Question about Onkyo HTR500 Receiver
Hookup I have a 15 band graphic equalizer and need to find out how 2 connect it 2 my 7.1 HT-SR800 home theater system
  • 2 more comments
  • 2loud4u Oct 15, 2008
    the eq is a geq 215 2 chanel,single rack 15-2/3rd octave bands each channel (Nady Audio)
    what part of manuel?
    where do i get this type of application
    cool thanks
    Sergeant:
    Champion:
  • 331 Answers
U will have to see which of ur connections of ur equalizer fit into ur home theater system ............
try reading the back panel or ur HT carefully and then..... try it
Posted on Oct 15, 2008
  • 51 Answers
• The front, center, surround, and surround back speakers
can be adjusted at 80 Hz, 250 Hz, 800 Hz,
2500 Hz, and 8000 Hz. The subwoofer can be adjusted
at 40 Hz, 80 Hz, and 160 Hz.
• While the Direct or Pure Audio listening mode is
selected, the equalizer settings have no effect.
• This procedure can also be performed on the AV
receiver by using its [SETUP], [ENTER], and arrow
buttons.
a special pin -plug is available for it in market, it could be connected to ur home-theater system..
It wii definitely work,try it........
    Genius:
  • 1,847 Answers
The simple approach is just to add an external stereo front left/right amp to the system and do not use the internal amp channels. Feeding the equalizer from the preouts will work OK as these are designed to feed amplfiers or similar devices (such as an equalilzer). I have used preouts to feed external amps for both left/right fronts, center, sub and rears.
    Genius:
  • 3,422 Answers
HI,
Please click on the below link to view the manual:
http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=HT-R500_E_C.pdf
    Scholar:
  • 74 Answers
It would help to know what equalizer you have, but I will assume it is a stereo analog unit. With the exception of the Tape In/Out connections on the back of the receiver there is really no provision for an equalizer. Even the Tape I/O connections are of little use if you can't monitor the source through the Tape In connections. Even if that were to work, it will not function for any digital sources you may have. You should be able to install this between an analog external source and the input to the receiver if you have one particular device you would like to tweak.
There are equalizer settings you can control within the receiver itself. You have the option of selecting the manual method for equalizer settings for each speaker or the default automatic method. Granted there are only 5 frequencies (3 for the sub) that you can adjust, but the fact that you can adjust each speaker separately is an advantage. The following was taken from the owner's manual:
buttons.
This is a very good receiver with some great features. If you have performed the Automatic Speaker Setup, you can go to the equalizer setting and select Off, Audyssey (automatic) or Manual.
Hope this helps.
  • Technosavy Oct 15, 2008
    Here is a link for the receiver manual, copy and paste into your browser:
    63.148.251.135/redirect_service.cfm?type=own_manuals&file=HT-SR800_En.pdf
When i press tuner to listen to the radio I can't ever get a radio station. It is always static, help please
There is an antenna connector at the back of your unit, try connecting any antenna, an old rabbit ear antenna from your old TV will work.
Jun 25, 2010 | Onkyo HT-SR800 System
Hookup diagram
easy.connect the dvd trough optical cable to the amplifier home theatre for surround sound and the video where it says DVD input and the sony cassete deck where it says cd in A/V the red cable wwhite and yellow,
Jan 20, 2010 | Onkyo HT-S790 System
Onkyo ht-557; picture dropped out, now just green screen
don´t you activate the progressive scan by mistake
Apr 23, 2009 | Onkyo HT-SR800 System
No sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
Jan 10, 2009 | Onkyo HT-SR800 System
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
Onkyo HT-SR800 the surround speakers are not blasting
I had the same problem and fixed it by manually setting the surround speakers changing the Level Cal to +12dB. You will immediately notice a significant increase in volume and may need to back down on the dB's. What a diffence it makes!
Sep 14, 2008 | Onkyo HT-SR800 System
Tivo HD will not record when Onkyo HT-SR800 is off
Do you want to run all your cables thru the receiver? There really is no benefit for you to do this since that receiver doesn't handle HDMI audio nor do any kind of component to HDMI conversion. Might as well connect your tivo box directly to the TV with HDMI. You'll have to switch inputs on your TV between the cable box, but its not a big deal.
Feb 20, 2008 | Onkyo HT-SR800 System
Onkyo HT- S790 installation manual
You can find manuals for Onkyo products here http://www.onkyousa.com/download/own_manuals.cfm
Jul 22, 2007 | Onkyo HT-S790 Home Theater System System
Onkyo HTR500 Receiver Logo
250 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
