Question about Home
Tub spout. Moen
Just bought a new tube spout to repalce my old one. The new spout same as the old, very common spout.. the inside of the spout has a (white) PVC threaded pipe in it with a smaller tube inside that as a O-ring in it.. I tried to unscrew annoying pipe but it wont budge.. and I dont want to ruin it incase I end up returning it. I think its just a reciver for a 1/2 inch copper pipe (which will fit).
Im calling Moen in the morning.
thanks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi handie Man,
I'm Harvey the Master Plumber.
Your problem is: Just bought a new tube spout to repalce my old one. The new spout same as the old, very common spout.. the inside of the spout has a (white) PVC threaded pipe in it with a smaller tube inside that as a O-ring in it.. You tried to unscrew annoying pipe but it wont budge.. and you dont want to ruin it incase you end up returning it. You think its just a reciver for a 1/2 inch copper pipe (which will fit).
That is exactly what it is. You've purchased a universal spout which requires a 1/2" copper pipe coming out of the wall. If you're not up to changing to that, take the old one to a plumbing supply. If you're lucky they might have a direct replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
Trying to replace a moen tub spout. Removed screw. Spout pulled out an inch and is now spinning around the pipe without coming off. Help! JoAnn
Some gorilla probably stripped the threads inside at the end. You may have to resort to a hacksaw do get it off but be careful to avoid damaging the threaded end of the stub.
Jan 23, 2018 | Moen Plumbing
How to install moen adler thread end nozzle with adaptor
I have encountered different threads in different spouts, both old and new work. Yours may have a thread that is different from the adapter.
Feb 12, 2017 | Moen Plumbing
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
Moen shower valves are failing
the diverter is stuck. you have to move it up and down to free it up. the diverter is the mechanism attached to the tub spout that switches the water from shower to tub. you may also need a new diverter if fiddling with it doesn't work.
Jan 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
When the shower valve is engaged I still get water out of the tub spout and limited water out of the shower head. I just replaced the cartridge thinking that might be the problem but no luck
it sound's like you need to replace the tub spout.there should be a set screw on the bottom of spout loosen and twist off. replace with moen spout for ease of re-install.it's a real pain in the *** to try and replace -o- ring spout.
Dec 05, 2009 | Moen & One Handle Tub & Shower Faucet
Moen Tub Filler Can't Remove Spout
It should lift off gently twist as you lift maybe tap spout lightly back and forth with a rubber mallet
Oct 14, 2009 | Moen Kingsley Two Handle Roman Tub Faucet...
Moen roman tub faucet on hot water side stops flowing and just trikles out
If this occurs after you were able to get hot water to flow from the hot side then I suspect that it is a piece of debriis that has found its way to block the port opening. Remove the acess panel to the valve shut the water supply off to the tub valve using the handles only first on the valve. With the access panel removed tak e a bucket or other similar container and remove the hot water tubing from the spout. Once that is accomplished stick the tube into the container and turn the hot lever on. This should blow out any debris that may exist. Reassemble the valvle. If this did not work remove both the cold and hot feed tubes from the spout and use an air compressor to blow the spout out. If neither of these worked you will probably need to call a serviceman to resolve as other options require cutting the hot supply to the handle and may require special tools that you may not have handy. Thanks for using Fix Ya.
Mar 03, 2009 | Moen Plumbing
Home Logo
455 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
