Need semi-conductor parts for Proview TV/monitor
This TV/monitor combo is dead. I need source for two identical semi-conductors ( I think they're MOSFETS ). The markings on these devises are 40P03-20. Please help.
  • santanag9 Oct 15, 2008
    I dont know how to take off the base of my westinghouse lcd tv, to just hang it into the wall.
I need to know how to take off the base of my westinghouse flat screen. (42") That way I can hang it into the wall.
Posted on Oct 15, 2008
    I dont understand what your saying, can you explain it to me with a bit more details.
Need a circuit diagram for a Ryobi BCL14181H charger to try and identify a burned out resistor
I just removed and measured mine, it is reading 148ohms. Assuming a 5% tolerance, i'd say it's a 150ohm resistor. Mine has just gone but it's the semi conductor adjacent to that. If you can read the identity mark on top, would be greatly appreciated.
Dec 05, 2015 | Drills
Semi conductor electric cooler
These people have a similar fan motor.
http://www.appliancepartspros.com/search.aspx?model=dts%20181%20cr%20dr%20ww
some semi conductor fridges use mains operated computer-type case fans.
Aug 06, 2015 | Furniture
Numark ttx1 blowing fuses
Fuses blow when there's an overload. Most are caused by a semi-conductor that has shorted. If it was the bridge you can test with an ohm meter. Connection across it's leads will be just like touching the test probes together. That goes for any of the semi-conductor devices.
Mar 06, 2014 | Audio Players & Recorders
Teac ls-l800 not working , think blown fuse
1 AT fuse is a 1 amp fuse.
Fuses tend to blow when there's an overload, mostly caused by a faulty semi-conductor perhaps on the main power amp board.
Apr 14, 2013 | Audio Players & Recorders
I cannot type in the channels on the remote anymore? I can scroll the channels??But I canot type in channel number. For example channel # 25 there is only 2 lines and it goes automatically to channel 15??...
your remote maybe dirty inside where the semi conductors are that designate what numbers you are ppushing. you can take it apart and clean it under the rubber. if that dont work get a new remote
Jan 30, 2011 | Samsung CXJ1364 13 in. TV/VCR Combo
MY FUSE KEEPS BLOWING OUT
If the fuse keeps blowing it's because some part is acting like it is a piece of wire. It will probably be a semi-conductor in the power supply of the turntable, or the transformer. They often look burnt or damaged the semi-conductors in this state.
Nov 19, 2010 | Vestax PDX-2000MKII PRO Turntable
I have prodipe powered monitor speakers. one of
It will be a semi-conductor that's causing the problem. All you need to do is get a can of Servisol Freezer Spray. Then when it's playing up spray any of the semi-conductors you suspect (one at a time) with it. If it's the faulty one it should start working. To confirm it, heat it up by touching a leg or pin (IC) with a hot soldering iron to get it to act up and spray again.
May 08, 2010 | Audio Players & Recorders
A small 2.5 amp fuse keeps blowing. It is located at the back of the unit just after the ac inlet
When a fuse blows suspect an overload in the power supply or power amp section.
For culprits in the power supply check the transformer, large capacitors, rectifier, voltage control semi-conductors, diodes.
In the amp section any semi-conductor on the heat-sink.
Semi-conductors - transistors and IC's are the biggest cause of fuse blowing. They become short-circuit acting like a piece of wire!
Because of this transistors and diodes are easy to spot with an Ohm Meter, as it will be like you have just touched the probes together.
Very often they have holes, or damage, or have burnt up with this kind of fault.
If it is a fault on the main amp section, check your speaker wiring as the + & - wires could have touched to cause it.
Apr 18, 2010 | Pioneer A509R Amplifier
I have a dx-lcd32-09 and it wont come on. the power light wont come on. i brought a new power cord, thinking it was that. nothing happened, i open it up and everything looked ok. could it be the fuse?
hi,
your are right,your fuse might not working anymore. Replace new one.If your monitor is still not working, probably there is defected semi conductor of your monitor. Approach technician near to you...I hope this may help,
best regards,
kaybicks
Feb 27, 2010 | Dynex DX-LCD19-09 19 in. LCD TV
Arnet A700C Box shut down - 14 volts leaving power board OK?
THERE ARE STEPS TO FOLLOW, TROUBLEING FAULTING, CONNECT A METER AVO AND SET IT ON AMPS IN SERIES WITH OUT PUT, OF A POWER SUPPLY, THIS SHOULD BE OPEN CIRCUIT, I MEAN CUT A POWER LINE INTO A LOAD. AFTER THAT START ISOLATING SEMI CONDUCTORS ONE BY ONE, SEMI CONDUCTORS ARE COMPONENTS LIKE, DIODES, IC AND TRANSISTORS. A FAULT WILL BE FOUND
Mar 27, 2009 | Televison & Video
Televison & Video Logo
281 people viewed this question
Top Televison & Video Experts
