Question about Casio Exilim EX-Z750 Digital Camera
Washing Machine and EX-Z750
Recently, i went paintballing and took a lot of photo's. After which, i washed my paintball pants and unknown to me, my Casio Exlim EZ-Z60 was in my pocket, so i found it after the washer had turned off.
I have been airing it out for 3 days now, and the only way it will turn on is if i hold the power button, or to press the power button once then again after a second or so, and then it makes a noise like if you were to go to the gallery, and will show a screen that says "Adjust" and it has a Time&Date setup, but my keypad doesn't have any affect on the screen.
If i try to turn it on normally, it will flash the green power light and stay black, a couple minutes later it will make a noise as it turns itself off.
Help me please. I would really really appreciate some feedback that might help.
If it requires taking apart i have the materials required to do so. I figured that would be a last resort, in the case it couldn't be replaced and that i cant get any help.
Its been three days since i did anything with it, it has been sitting without a battery or microSD card to allow for drying. I havent opened it in fear of voiding any chance of replacement.
  • 39 Answers
Alright you may want to try putting it in a sealed baggie with rice...yes I said rice lol. The rice will draw moisture from the camera. If this doesnt work you will want to take it apart and blow dry the internals. Do you have a warenty? You may want to look into that.
Posted on Mar 29, 2009
If a player gets hit with a paintball that doesn't break, is he still out?
In most paintball games and tournament play, a paintball impact but non-break is non-elimination. It is good sportsmanship to call out "bounced" or "didn't break" if he/she is hit but does not receive paintball splatter.
Jan 17, 2013 | Sport & Outdoor - Others
This a genesis lethal threat paintball gun I just got it and I am new to paintball what size paintball do I get for my gun please get back to me as soon as possible thank you
First off do you have a hopper and an air tank or co2 tank with air or co2 in it. If no get those things and fill your tank at a local paintball field. If yes your gun takes a .68 caliber paintball. That's really any paintball that you can buy at Walmart or sports authority.
Dec 01, 2012 | Toys
Bruizer outlaw paintball gun
There are many things to take care of the paintball gun. The good thing is that with paintball gun so much choice available, you should always be able to find a marker that meets your requirements perfectly. To get the details about each and everything you can refer to Best Paintball Guns.
Aug 26, 2010 | Sport & Outdoor - Others
I have a semi auto alpha black. When im firing on semi auto sometime the gun switches quickly to fully auto and releases lots of CO2 without really shooting any paintballs
Does this only happen when you're low on air? Also, make sure you're using a good paintball oil for lubrication and make sure the marker is clean. It's possible for an o-ring to leak, or once it gets cold to leak, so make sure you use the proper o-ring for the proper location (lots of them look alike so keep them labeled and bagged separately).
Play hard, play safe, play with honor!
8^)
Aug 19, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
98 Custom Act Paintball Gun: i want it to go fasteer...
I can take that a couple of ways. Do you mean you want to fire more balls per second or you want the paintballs themselves to fly faster?
If you want to fire faster, make sure it's clean and properly lubed with a quality oil that made for paintball. Practice makes perfect and fire that ****** as often as you can, even without paint (that's cheaper!) so you can get your trigger finger in shape.
There are custom mods to the trigger, or you can buy a trigger that's smoother or a shorter pull. There are electronic trigger assemblies that make firing faster even easier.
If you're talking about making the balls fly out of the gun faster, that would be the "velocity adjustment". Your user guide shows you how to make that adjustment and which direction is up, and which is down.
A good suggestion is to check out a local field or paintball store, or an airsmith and they can give you some definite ideas you will want to pursue.
8^)
May 17, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun problem
First off, make sure it's clean, and lubed with a quality oil made for paintball.
If you're sure the o-rings are good (as in relatively new) it's pretty hard to tell just from looking as it doesn't take a lot of damage to leak air.
Try a different tank, just to be sure. Make sure it's full.
**** it. If that stops it there's a clue.
If it's had some use it's possible to have a bad/weak spring and the valve isn't closing entirely. Make sure your velocity is less then 300fps.
Check out your local airsmith or field and they should be able to get you squared away if none of that helps.
8^)
Apr 30, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Took it apart and don't know how to reassemble
How To reassemble an Army alpha black paintball gun.
Apr 23, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Washing Machine and DigitalCams dont mix
Sorry if the replay comes late, but whenever that happen with any electronic device, the best thing to do is, first off all remove the batteries, after is to taking it apart and just wash with alcool, to remove the water and humidity, and after dry it up, u can still trying it, therefore just do it as quick as possible.
good luck
Oct 14, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
78 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
