Picture is cocave,top and bottom. - Televison & Video
If it is an RCA about 10 years old it is a pincushion IC which is no longer available and there is no generic replacement the last time I looked. Sorry
Posted on Oct 15, 2008
What is diferent betwin 1920*1080p and 1920*1080I
Television pictures are a series of still pictures that are presented quickly to give the illusion of continuous movement.
1080p and 1080i indicate how these pictures are formed.
1080p is progressive scan. It is a format that "paints" the picture left to right, top to bottom. On older tube type screens, this would cause the top of the picture to be dimmer than the bottom, as the phosphers would fade before the next picture was painted.
1080i is interlaced scan. This format paints every other line from top to bottom, and then paints the lines it missed before moving to the next picture. This evens out the brightness.
If your TV is capable of 1080p, it is considered to be the best picture (but you probably won't see the difference).
Feb 04, 2011 | Audio Players & Recorders
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
We have a widescreen plasma (Panasonic TY ST05-K). The picture all of the sudden shrunk to about 3/4 of the screen. Fortunately, the picture is not cut-off, so you can see the whole picture. The...
Hi there! If picture is smaller top to bottom with blank section on top and bottom then check your aspect ratio settings. If blank at the bottom only the Bottom Y-Drive board may be faulty. If blank at the top The Top Y-Drive may be faulty. If blank on the Left (TOP TO Bottom) then the Right X-Drive Board and on the Right, the Left X-Drive Board. May also be bad connections on the cables or flexible ribbon cables. Best Wishes and Good Luck, JUS004
Aug 23, 2009 | Televison & Video
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Curved picture at top and bottom
if it is bowing from top and bottom your looking at a convergance problem if you keep using your tv soon there will be no picture at all when the board crashes... convergance board needs to be replaced... hope this helps..
Apr 11, 2009 | Samsung HCN4727W 47" Rear Projection...
Picture has a swag at top and bottom of picture
hello it sound like convergance trouble can you access the menu and try and adjust the picture if that don't work it could be the convergance chips
shaun
Apr 08, 2009 | RCA Televison & Video
My NDS top screen's picture is on the bottom screen
You most likely put it in wrong. Take it off and try again, if it still doesn't work something has to be wrong with the screen you bought.
Oct 12, 2008 | Nintendo DS Console
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
