Question about Microwave Ovens
Kenmore microwave oven by LG
The Microwave works fine for 3 to 5 minutes the the power goes out. After about 15 minutes it resets its self and will work fine for a while as long as you don't cook over about 5 minutes.
  • vincent_jim Oct 20, 2008
    Thanks for responding
    We purchased the oven in 1999
    Last year we replaced the control panel
    I just tested the microwave and I can feel air coming out of the top when I heated a cup of water.
    It is probabley at the end of its life but I did not want to give up with out trying to get some help.
    is there a way to test the magnetron? How can I get at the magnetron to see if there is a build up of dust that might cause it to over heat?
    Thanks for any help you can provide
    Jim Vincent
  • William Miller
    William Miller May 11, 2010
    The magnetron is overheating, and (luckily) the thermostat is protecting it by cutting the power until it cools.
    This overheating can be caused by blocked air vents or a failed cooling fan, or it can happen when the magnetron is failing.
    Does it sound like the internal cooling fan is working? It;s the one that should be one whenever it microwaves, not the vent hood exhuast fan.
    How long have you had it? Is it still under the 1-year warranty or the even the magnetron warranty?
  • Microwave Ovens Master
  • 9,086 Answers
You can remove the grille and control panel and you may be able to see the magnetron. If not, the oven will have to come out of the wall and the cover will have to come off.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
There may be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here is a link you or someone you know can use to test the magnetron, but please read the safety info: http://www.gallawa.com/microtech/mag_test.html
Even though it passes these tests, it may still be bad. If the cooling fan is working, then it's the magnetron. That simple, I'm afraid.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
Posted on Oct 21, 2008
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
My microwave just stopped working. It was working fine.
you can check fuse inside ok or not.
High voltage diod and capacitor OK or not.
micro oven can hold a dangerous amount of electric charge (15000V) for 15-30 minutes even after unplug.
so be careful
go for professional technician.
Jan 29, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
Kenmore over the range microwave oven model 721.80413500 keypad just stopped working. No response when pressing any button, even the light and fan button. Microwave was working fine minutes before.
80% of power problems are caused by ceramic fuse locted under microwave cabnet.Use a tester to see if you have continuity.You may just need a fuse.
Jan 29, 2011 | Kenmore Microwave Ovens
Kitchenaids microwave error message F2.Q1. What to
F2.Q1 Not reading keypad
inputs
1. Unplug microwave oven or disconnect power.
2. Replace the user interface board (UIB).
3. Replace the door control assembly.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
Many of the error codes may be solved by power cycling: unplug microwave oven or
disconnect power. After one minute, plug in microwave oven or reconnect power.
i found this info on a tech sheet hope this helps, let me know how it goes... some of those electronics had 5 year parts warranty i would check that out....Also u might be better of buying a new one if its out of warranrty as some of those boards are expensive, obvioulsy unplug unit first try to reset it self.
Feb 14, 2010 | KitchenAid KHMS2050SSS Microwave Oven
Oven has been working fine. Heating a cup of coffee it just stopped dead. No display. Nothing. Power to outlet working fine. Is there a reset somewhere?
Mine did this when my wife had it on full power for over 10 minutes. We left it set for 15 or so minutes and it came back on. It did the same thing when my niece was heating a liquid with some metal in it. It eventually came back on. There must be a thermal circuit breaker inside the unit. Yours may have a fuse or some sort of circuit breaker inside it, that needs replacing or resetting. Then again some units have a fuse that goes out when the Magnetron shorts out, or goes bad. This would require replacing the Magnetron as well as the fuse.
Sep 12, 2009 | Sharp R-326FS 1100 Watts Microwave Oven
Microwave was ran for 5 minutes with nothin in it now no display
most have an internal fuse check it first if that is not it check the thermal fuse both parts run 10-15 dollars
Jun 30, 2009 | Maytag MMV4205 Microwave Oven
MY KENMORE 1000 WATT LITERALLY WORKED FINE ONE MINUTE THEN NOTHING THE NEXT. I HAVE NO IDEA WHAT HAPPENED.
Most likely the circuit breaker tripped or the fuse blew. A 1000 watt microwave is using 2/3 of the power available on a typical household circuit of 1500 watts. If anything else is plugged into that circuit u can have a problem. Just reset the breaker or replace the fuse and u will be up and running. if it happens alot you should consider a dedicated circuit for your microwave only.
Apr 21, 2009 | Kenmore 62622 Microwave Oven
Kenmore microwave 721 Displays 66:66 and beeps
Try first unplugging power cable for ten minutes, and see if it clears the error.
Oct 24, 2008 | Kenmore 63672 Convection/Microwave Oven
Help
Try to unplug the micowave and let it stay unplugged for 10 -15 minutes. Plug it back in after 10-15 mins and see if it resets the error message.
Jan 25, 2008 | Microwave Ovens
Microwave Ovens Logo
94 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
