Scanning was cancelled by user or terminated abnormally Lexmark X73
Hi, I was speaking with Jay to get help to solve my HPScanjet G4050 problem. He asked me to download a program called Crossloop so that he could access my computer and help me with the problem. After downloading the program, I lost him. I would like a refund of the $14.95 (or $14.99, I'm not sure which) back to my credit card. My email address is MaryMThomas. I was on the internet live with him around 10:00 or thereabouts today, October 14,2008. My nickname that I gave was MLMT1. I don't have the print out of the charges or the number. I assume that I was going to get that when he fixed the problem for me, although my charge was upfront before I got to talk with him. My home phone is 336-723-8563. Please call lme or email me at MaryMThomas@triad.rr.com and tell me that this charge has been removed. I have called the credit card company to stop payment on this account, but they wanted me to contact you first. Thank you. Mary Thomas
Posted on Oct 15, 2008
Lexmark X73 Printing Problem
When you say that your all-in-one system will copy, but will not print from the computer, this tells me that there could be a connection problem between the printer and the computer. This is more then likely a driver problem. you will need to go to lexmark and download the latest drivers for your operating system.
But this could also be a broken or loose cable.
Apr 15, 2010 | Lexmark X73 All-In-One InkJet Printer
Artcopy 55?
To resolve this error, complete steps A and B below. Step A:
  1. Open Windows Explorer.
  2. Go to C:\Program Files\LexmarkX73.
  3. Delete the Artcopy55.jac file.
  4. Open the Scan & Copy Control Program. (Go to Start, Programs, Lexmark X73, Scan & Copy Control Program.)
    The file will be rewritten with the latest settings.
Step B:
  2. Go to C:\Windows\Twain_32.
  3. Delete all folders except for the Lexmark folder.
  4. Reboot the computer.
Note: If completing the above procedure doesn't resolve the problem, JETSOFT recommend reinstalling Windows XP as a solution. (JETSOFT is the company that developed the Scan & Copy Control Program.)
Apr 10, 2009 | Lexmark X73 All-In-One InkJet Printer
I have a lexmark x73 i'been instaling so manytimes on order to make the scaner to work but nothing I would apreciatte if you can give me some tips or help thanks
The all in one solution software you used in XP doesn't work fully with Vista.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Lexmark X73) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | Lexmark X73 All-In-One InkJet Printer
Scanner was terminated abnormally & will not scan now, please help
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Lexmark X73 All-In-One InkJet Printer
Trouble scanning without pc
Using the operator panel:
  1. Turn the printer on.
  2. Open the top cover.
  3. Place the document face down in the lower right corner.
  4. Close the top cover.
  5. Press the Color or the Black copy button as required.
Using the computer:
  1. Make sure the printer and your computer are turned on.
  3. Place the document face down on the scanner bed in the lower right corner.
  5. Click Start, Programs, Lexmark Xx3, Scan & Copy Control Program.
  6. Select the number of copies.
  7. Click the option that matches the desired color of the copy.
  8. Click the Copy button.
To customize the copy settings:
  1. Click Start, Settings, Lexmark Xx3, Scan & Copy Control Program.
  2. Click File and then Setup.
  3. Select the Copy/Fax tab.
  4. Customize your settings as required.
  5. Select OK to start copying
Apr 04, 2008 | Lexmark X73 All-In-One InkJet Printer
The included X73 OCR has disappeared
When you install software install in another location ( do not install in program files as normally ) let me know if u got help!
Mar 24, 2008 | Lexmark X73 All-In-One InkJet Printer
Scanner will not scan
Set this options un der Control panel Scanner and camera. If fails try this, Uninstall everything HP Installed. Unplug the scanner. Then reboot. THen install the drivers and applications. Then reboot. then insert the HP scanner into the USB.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
Lost the CD
If you go to the US website, then it will scan your system for a printer then install driver http://www.lexmark.com/lexmark/site/home/0,6932,204816596,00.html Otherwise you can download the driver here http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=227:5:0:94:0:0&emeaframe=&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&&req=:::::
Mar 03, 2007 | Lexmark X73 All-In-One InkJet Printer
My 4 in 1 wont scan but does print
Before we give up on the scanning/copying ability of your machine. Try unplugging the machine from the wall and from the computer for at least a couple minutes. If that doesn't work, You may also check for a factory reset switch or reset mode you can choose. http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Drivers&ccs=229:1:0:94:0:0&os_group=WinXP&searchLang=en Last but not least. Uninstall the printer again, unplug it from the wall and computer. Make sure you restart the machine and even shut it down before trying to reinstall the drivers. The above site has a patch for the scanner. Not sure if its what may be ailing yours. Let me know what happens. Good Luck, Tim
Mar 01, 2007 | Lexmark X73 All-In-One InkJet Printer
75 people viewed this question
jasbo
jasbo
