Question about Everex StepNote VA4103M Notebook
Everex 4103 I get 4 short beeps on this laptop can you give me a solution
  • Roonie Tunes
    Roonie Tunes May 11, 2010
    Ummm... I own an Everex 4103.... "when" do you get these short beeps? On start-up? Between applications? Please clarify
I have a everex stepnote nc1610 laptop when turn on gives 4 beeps then 2 more beeps
restart and HOLD the keys fn +f8 go section troubleshooting and proceed witht the steps mentioned in the section and fix it.
GOd bless you
Sep 25, 2013 | Everex StepNote Computers & Internet
Everex step note wont boot it beeps 3 times then once what dose that mean?
my compaq did that while i was in Iraq and i mailed it home and i think it was the hard drive but i think each company has like a code that they can tell
Feb 04, 2010 | Everex StepNote LM7WE Notebook
Problem with an Everex
this is hang-up on your Everex, check how many beeps you hear and we will identify the problem on your Everex 1500. See to it that your hear the Beeps on your Stepnote, good luck!
Jul 22, 2009 | Everex StepNote NC1500 Notebook
Wont boot but gives a 4-1-1 beep code
This is a memory error problem. Try rearanging the memory or just try one stick. For more information, look at this site:
(copy and paste in your address bar)
Jul 08, 2009 | Everex StepNote VA4103M Notebook
My everex 1502 wont power up just beeps and goes
this commonly occour when there are any complaints with the RAM module. try replacing them or unplug it and again reinsert it som times this can also be caused due o loose contact
May 14, 2009 | Everex StepNote NC1500 Notebook
Everex stepnote laptop starts up but does not run anything
Your memory module(RAM) has come loose of the DIMM slot(memory slot). Can also be due to oxidization of the RAM tips. I suggest that you open the back of your laptop , remove the RAM , rub its end(the end you plug into the slot) with and eraser and put it back into the slot. This will most likely resolve the issue.
Mar 31, 2009 | Everex StepNote VA4103M Notebook
2 short beeps at startup
Two beeps is an indication of a memory problem. Try re-seating the RAM, you may need to replace one or more of the memory modules.
Re-seating is the first thing to try.
Good luck with this.
Mar 24, 2009 | Everex StepNote NC1500 Notebook
Accessing system bios
EVEREX 2053T Laptop - BIOS SETUP UTILITY - use the DELETE key and it will give you access
Oct 28, 2008 | Everex StepNote SA2050T Notebook
Everex StepNote VA4103M Notebook Logo
103 people viewed this question
Top Everex Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
