Question about Brother IntelliFAX 2800 Laser Fax
Print in light
We have changed the toner, but the fax still prints very light.
  • 2 more comments
  • Anonymous Oct 23, 2008
    Copies very light - I have a new toner and a fairly new drum. I have tried to change resolution as described in manual and copies are still too light to read easily - how do I fix this?
  • Phylmar Nov 13, 2008
    I just changed the toner and the print is still very light.
  • ccope49 Jan 23, 2009
    Have tried all these suggestions including change toner and drum and print is still VERY light! also, have a completel blank strip down the right side of the copy and/or fax. Is there some sort of kit I can buy to possibly change out certain parts (rollers, etc) that could be causing this?
  • Anonymous Feb 23, 2009
    Same issue - new toner and prints fine right down the middle but both the right and left side are super light.
  • 4 Answers
1. Check TONER SAVE setting. If this setting is programmed "ON", all
printed documents will be light.
a. Press MENU/SET, 1 (General Setup), then 6 (Toner Save).
b. Press the top or bottom navigation key (keys located above and below
the MENU/SET key) until the display reads "Toner Save: OFF".
c. Press MENU/SET.
d. Press STOP/EXIT.
2. Check the PRINT DENSITY setting. This setting allows you to adjust
the print density from light to dark.
a. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 6 (Print Density).
b. Press the up navigation key (key above MENU/SET) to make print
darkeror the down navigation key (key below MENU/SET) to make print
lighter.
c. Press MENU/SET.
d. Press STOP/EXIT.
Posted on Dec 02, 2008
Fax machine print light
When you see light print it can be from a few things. This is basically a laser printer with a fax machine so the same problems exist in both. The most common cause by far is simply low toner. If you take out the toner cartidge and gentl shake it side to side then put it back in. Now try printing again. This should be much darker. This may only last a few dozen pages (but can go a quite a bit more if you are lucky) but it shows you that you need to get a new toner cartridge. The other causes can be a image setting in the fax. In the control panel it will show you a setting for how dark it will print. Normally it is in the middle of the range. The last common thing is a fusor wire. This normally shows up as a error first but it can slowly fail. The fusor is the heater that bonds the toner to the paper. If it doesn't get hot enough then not all the toner sticks and you get light printing.
Normally the problem is low toner.
Jan 10, 2012 | Panasonic KX-FL511 Plain Paper Laser Fax
Printing black on paper
Some of these machines will allow you to printe a grey scale test copy.
This will readjust the fax machine back to a nominal mode.
Not knowing how old or how long the machine has been serviced, background can be caused by dirty optics somewhere in the machine.
A remanufactured drum unit can cause this type of problem, (defective unit)
Competitive toner in the toner unit can cause poor copy quality.
Reinstall the old cartrige and see if the problem changes.
Not knowing if the machine has a seperate drum unit and developer housing, it would be hard to answer anything else.
Oct 15, 2009 | Brother IntelliFAX 4100 Laser Fax
I have a Brother mfc-8440. It prints light on the
Usually when it prints light on one side and normal on the other, it's either the drum (which you replaced) a dirty corona wire, or the toner is unevenly distributed in the cartridge. You can removed the toner cartridge and gently drop it from a distance of about 4-5 inches to dislodge any caked up toner. This is normal in a cartridge that has sat a while or if the fax machine is in a room with high humidity.
Hope this answers your question and best of luck.
Greg
Aug 02, 2009 | Office Equipment & Supplies
When it prints it comes out very faint
remove the toner . look in on the left hand side where it goes you should see to half loops springs. these might be dirty or bent . this is what gives the toner the charge, if you want to clean them go ahead, if you want to bend them turn the power off first those are high voltage pins.
Jan 21, 2009 | Panasonic Panafax UF-890 Plain Paper Laser...
Light fax
This could be a couple of different things. The first is that you are running out of ink or toner. Or you could have your toner save turned on. You can conserve toner using this feature.
When you set Toner Save to On, print
appears lighter. The default setting is Off.
1 Press Menu/Set, 1, 6, 1.
2 Press ▲ or ▼ to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
Jan 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Received fax in memory but not printing
I just checked this out as I had the same problem. It seems that the machine is programmed to stop printing faxes when the Toner is "out". Even though the toner is not completely out. I was positive that the note on the screen was false since I could print out documents and copies (I am not using Samsung original Toner). But the fax will refuse to print.  I fixed this by changing the toner (again with a non-Samsung toner) and it is printing all the faxes in memory.  It is stupid that they haven't set up a menu item to force it to print all the faxes in memory but voila, that seems to be the fix. I guess this is a way for them to control that we only use Samsung toner.
Dec 12, 2008 | Samsung SCX 4521F All-In-One Laser Printer
UF 585 problems with changing the toner
You have to clear all memory jobs this is how is it done
This function will put you in service mode
Fuction
7
monitor key slowly 4 times
6
scroll down to ALL JOB CLEAR
set or start
Hope it works for you for more information you can visit Innovative Copy Products Support Panasonic
Nov 18, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Printing Faxes
try another drum unit.
Jul 02, 2008 | Brother MFC-8220 Fax
Light copies
You may have your machine set to print in "toner save" mode. Check your machine settings by printing a list. Also, some generic toner cartridges have too much polymer in the mix and will print light copies. If you change back to OEM toner, you may have to change the drum too, as the extra polymer stays in the drum unit and weakens the mix.
Jun 04, 2008 | Brother IntelliFAX 2800 Laser Fax
Lines printing out on faxes
white or black lines? what kind of machine? does it have lines when sending?
Nov 29, 2007 | Office Equipment & Supplies
Brother IntelliFAX 2800 Laser Fax Logo
412 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
