbol is similar to
Oct 07, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Canon W8400 printing.
Hi Did you get an answer I have the same problem.
Tony
May 24, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Canon W8400 no Y ink tank
i have the same problem with PM tank (error code E0250A). tried three! new ink tanks and nothing. the empty one is fine...
Sep 14, 2009 | Canon imagePROGRAF W8400 InkJet Printer
I have a error code eo2820 after adv adj failed on my w8400
it's a problem that the sensors can read adn adjust the print head.
1.st print a nozzle check to see if the print head is OK
2.nd check if the paper is suitable for this kind of printer,sometimes it's not enough to use pigment materials but the correct materials.
3.rd clean carefully the sensor that reads the print-out
try and let us know the results
Aug 27, 2009 | Canon imagePROGRAF W8400 InkJet Printer
Canon prograf w8400
GO ONLINE AND TYPE THE FOLLOWING:
CANON IMAGEPROGRAF W8400 INKJET PRINTING 2 INCH BLACK LINE
ENTER
SEE IF ANYONE ELSE HAVING THIS PROBLEM BEFORE, GET SOME HELP OR IDEAS ON HOW TO FIX IT
GO ON LINE TO
WWW.CANONUSA.COM/IMAGEPROGRAF
ENTER
ROD
Feb 10, 2009 | Canon imagePROGRAF W8400 InkJet Printer
Error E02530 on Canon W8400 PG
Hello
when i load a material in printer, it shows me this error E0200B (size undetected) i loaded another photo papers and photo rolls but it steel show me the same error.
what should i do to solve this problem ?
thank you
Oct 27, 2008 | Canon imagePROGRAF W8400 InkJet Printer
Open Questions:
See all Canon imagePROGRAF W6400 InkJet Printer Questions
Canon imagePROGRAF W6400 InkJet Printer Logo
1,125 people viewed this question
old marine
old marine
