Question about Microsoft Xbox 360 Console
TWO RED LIGHTS ON XBOX 360.
My xbox 360 will run for maybe 2-5 minutes max, then the fan gets really loud and the system cuts of. It does'nt cut off completely, but the two lights on the left side of the power button turn red.
  • 1 more comment
  • ICP_23 Mar 06, 2009
    Two red lights on the left side keep lighting up and i try to let it cool for like a hour and then go back to it and it lets me play for like 10 mins and then it does it again
  • xnmdenver86 Apr 09, 2009
    My X Box 360 is doing the same thing. This problem has been happening for over 3 months. I've let my X Box cool for over a week, and stillsame problem
  • Anonymous Apr 09, 2009
    MINE TOO. AFTER TURNING ON FOR 1ST TIME IT WILL DO IT AFTER 10MIN. I HAVE THE COOLER ON BACK SO I DONT THINK ITS OVERHEATING. SENDING UNIT IN TO HAVE FIXED OR REPLACED. LET U KNOW WHAT THEY SAY WAS PROBLEM.
I have the same problem they say to turn it off for the rest of the day let it cool down for like 5 hours and it will be fine the next day make sure it is not closed in and has air coming into the consol and you sould be fine
Posted on Mar 06, 2009
That means it overheating........
Posted on Oct 15, 2008
Xbox 360, when i turn it on 1 red light comes on, then when fan kicks in 2 red lights come on & it just cuts off
DO NOT OPEN THE CONSOLE!!!!!!!! Microsoft will fix it for free!
Alright, the one red light means it has a "Hardware Failure".
Since its 1 Red light it is known as the "e74 Error" Which lucky for you Microsoft will fix for free.
The 2 Red lights mean Your Xbox 360 is overheating.
Microsoft will fix it for free with free shipping. Takes about 2 weeks.
There is videos and different ways to fix it online but it will happen again with those half baked solutions and also with this Microsoft adds alot more time to your warranty.
Please go here to Send in your xbox
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
May 09, 2010 | Microsoft Xbox Console
3 rings of death turned to 2 rings. xbox 360 NEED SUGGESTIONS
you probably did something to where you messed up your xbox motherboard, making it (after less then a minute of power) get short circuited and power fails. i would recommend getting it repaired by microsoft if you have a warranty.
Dec 03, 2009 | Microsoft Xbox 360 Console
2 flashing red lights
Two flashing red lights means it has overheated. Maybee it does have alot of ventilation but the dust may have ecumulated to an amount that can not escape the system case. Clean it really well with a can of compressed air and make sure fan is running in the back. Some fans fail but continue to spin so if it looks to slow it probably is. You can watch you tubes tutorials about opening and cleaning your console. Hope this helps. Good Luck.
Nov 23, 2009 | Microsoft Xbox 360 Console
I just put a new case on my 360 and it has a clear pece that goes over the dvd drive so you can see the disc when i play for at leat 30 minuites the video cuts out the controoller continues vibrateing and...
left side, means thats your 2 red lights is your AV/HDMI cable not connected properly. 3 red lights is the ring of death. 4 red lights is the disk drive/laser has gone.
Aug 09, 2009 | Microsoft Xbox 360 Console
2 red lights fans don;t work
Hey Marsh2Man,
It's not your fans that's causing the problem. It's the XBOX itself. The Xboxes generally overheat and this has been a big problem for Microsoft. Alot of companies are actually reflowing these system, reheating the solder under the chips allowing them to connect back down to the points on the board.
You will need your system reflowed. Contact a repair shop.
Jun 02, 2009 | Microsoft Xbox 360 Console
My xbox says E74 on the screen
Hello Alexwhttn,
What you are experiencing for both of your box's is very common.
The first box that displays the e74 error code has a hardware malfunction. What that most likely means is the motherboard is losing contact with some of its components due to bad solder joints.
Their are a few remedys for this.
The easiest and the most dangerous(for the xbox) is to put a few towels wrapped around the xbox to completly seal in the hot air as it is running. Let the xbox run for roughly 5 minutes with the towels on it and then shut it off and let it cool for roughly 10 minutes. After it is cool you can turn it back on and maybe just maybe it will work for you. The reason this works is because it heats the xbox up enough to reflow the solder and make the broken connections melt back together. This is really only a temporary fix and over time you will need to heat it up more frequently and for longer periods of time. I've done this to two xbox's and both of them towel tricked' for years before the completly died.
The second way to fix your xbox is to just send it to Microshaft and let them handle it. If its under warranty this is your best bet. The new xbox's have a different motherboard that almost eliminates the problems with the former xboxs.
The final way is the do-it-yourself way that will fix it permenantly. I won't go into a step by step list of how to do it because all you have to do is search youtube.com for xbox 360 fix. It will bring up a whole slew of videos on how to fix the faulty motherboard.
What you will be doing is using different bolts to clamp down the heatsink and another item connected to the motherboard. You will also be applying fresh thermopaste to the connects to get a better connection. This is a short short answer of what you will do.
On to your second xbox.....
Your overheating the xbox 360 when the two red lights come on. I can't remember if its the left two lights that illuminate(I believe it is) or the right two but if the two vertical red lights come on after some gameplay it means your getting it to hot.
Some remedies for this are the intercooler sold for the xbox360.
I like to put a few books on the corner of my 360 to prop it up(xbox is in the horizontal position) to let air circulate underneath it.
I also cut a 1.5 inch by 3 inch hole above the power button. This will involve opening the xbox, and removing the case to cut but once done you wouldn't believe the amount of air flow you get through this hole.
Well I've tried to give you the best answer I possibly can. I hope this helps. If it does help you could you find it in your heart to give me a good rating?
Thanks and have a great day,
AadoubleA
Apr 04, 2009 | Microsoft Premium System for Xbox 360
2 red ring lights when playing World at War
no you still have a warranty microsoft extended there warranty due to console problems so call up xbox talk to max. and the warranty ends 2010
Mar 15, 2009 | Microsoft Xbox 360 Console
As playing Xbox 360 system shuts off two red lights occurs.
Two red lights mean your 360 is over exceeding the inside temperature. Your fan must not be working at all and your 360 is overheating tremendously. That is what I know about the 2 red lights. Im not sure what to tell you to fix this but to just call 18004myxbox.
Mar 01, 2008 | Microsoft Xbox 360 Console
Problem with Xbox 360
You have the infamous red ring of death. This means you system's hardware has failed and you have to contact Microsoft about getting it fixed.
Nov 29, 2007 | Microsoft Xbox 360 Console
2 red lights on the ring of light
2 red lights mean its getting overheated i noticed this was happening 2 mine whilst i was playing halo 3 so every 30 - 40 mins i saved and quited and placed a fan infront of the back pannel for about 5 - 10 mins this cooled it down and could be played for longer without thret of over heating
p.s saveing and quiting can be frustrating every 30 mins so do it after that level 30 mins through. :)
Jun 09, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
238 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
