Re: your suggestion for my Dell Lattitude D600 Hard Drive Problem
Hi thank you for responding to my long posting about my current laptop issue. Based on what you suggested I had a few questions? You mentioned something about purchasing a 2nd computer (which luckily I recently purchased a 2nd laptop, I have a hp pavilion) and obtaining a few items; one being a laptop enclosure that could be hooked up to the 2nd computer and used to attempt to obtain vital data (which in my case is a hell of a lot of music and then also pictures) from the either crashing or possibly already crashed Dell D600.
Ok so where I am a little lost (ok a lot lost since I am by far no IT that would figure this out on my own) but currently the only thing that comes up when the Dell D600 is powered up is the black screen that states the "secondary hard driver 0 not found" and below that it says "a disc read error occured ctrl alt delete to restart" and then of course we can restart and either get the same message or hit either F2 for set up and run the diagnostic test that gave us the DST fail result or F12 Boot Menu which does show Primary Hard Drive 60GB.
Yesterday I download on to a cd the winxp restoration cd for D600 from my other laptop which is a hp pavilion but when I put that CD in the D600 the green light comes on like it wants to read it but then that goes away and nothing happens.
So again I am not sure how if the cd driver is not reading anything (I'm going to assume has something to do with that start up message "disc read error ctrl alt delete to restart") how even if I purchased that D600 restoration CD, that it would work or if i purchase that enclosure and hook it up to my hp pavilion in what way you mentioned, would that enable me to get something to come up on the d600 that might allow me to try and obtain any stored data from the hard drive.
Sorry that I'm not understanding better..your time and help is very much appreciated.
  • Heather
    Heather Oct 15, 2008
    Novelist:
  • 137 Answers
Ok, now we have some good discourse! While I'd always prefer to use a friend's laptop to test my fringe hypotheses, having your own is a fine option too. And it sounds like you have an enclosure too, so you are pretty much all set.
It's really sounding like the entire computer is having problems at boot. The drivers for the CD drive are built into the computer, so you don't have to worry about replacing them. That's how it can boot from a CD even before starting windows.
I think you are doing everything perfectly so far, so the question is how much more you want to do before selling it As-Is on Craigslist or claiming it lost in a terrorist attack to your home owners' insurance.
more choices though: if you want to keep fiddling with it, try these few suggestions.
If the green light goes on when you put the burned Windows CD into the drive there are a couple things that might be going on. If you can hear the drive start up and spin then stop then try again, then it sounds like either the CD is bad or the drive isn't working properly. Make sure the version of Windows you burned is a bootable version (full OEM or Restore CD and not an upgrade). Just a thought. Also, when you press F12 with the CD in the drive, does it show a boot from CD drive option? If so, I'm guessing that you try it, it spins the disk then nothing for a bit then the error message. If so, what's happening is that it's checking the CD for boot information, can't find it and then tries to boot "normally" which for it isn't.
If you ALWAYS see the 60GB Primary drive when you press F12, then the computer really believes that there is a drive there and maybe there are problems with the drive AND the CD rom.
The idea with the enclosure is that you can pull the hard drive from your D600 and put it in the enclosure to be read by your HP. This way, even if part of the drive isn't good - for instance it might be that the "boot sector" of the drive is corrupted - your HP should be able to read the rest and allow you to get back all your music and pictures.
Sheesh, don't be sorry about not understanding this all on the first pass. You're already doing a great job of diagnosing and repairing what you can. Get back to me after you've run yourself into another dead end. Good luck!!
Here are a few places to check out.
Dell's D600 Service Manual - to help you remove any tasty parts you need to (like the hard drive)
D600 Hard drive removal instructions - PDF format so get ready for download!
There's also a chance that you already have a Restore Partition on the existing hard drive. The problem being that your computer isn't reading the hard drive properly may make this a non-issue, but if you want, try this: BUT WARNING THIS WILL DESTROY ALL DATA ON THE HARD DRIVE so only do this AFTER you have removed all your important stuff from it by plugging it into your HP.
Taken from Dell's Technical Support page and should be followed from there:
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received.
Posted on Oct 15, 2008
Blue screen stop ox0000008e error in dell d600 and 1000-0146 error code
That error means you have a bad stick of RAM. Replace it and the issue will not reproduce.
Sep 20, 2010 | Dell Lattitude D600 W/XP Pr Notebook
Where is the hard drive located on the dell lattitude laptop
Take 2 screws out of the bottom of the laptop. The hard drive slides out of the side of the unit like the CD Drive would.
Jan 22, 2010 | Dell Lattitude D600 Notebook
I have a Dell C400. All of a sudden it won't boot. Can't even access BIOS. Display has nothing. Battery light keeps flashing from green to amber.
Remove the battery and the hard drive , use the charger and try to boot to BIOS. If it fails then the laptop is dead.
Jan 17, 2010 | Dell Lattitude D600 Notebook
Hard drive not seen in dell latitude d600 after upgrade to vista
Your hard drive may need reseating.
If it still gives error hard disk not found then you have a faulty hard drive.
You need a new hard drive and then install Windows Vista
Mar 23, 2009 | Dell Lattitude D600 Notebook
Hard drive location
http://support.dell.com/support/edocs/systems/latd600/sm/hdd.htm#1123687
Need a bios password on the hard drive for a dell lattitude 600
To reset Bios Password
  1. Turn your computer off.
  2. Unplug all the cables.
  3. Open the tower.
  4. On the System Board, you can find PSWD jumper placed in pins.
  5. Remove it and from pin 1 and 2, then put it in 2 and 3.
  6. Turn the computer on.
  7. turn off the computer and put the jumper back to the same pin.
  8. Start the computer and your BIOS password is reset.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 21, 2009 | Dell Lattitude D600 Notebook
D600 Power problem, Won't boot up
I agree. Try to turn on your computer using the ac adapter only. If the system won't hold power using the ac adapter. I suggest to call you computer manufacturer to check the warranty . I am seeing a problem with the motherboard.
Keep me posted.
Thanks.
Oct 19, 2008 | Dell Latitude D600 Notebook
Dell d600 latitude laptop
Hi
Dell Latitude D600 can only accommodate one internal hard drive. You can however install a 2nd Hard Drive as a drive module.
Check the picture below. The HDD Drive Module fits in in place of the CD/DVD Drive.
Let me know if further is needed.
Mike
Jun 07, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
634 people viewed this question
David Payne
David Payne
