Question about Canon PowerShot S5 IS Digital Camera
My flash will not work
Ok this happens constantly, my flash wont work, the camera tells me to raise it and when i do it takes the picture but does not flash. simply said my flash is not going off at all, and it has nothing to do with charging because i know its charged
  • shyamvad May 15, 2009
    Hey I have the same problem and no amount of toiling with the settings seems to bring back the flash.
    I don't remember the flash bulb blowing off.
    Does anyone know what settings I need to work into.
Just program it to "Always On"
Posted on Oct 21, 2008
I'm having the same problem... and there is NO setting for "always on"
Posted on Mar 14, 2010
Guys... I got a problem with my S5IS. The in built flash is not working and not letting the picture been captured. And more over it gets hanged. It was working fine till today and all of a sudden it started. I can take pictures if im using it without flash. And it will also work with additional flash. Im totally confused. Hope someone can help me sorting out this.
Posted on Jun 09, 2009
Why does "raise the flash" come on the screen when I turn my coolpix s5090 camera?
I do not know allot about the s5090, but I can give you general information based on how most Nikon pocket cameras are designed to work. If the Nikon is set to one of the automatic modes it is designed to prevent you from taking a picture if it senses that there is insufficient light to get a properly exposed picture. The camera may be telling you to rase the flash because it needs more light. Also, somewhere on your camera there is probably a menu that allows you to choose the flash mode. It may be in your regular menus or, if your camera has a round left-righ-up-down switch on the back, you can select the flash mode by pushing up and then using the right-left keys to choose the flash mode. The mode you select is locked in when you push the button in the center. In general, the modes are automatic (the camera decides when flash is needed), red eye reduction (the flash activates twice; once to cause your subjects eye's iris to close and the second to take the picture), flash always (flashes regardless of the ambient light) and flash off.
Jul 12, 2014 | Nikon COOLPIX Cameras
Flash not working
I had a similar problem my camera kept telling me to raise the flash even when it was raised. I opened the back of the camera taking out the little screws on the back only. To the right right below the flas is a switch that registers when the flash is raised. Something had broken off in mine because nothing would push the switch. I wedged it down with a foam nose pad for glasses (came in the kit i bought for the screwdriver). Now flash registers all the time so I have to manually change the setting if I don not want flash but it is working now.
Apr 02, 2014 | Canon PowerShot SX130 IS Digital Camera
Canon EOS Rebel XT Error 05 or BUSY
The Error 05 means the build in flash cannot be raised.
In the moment it should pop up, something was blocking the free movement. Could be caused by the way you were holding the camera. Could be happening, while you were pressing the flash button, or when you are in the basic zone shooting mode, such as portrait, which needs the use of the flash.
Switch the camera off an then on again. Move an eventually cause of the blocking and press the shutter realise button again.
Feb 21, 2014 | Canon Cameras
Can't get the flash to raise on its own. Surely I
As far as I know, the only way to raise the flash is manually.
Jan 14, 2010 | Canon PowerShot SX10 IS Digital Camera
Despite changing batteries constantly, camera wont work properly. With fresh, new AA batteries, camera will take 1-2 pictures and then low battery light comes on , then camera shuts off
hi, this can be happening due to some bad battery contacts in the camera. take some cotton buds and clean the lower and upper contacts of the camera. this will help you. else revert back to us. thank you sweet rascal
Oct 18, 2009 | Canon PowerShot A75 Digital Camera
Wont take a picture with the flash on!! help
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2008/05/simple-fixes-for-cameras-that-wont-take.html
Apr 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Nikon coolpix s210 Not taking pictures
It sounds like you should try a new set of batteries in the camera. I have a similar camera and the flash is the first to go when the batteries are dying.
I hope this helps,
Eric
Jan 19, 2009 | Nikon Coolpix S210 Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
589 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
