Question about Electrolux EW1000i Front Load Washer
Error message E31 on Electrolux I-touch front load washer
Machine comes on but will not start
  • logi2003 Jan 24, 2009
    same problem, have an IQ Touch Front Load Washer by Electrolux, error code E31, Starts, then stops with this error code, Model Number EIFLW55HIWO
  • 750 Answers
Hello kleveille
Welcome,
You said, your machine comes on but will not start
I need the model number to start to help you???????????????????
huuum
Posted on Oct 16, 2008
Washer won't start showing code E31. Already changed pressure switch an cleaned drain. Is there a way to reset?
error code e31 frigidaire washer Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your error code e31 frigidaire washer question. ... error code E31, first check if it is a false error code by resetting the power to the appliance by ..
Jul 28, 2015 | Washing Machines
E31 error code on electrolux washing machine
Good Afternoon Friend,
I understand that you are receiving an E31 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E31 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
Jun 08, 2014 | Electrolux EW1000i Front Load Washer
Electrolux EIFLW55HMB Front-Load Washer With IQ-Touch controls won't open
Try unpluging for a few minutes . wake the washer up by turning knob then at the same time press and hold start cancel error will display . take off top and you will find a tech sheet on left side and that should help. you can manually unlock the door after taking top off and reach down to door lock you will feel a plastic switch to pull
Feb 17, 2013 | Electrolux EIFLW55HMB Front-Load Washer...
E42 error code electrolux washing machine
Just followed the advice above by removing the 2 screws holding the top on and manually released the front load door. Now to figure out what part I need to replace the door lock mechanism and figure out how to do that.
Thanks!
Dec 20, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Frigidaire-washer Error Code E31 What does this mean?
It would seem that these newer washers respond much like a computer. If you have not tried it, and this works for multiple error messages, unplug your machine, wait ten minutes and plug back in. Often this resets the board and your error will not reappear.
Feb 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer lights are all flashing
Hi friend.....
It is an indication of an error code,,,,,,,did you see any error code on timer.........
thank u..........
May 03, 2009 | Electrolux EIFLW55HIW Front Load Washer...
E31
Hello Smithysarah,
Welcome to fuixya,
You said, HI MINE READS ERROR E31 WHAT DOES THIS MEAN?
E30 or E31= Motor Drive Problem -
Run the programme again,
if problem persists call for
a Service Engineer.
I will tell you a secret.
Try unplugging the washer for 5 minutes and then we will see if this has reset the system!
like rebooting your computer.Some times it is only a glitch and no mechanical problems are there!
If so you saved a service call.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Thank you.
Waiting for your results!
Sep 30, 2008 | Hotpoint Ultima WD72 Front Load...
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
E31 error code
Did a little search and this is what I've found. http://www.fixed4free.com/answers.php?id=30722 Goodluck.
Aug 29, 2006 | Zanussi FJD1666W Front Load Washer
Electrolux EW1000i Front Load Washer Logo
1,048 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
