Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
How chang catrage
I dont know how replace the ink in brother ink jet printer ink c
On the front there is a cover, right hand side flip it down and you will see the four cartrdges in their.
Posted on Oct 17, 2008
Brother mfc 440cn
If your using anything other than brother ink it must be very compatible.
Generic ink will dry and clog the ink jets, I suggest you replace with brother cartridges and clean ,clean, clean. If problem exists you'll
have to get a ink syringe, some paper towels to place under the print head. Fill the syringe with hot! water and send just a little through each hole where the ink would go in from the cartridge. Be Very Careful not to inject to much justs enough to loosen the the dried ink and free the the jets. I take no responsibility if you get it wrong. I was able to correct the same problem with mine the same way and never used generic ink again. You can do it! and save on repair bills.
Jul 08, 2014 | Brother MFC 420CN All-In-One InkJet...
My Brother LC61, bought in Nov.2010, won't print black. Recently replaced black ink along with all color inks...replaced black ink again when it quit printing...still won't work. Machine whirs...
This is common problem with Brother Printers. I am going to assume you are using Non-Brother branded ink cartridges. Brother cartridges have a cleanser in the ink that most generic cartridges don't have. This in turn causes the jets to clog and not allow ink to pass through them. The fix is to go buy a couple of Brother cartridges and do a cleaning with those cartridges. You may spend some money doing this as a cleaning wastes a lot of ink, but it will clean the injection lines and fix the printer. You could also consider buying a new printer. I know this is not the answer you were looking for, but it is the true answer. I just bought a new printer due to this fact.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Brother Multi-Function Center MFC-240C...
Brother MFC-290c printer does not print black anymore. Test print page color ok but not black printing. What is the problem?
The problem is either:
* out of BLACK ink -- replace the ink-cartridge
* clogged ink-jets -- the ink is not spraying onto the paper, so run a few print-head-cleaning cycles
* dead electronics -- not triggering the jets to spray ink, so replace the printer
Feb 20, 2011 | Brother MFC-290C Multifunction Color...
Ran low on inks on my mfc-990cw and after replacing them now all show full levels but when printing black does not show. ZTried cleaning feature but did not help. Still no black
me too. Brother tech said bad printer head. cost of replacement (only when bad after one year and 3 month) the same value as a new printer.
so, I use it as scanner and telephone. but still not using the printer it comsume all the ink, so it asks you to put new ink in the printer..... waste of $$$$
Will trough it to the garbage!
Nov 13, 2010 | Brother MFC-990CW COLOR INK-JET MFC Ink...
Hp business ink jet 2800 printer carriage stall clear carriage obstruction press resume to continue
i get this message on my printer
carriage stall clear carriage obstraction
i change the prints head and the colours catrage and still have the same message
can u help me
Jun 30, 2010 | Office Equipment & Supplies
Dont' Know Where Printer Cartridges Go In Brother MFC Printer
Here is the manual:
MFC240c Manual
See page 93 for ink cartridge replacement.
Thanks for using Fixya.
Jun 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message on fax machine says change printer drum?
You need a toner cartridge which includes the drum. Go to a store like Staples, they will have what you need.
Jan 04, 2009 | Brother IntelliFAX 2600 Fax
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
