Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
Connects to Access Point but the internet cannot be found
I receive this message when attempting to connect to the internet on the Linksys monitor screen. Every so often it connects to the internet for no apparent reason. However, this is a toss of a coin and will not consistently connect. What is the problem? And how do I fix this?
  • Anonymous Mar 14, 2009
    i have the same problem and "ipconfig/renew" does not fix it. have tried it several times.
I am having the same problem. My internet connection is at 96% and it connects and then disconnects while trying to access the internet.
Posted on Oct 25, 2008
    Genius:
  • 1,124 Answers
Try to reset your ip address
Find your internal IP address.
Click on "Start -> Run..." and enter "cmd" into the box.
When the command-line pops up, enter "ipconfig / renew" and hit "Enter."
This will be rewing your ip address
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Posted on Oct 15, 2008
  • Linksys Master
  • 6,487 Answers
The main reason why you have this error message because your computer is not getting a valid IP address from teh wireless network, and the reason why its not getting a valid IP address is the wireless security or sometimes called WEP/WPA kay are not type in to the correct place, If you have a WEP enable on your wireless network you will have two option on the Linksys WLAN monitor where you can type in teh security key, you will see two boxes there when you try to connect to the secured network one says Passohrase and one says WEP key1 and if yuo have a wireless key that has a total of 10 or 26 key character you need to type that on the WEP key1 box leave the passphrase blank...But if it still didn't work you can contact this number for help 1-877-787-8749....
Cannot change transmission rate of Linksys WRT160N
1.With an online-capable game inserted into your Nintendo DS, turn on your system and access the game's main menu.
2.Access the Nintendo Wi-Fi Connection settings.
-These settings are typically found by selecting "Nintendo WFC" from the game's main menu. For detailed directions, consult the manual for the game.
3.At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
entryscreen3-cwz5mha2srvvin44vycqgk0s-3-2.jpg 4.Tap a connection file labeled "None."
emptyconnections4-cwz5mha2srvvin44vycqgk0s-3-5.jpg -If no empty connection files are available, select "Erase Settings" followed by "OK" to create an empty connection file.
5.Tap on "Search for an Access Point."
connection1settings-cwz5mha2srvvin44vycqgk0s-3-9.jpg 6.The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
oIf you receive the error message "No Compatible Access Points Within Range," click here.
7.Tap on the name of your wireless router or access point.
oIf there is a gray padlock next to the name of the wireless access point you wish to connect with, this indicates your router is using a security type incompatible with the Nintendo DS.
If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point.
enter_wep1-cwz5mha2srvvin44vycqgk0s-3-14.png 8.Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test.
9.The connection test was successful - Your Nintendo DS is now connected online.
Situation Not Resolved:
If the connection test was not successful, you will receive an error code:
·Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
Apr 21, 2017 | Linksys WRT160N Wireless Router
My LINKSYS advisor reports a problem connection with the internet (there is a warning triangle on the network status display) and my laptop connects to the router but receives a page can not be displayed...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 07, 2010 | Linksys WRT300N Wireless Router
I can not access the linksys access point, the 192.168.1.245 does not link.
the default address is 192.168.1.1. if you still can't access you can factory default by pressing and holding the reset button on the back for about 10 seconds. after it restarts the ip address will be 192.168.1.1 leave the username blank and the password will be admin.
Apr 15, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
I just added the wireless notebook adapter and it
Is your wireless network secured ? IF secured then make sure that you are typing the correct network key / password.
if you are not sure about the wireless settings of the router then open the set up page of the router and check the wireless settings.
You are getting the message " connected to the access point but internet can not be found ". Are you using Linksys wireless adapter ?
What is the operating system ? If it is Windows XP then use windows utility to connect to the wireless.
Click Here for step by step instructions
Mar 10, 2010 | Linksys Computers & Internet
Using a linksys g adapter card in my laptop cannot get internet
U have to configure the router.Then & then your internet will work.You can see the instruction set given with the linksys router or instruction set cd.Follow the steps,which will ask you ip,user name,password etc. information.Fill the right information save & reboot it must work.
Jan 03, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Dell Dimension DE051:Wireless Internet Problem (Can't Load Sites)
contact Comcast and have them reset your IP address. also have them ping your modem after they reset IP.
Also, see Linksys website for LELA (easylink advisor) to add devices to network. Uses a good bit of memory so don't allow to run automatically at start up.
Dec 30, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Linksys WUSB54GC 802.11g/b can find access point but not internet
do one thing remove the prefered networks from the list of prefered network sand after that connect to the network
u will be able to go online after that ....
Nov 15, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
One computer not able to access internet
you got to make sure the wireless settings of the wireless adapter is the same with the router. usually this problem happens if the wireless encryption or password you used in the computer is not the same wireless password in the router.
May 29, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
No association with access point
hi
is the access point WEP enabled? or is it public? as long as you are able to detect the access point, try and edit your profile to which you can connect.
if it is a WEP enabled access point, you should have a passphrase key to access it.
if its public...
try and use this...
http://www.makayama.com/EasyWifiRadar.zip
hope this helps
Jan 28, 2008 | Linksys PCMCIA Network Card PCMPC100...
Linksys WAP54G connection to WRT54G
Ok, so why do you need an access point upstairs and a router downstairs connected wirelessly? If you can't connect with a laptop or a pc, why whould you think you could connect the access point? The purpose of this configuration would have to be with the access point to the router via ethernet. What's the point? If the problem is range, check out http://www.dd-wrt.com/dd-wrtv2/index.php to enhance the capabilities of the WRT54G... and maybe building a parabolic antenna for it as well. Plans to do so abound at Lifehacker.com.
Sep 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
358 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
