Question about HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315, scanner and Mac os
Hello, I have an HP Psc 1315 all in one printer and a Mac os. How can i scan a document? I have tried thru iphoto, and adobe reader, but i really cannot find how to scan?Thanks for helping!
  • 9 more comments
  • Anonymous Oct 18, 2008
    i have the same issue.  i was looking around on the hp website and found that mac os x is incompatible with 1310 series scanners, but everything else should work.  is the hp psc 1315 considered a 1310 series?
  • Anonymous Nov 10, 2008
    I have the same problem-have you found any solutions yet?
    sargej47@gmail.com
  • Anonymous Nov 16, 2008
    Inwant to have a free download for the scanner of
    my hp psc 1315 all-in-one
  • Anonymous Nov 26, 2008
    scanner not recognised on the computer
  • foreignaxcel Nov 27, 2008
    I own a mac and an HP 1315xi printer/scanner. I have not been able to scan anything. For some reason my Mac can find the printer and use it to print, but when I try to scan a document even the HP software cannot locate my printer/scanner.
  • ebrook Dec 04, 2008
    I have a 1310 all in one printer and my Mac OS does not recognise the scanner...
  • Anonymous Dec 13, 2008
    DRIVER HP1315
  • Anonymous Dec 26, 2008
    i also have the same problem,, how it can be solved?
  • Anonymous Feb 10, 2009
    Same here and the sotware indicated on this tread only works for Mac OS X 10.3 or 10.4, but I own Mac OS X 10.5....
    I have an HP a6200n with Vista and an hp psc 1315. I just want instructions on scanning proceedures. I hit the scan button. It scanned the document. I have no idea where it went or how to retrive it or save it to a file. I went here hoping to find the instruction manuel on line.
  • Anonymous Feb 20, 2009
    When I open the HP Device Manager it says: Error, scanner cannot be initialized. And I cannot scan at all.
To scan documents on Mac OS X using your HP PSC 1315, you need to download HP's "Device Manager" software which is available here : http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-41992-1&lc=en&dlc=en&cc=us&product=374572&os=219&lang=en
I just installed the software and am now scanning problem-free.
Posted on Dec 11, 2008
  • user425 Jan 30, 2011
    I had a similar problem using the HP PSC 1210 all-in-one. It would print after installing Mac OS 10.6.3 but I couldn't scan. - found the answer here:http://h10025.www1.hp.com/ewfrf/wc/docum...
  • kelly918
    kelly918 Jul 30, 2012
    this link helped me with my 1310 scanner/printer on 10.6.8 July 2012. Scan Pro now works with snow leopard. Thank You!
HP PSC 1315 Does Not Scan under Mac OSX 10.6.3 Snow Leopard. It's been a very long time since the release of Snow Leopard, so the Retardos at HP should really come up with a real and definitive solution to their hardware. HP products will definetly Not be a part in my future Purchase List.
Posted on Apr 25, 2010
You didn't say what version of Mac OS X you're using. The Device Manager solution works up to Version 10.4. However, for Version 10.5, you're out of luck, according to HP. It says it does not support the PSC 1310 series (including the 1315) as well as several other lines:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01234231&lc=en&dlc=en&cc=us&lang=en&softwareitem=mp-41992-1&os=219&product=374572#
Posted on Nov 24, 2009
Vue scan. http://www.hamrick.com/vsm.html. It's not free but it really works.
Posted on May 04, 2009
I can print out documents but can be scanning documents
Posted on Oct 02, 2009
I have an older hp 4500 all in one printer running with mac mavericks 10.9.5. Start printer. My system for scanning was to go to system preferences on computer. Click printers and scanners. Once screen comes up click on scan, open scanner, choose scan mode, flatbed or docs. Now type in paper size, usually 8.5 X11 inches. now to scan to mail, put format to pdf or jpeg to iPhoto. open mail or iPhoto screen and minimize. Now push scan at bottom of screen. Once scanned, maximize mail or iPhoto screen. This might work for other hp printers. This is not as easy as pushing scan button on printer but it does work.
