Question about Milwaukee 6310 22 18 Volt 6 1/2 In. Circular Saw With Two Batteries, Charger And Case
18 volt milwaukee batteries
When i plug it in to the charger the red light comes on for a second then goes off. it should blink green but it doesnt anymore
    Problem Solver:
  • 15 Answers
You could try another battery if you have on(they only last for so many charges) or your charger could be bad. Try plugging it in to another outlet. Good Luck
Posted on Nov 18, 2008
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Why does cordless drill charger light blink off after 3 seconds?
It could be a defective battery or it might just be normal for the charger and it lets you know its charging. Look in the manual for the tool and it should tell you why it blinks and turns off. If you dont have the manual i'm sure you can look it up online.
Feb 02, 2012 | Coleman Powermate 18 Volt Cordless Sander,...
M28 battery is flashing green and red when put on v28 milwaukee charger
Is the battery hot or cold??? either temp. extreme will do that...
otherwise the battery is shorted internally and so the charger will not charge it...the battery will need to be replaced.
heatman101
May 21, 2011 | Milwaukee Tool Milwaukee V28 1/2" Hammer -...
Battery charger on a Worx Gt Trimmer Battery is blinking red what is the problem
Flashing red light indicates battery is bad. Flashing green light indicates charger is bad.
Feb 21, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
I have a jazzy power chair and when you turn it on all the lights come on for about 3 seconds then they go off and all you have is the red lights. we live in alaska so nobody around here to take it to
John Do the red lights blink or steady? this indication on the joystick usually means low batteries. Now this could be caused by bad batteries or a bad charger. On the jazzy if you have an on-board charger the light on the charger will come on green when the batteries are fully charged. If you can look under the rear of the chair you will see the charger and can tell if the light is green with the charger still plugged in after charging overnite. If the light is not lit then you probably have a bad charger. If you have a digital volt meter put it on dc volts 200 volt scale and plug the leads into the two outter charger port holes located under the front of the joystick. Your battery level should read 24-26 volts after charging all nite and with the charger plugged in up to 30 volts if there is no change in the voltage from charger plugged in and not plugged in then the charger is bad. You can then look to purchase an off-board charger that plugs into the joystick charger port to charge your batteries. If your battery readings are lower than 21 volts even after trying the new charger then you will have to replace the batteries. You might try to find someone in the local area that has an off-board charger you could borrow to see if you can get the batteries to charge. This will help you find out if the batteries need replacing. Hope this helps
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
When i plug my milwaukee power-plus 9.6-18 volt universal charger into a plugin the light on the charger will come on for a few seconds and then will go off not charging
sounds like the charger is shot- if underwarnty turn it in. an elctronics shop may can fix it. anyone else will probably tell you to replace it.
Aug 15, 2010 | Milwaukee Tool Saws
Milwaukee universal battery charger
check the voltage of the batteries before charging. Place on the charger and wait 1/2 hour or so, then recheck voltage. If it has not gone up, your charger is at fault.
Dec 18, 2008 | Milwaukee 6310 22 18 Volt 6 1/2 In....
Milwaukee 6310 22 18 Volt 6 1/2 In. Circular Saw With Two Batteries, Charger And Case Logo
728 people viewed this question
Top Milwaukee Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Jim London
Jim London
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
