Question about Panasonic SC-HT940 System
HT900 erro f61 i have a ht940 and i have the same f61 code popping up on start up and then immediatly shuts down. Has anyone gotten any response for how to fix or what i can do.
I kept hitting the disc exhange/eject button to turn the unit on and after a couple of tries it finally opened about half way. The whole reason i wanted to open it was to get the last dvd that i watch out of it. Well in doing so i noticed that there were some discs rattling around up underneath the cd tray (from my 1 1/2 year old). After shaking the unit a couple of times i was able to get the discs out of the underside of the disc tray. When i hit the disc exchange to close the try the unit powered up, closed the tray, and operated fine and i am back to using it like i used to with out any other problems.
Posted on Oct 20, 2008
Reading code f61
pop cover plug in with med to light pressure on the heat sink press down gently and push one way just a tad , press power , see how long to shut down. do same other direction. what you should find is that the solder connections are bad and need to be redone. this is not the first pan. that has had this problem, some of there other stereos do to.
Apr 21, 2014 | Panasonic SC-HT650 System
F-61 error
F61 IS A PROTECTION FAULT.POSSIBLY YOUR FAN OR AUDIO STAGE IS FAULTY
Jul 18, 2009 | Panasonic SC-HT940 System
F61 pops up as a error code on stereo
try starting out with volume low. And check to make sure no wires are touching I believe this is a circuit protection code
Jul 07, 2009 | Audio Players & Recorders
My sc-ht744 wont turn on just displays f61 and shuts down
Sounds like a short in the speaker wire or your polarity is incorrect ,black is negative and red is positive ,just double check theese before next step also the ic501 power module has been known to solve this problem if its not the wire,s because either of theese two failures will cause the error code too pop-up, Honestly this has been a problem with this unit and you are not alone , If the power module in the unit needs to be replaced ,call up customer service at panasonic and maybe your still under waranty where they,ll fix it for free !Thank you and hope I might have been able to help you in some way ,Sincerely Glenn
Jan 25, 2009 | Panasonic SC-HT900 System
F61 fault
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Jun 15, 2008 | Panasonic SC-HT940 System
F61
check the fan
If one fan dosent work it will show the error F61
May 15, 2008 | Panasonic SC-HT940 System
Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
F61 error
If memory serves me correctly, the F61 message is teh shorthand for protect mode. There is a problem with the output section that is being detected. The unit shuts down to prevent additional damage to either the amp section or the speakers. I'll look up your specific model for more details. In the meantime, check the speaker wires to be sure that they are not frayed and crossed.
Dan
Apr 08, 2008 | Audio Players & Recorders
HT900
My SA-HT900 with tower spekers works exceptionally well if you dont beat the hell out of it.
Oct 09, 2007 | Panasonic SC-HT900 System
Panasonic SC-HT940 System Logo
232 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
