Question about Haier HVR049BLW Wine Cooler
Haier HVR049BLW Wine Cellar runs too cold and has "LL" msg
My Haier wine cellar unit is a little over 12 months old and all of a sudden is going down to 34 degrees. I have the temp set locked at 55 and then tried 60 degrees. Regardless, it goes down to 34 and the inside starts forming frost on the back panel inside the unit. The temperature goes down and an "LL" message appears there. I only know of the inside temperature because I have another thermometer I put in there. Any suggestions? I would like to repair this but not sure where to start. Is it the thermastat?
Thanks
5 Suggested Answers
SOURCE: Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Posted on Sep 03, 2008
peyton32034
  • 410 Answers
SOURCE: Punched inside panel.
sounds like some one tried to defrost it with an knife. you can order the evaporator thru haier but unless you know how to do sealed system work you will need a qualifed refrigeration company to repair it for you if you provide the part approximate cost in the states is around 300-400 dollars. good luck peyton
Posted on Jan 29, 2009
Daniel S
  • 4323 Answers
SOURCE: I need to obtain an
Hi
Please post back with the model no so that I can provide you Manual for your Haier Wine Cellar.
Daniel
Posted on Dec 26, 2010
rleteo
  • 3 Answers
SOURCE: I have an Haier 8 bottle counter top wine cellar.
look down of the wine celllar and take off the plastic cap and clean the electrics contact. After that use use the 4 screwed support to give it the right inclination._400.jpg
Posted on Jan 03, 2011
imufo2
  • 3773 Answers
SOURCE: My Haier HVW18 Wine Cellar has a top fan which
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 27, 2011
How do i set the temperature on my haier model number hvdw20abb
Thanks for including the make and model number.
Without these, an answer is impossible.
Here is a link to the manual, which describes in detail how to adjust the temperature.
Haier HVF020A User Manual Wine Cooler Features And Use Initial Set Up...
If you found my answer helpful, please rate. Otherwise, feel free to ask for any further info if needed.
Oct 30, 2014 | Haier HVDW20ABB 20 Bottle Display Window...
My thermostat is reading 48 and I can't get it cool enough in my wine cellar to turn off the unit so that I can adjust the temperature up to 55. Is there a place that I can put some ice on to lower the...
IF THE CELLAR TEMPERATURE IS AS YOU SAY 48 DEGREES AND IF YOU ARE TURNING THE SCREW ADJUSTMENT ALL THE WAY TO THE WARMER SETTING COUNTER CLOCK WISE AND THE UNIT DOESNT SHUT OFF YOU HAVE A BAD THERMOSTAT AND NEED TO REPLACE IT
Aug 04, 2011 | Breezaire WK2200 (265 cu. ft.) Wine Cooler
My wine cellar won't start when plugged and switched on
My Kenmore mini refrigerator has the same problem. One of the capacitors on the control board is bulging its top.
Apr 23, 2011 | Haier HVW12A Wine Cooler
Cooling unit is running, but interior is not cool.
How long have you had this unit and did it quit suddenly or did it fail intermittently. Do you mean running where you can hear the fan and the light comes on when you open the wine cellar door? If so, I would suspect the starting relay failure on your cooler which should be very easy to replace. There should be a wiring diragram on the back of your unit somewhere and could be labeled (RT). Your compressor would be the last thing I would suspect.
Dec 05, 2010 | Vintage Keeper 500 Plus Wine Cellar
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Kitchenaid Wine Cellar-model # KUWS2246EBLO Power on switch does not turn on cooling compressor. Lite will come on.
Try tapping on the thermostat it is probably sticking.
If it comes on then you will need to replace the thermostat.
Check the start relay on the compressor.
Check the fan motor on the compressor is it running?
Clean lint from underneath on the condensing coil.
Mar 26, 2009 | KitchenAid 48-bottle Wine Cellar
Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Mar 01, 2009 | Refrigerators
Top indicator light is on (orange)
Get info here:
http://www.eurocave.com/wine-cellar/wine-cellar-cooling.htm
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
Haier HVR049BLW Wine Cooler Logo
112 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
