Question about Motorola Walkie Talkies 2-Way Radio
I bought walkie talkies with 56 km radius and yet we are lucky to reach each other after approx. 1 mile,any idea why we don't get the range
  • Motorola Master
  • 1,655 Answers
You do not mention the particular model of Motorola, so this answer will be generic in nature. Some Motorola TalkAbout radios have been factory programmed with a few GMRS repeater frequencies. These channels require the use of a repeater tower, which will 'repeat' what you say over a greater distance. It is possible you have this type of radio. Check your user guide, and then set your radio to the appropriate channel for the repeater in your area.
Radio-to-radio without the use of a repeater you can expect up to 2 miles line-of-sight out of most handheld radios. This distance is reduced by obstacles such as buildings, trees, etc. inbetween the radios. It can also be reduced if you do not hold the antenna of the radio perpendicular to the ground.
Best regards.
Posted on Jan 19, 2012
  • Mark Long
    Mark Long Jun 21, 2014
    These models are based on a 3-watt input into the antenna system and both radios are within line of site within each other. Real world conditions make them more like 1 to 5 mile range. Let me put it this way, I operate a large rec facility with a repeater. The facility is in a mountainous region and a mountain separates our areas of activity. If you switch the radios to simplex, you only communicate with the people on your side of the mountain. With the repeater on, you can be at the bottom of one hill and talk to people at the bottom of the hill on the other side of the mountain and also our staff in town 30 miles away.
  • eradiostore
    eradiostore Jun 26, 2014
    Mark, What you describe would be entirely correct. Simplex radio-to-radio without the aid of a repeater is basically line-of-sight from one radio to another. Typically radios will get up to two miles line-of-sight. In mountainous conditions you will only be able to communicate where the radios could potentially see one another. The repeater which you say you can talk on both sides of the mountain must have an antenna positioned on top of the mountain. Using this repeater your radios would be talking line-of-sight from the repeater's antenna. The repeater would have a certain footprint of coverage.
SOURCE:
Use a audiovox walkie talkie
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
Oct 14, 2014 | Radio Communications
What is the range of the uniden black walkie talkie gmrs 520
  • Pair of GMRS/FRS 2-way radios for person-to-person communication while hiking, skiing, and more
  • 22 channels (8 GMRS and 14 FRS); wireless range of up to 2 miles
  • Auto squelch function shuts off weak transmissions and unwanted noise at range limit
  • Single call alert tone; automatic power save circuit extends battery life; includes 2 belt clips
  • Each radio runs for up to 48 hours on 3 AAA batteries (not included); 1-year warranty
May 30, 2014 | Uniden Black Walkie Talkie Gmrs 520
Uniden walkie talkie
What is the condition of the batteries? Try it with new ones and if you still have this issue, you need special equipment to test the output and sensitivity of the transcievers.
Mar 14, 2014 | Radio Communications
Motorola T8550R
Not all Motorola FRS radio models use the same designations for a give frequency or tone. You may have trouble talking with models different from your own...
Apr 28, 2013 | Motorola Talkabout® T8500R Two Way Radio
Why doesn't my cobra walkie talkie won't work after 2 mile
If you are referring to FRS or GMRS type radios, 2 miles is just about the maximum distance you will get out of them on normal terrain. Many of these types of radios will advertise claims of 10-15 or more miles of coverage. This type of "theoretical" mileage rarely if ever occurs in typical conditions. Many factors such as trees, buildings, hills and other "line of sight" obstructions will greatly reduce the effective range.
Feb 20, 2012 | Radio Communications
We bought a 35 mile radius walkie talkie and i live about 5 miles from the other walkie and it doesnt even pick up static after driving about 1/2 mile away how can i fix this
  • That is the unfortunate advertisement game of these "bubble pack" two way radios. It is very misleading to say that this radio will TX/RX so many miles. It may go 10 miles in optimal conditions. Perhaps a big open lake or hilltop to hilltop. In dense suburban areas you may get 1 mile if you both are outside. Inside buildings a half mile is about it. They are great for camping and hiking trips but not for 30 miles for sure. The more expensive 2-Way radios will serve you far better and more realistically. The quality is better and the antennas are far superior.
Regards, Tony
Apr 26, 2011 | Motorola Walkie Talkie 2-Way Radio
Charging Problem
You can ask the seller you bought the walkie talkie from.
Sorry, I don't speak English very well.
Dec 25, 2008 | Cobra Radio Communications
50 to 100 mile range
Any sports store like Cabella's, Gander Mountain,
Read what it says on the package?
Nov 03, 2008 | Motorola Walkie Talkie 2-Way Radio
How do I make it work
It depends on the channels on the walkie talkies.
Can you supply the frz range of the TRC, and walkie talkies make and model and I will try and get the frez on the channels for you.
I can then tell if it will work or not.
Apr 27, 2008 | Computers & Internet
Motorola Walkie Talkies 2-Way Radio Logo
317 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