Posted on Jan 05, 2015
    Problem Solver:
  • 7 Answers
've managed to get the scanning to work on Mavericks! Basically my all-in-one printer is the psc 1315 and the procedure requires installing SANE and HPLIP
http://wiki.nosdigitais.teia.org.br/Mac#Using_old_scanners_and_printers_through_SANE
Posted on May 23, 2014
The method explained below (in French) has worked for me:
http://www.smy.fr/apple/scanner-snow-leopard-10-6-imprimantes-hp-tout-en-un_205.html
I have a MacBook (with OS X 10.6.8) and a HP PSC 1315s scanner, and after following the instructions in the sixth paragraph (on the page above), the scanner function is now working again. (The idea -- if I understand it correctly -- seems to be to have the most recent version of the HP drivers installed, but then to overwrite certain parts with an older version.)
Posted on Sep 17, 2013
Driver pour installer hp psc 1315
Posted on Oct 29, 2008
Scanning is not supported for MAC X Sorry
Posted on Oct 28, 2008
Http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-41992-1&lc=en&dlc=en&cc=nl&lang=en&os=219&product=374575
hp scan software of the HP site!!
Posted on Oct 16, 2008
If you go onto hp you can download the install drivers. I only just did that today. I have a mac osx v 10.5.5 and a hp 1315 all-in-one. you can download the software for it, the only problem is that its not in english. If you do download it, just play around with the software until you have a general idea of what to press. When you download the software you can find the scanning utility and when its stopped scanning you just click and drag your file onto your  desktop.
Posted on Nov 09, 2008
Cannot find my HP psc 1315 printer using mac os x maverick
I've managed to get the scanning to work on Mavericks! Basically my all-in-one printer is the psc 1315 and the procedure requires installing SANE and HPLIP
It is not a very simple procedure, but is the only free solution that I know and works well.
Dec 23, 2013 | HP PSC 1315 All-In-One InkJet Printer
I have a HP Psc 1315 printer all-in-one, the scanner is not active, How make I the scanner working in my MAC
Totally depends on your version of Mac OS X. From the Apple menu, pick "About This Mac" and tell me what version it says
Nov 01, 2013 | HP PSC 1315 All-In-One InkJet Printer
I cannot get it to scan a document and allow me to edit information on the document.
To edit information on a scanned document you must use a OCR (Optical character recognition) software. This will make the scanned document into a word file, and thus allowing you to edit it. Most OCR software are expensive unless one was provided with the printer.
Also, if you are scanning in as a PDF, most of the time you will not be able to edit it due to limitations with software. Most computers only have PDF Reader, unless you specifically purchased Adobe Acrobat full version (retail price $300)
Mar 19, 2011 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 ALL IN ONE. HOW DO I CREATE A MULTI-PAGE PDF DOCUMENT. I HAVE A MAC. I DONT HAVE ADOBE. I CANT SEEM TO DOWNLOAD IT. I HAVE FIGURED OUT HOW TO SCAN AN IMAGE AND SAVE IT AS PDF...BUT I...
The HP support website doesn't specify that you would be able to do that. Normally, in the scanning preferences from where you scan/preview the document, you would have a radio button to tick for multiple pages.
Alternatively, you can use this site to combine your PDF files into a single one: http://www.mergepdf.net/ Simple click Pick PDF, select your files and then click Merge PDF, when it will finnish you can download the file.
Dec 02, 2010 | HP PSC 1315 All-in-One Printer
How to get instrucyion manual for hp psc 1315 all in one printer/scanner/copier
You can download and print the instruction manual in PDF format from HP PSC 1315 support website by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 13, 2010 | HP PSC 1315 All-In-One InkJet Printer
How to scan a document in pdf format from hp psc 1315
  1. Position the first page of your document on the flatbed scanner and close the lid.
  2. Step 2 In Adobe Acrobat, under the File menu, choose "Create PDF", then "From Scanner" and then "Custom Scan."
  3. Step 3 In the Scan dialog box, choose your configuration settings. This will vary based on the nature of the document you wish to scan (e.g. color or black & white, images or text).
  4. Step 4 Click "Scan."
  5. Step 5 When the scanning process is complete, Acrobat will ask you if you wish to scan more pages into the file. If you do, position the next page on the flatbed scanner and click "Scan More Pages." Otherwise, click "Scan Is Complete."
  6. Step 6 Repeat the above steps as necessary to scan a multi-page document.
May 30, 2010 | HP PSC 1315 All-in-One Printer
Pc locks up after using scan on hp director
Uninstall all of the all-in-one software. Go to www.hp.com and search for your model and download (free) the latest software and reinstall.
Jun 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
33,144 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
