Computer is slow as if it is constintly running a program or something - and - sometimes the screen will go blank as if it shut off, but the power stays on
    Genius:
  • 1,124 Answers
Many computers have way too many things running in the background. If you see more than three or four little icons down just to the left of the clock, (this area is called the System Tray), some of these programs could be causing your problems.
Use Windows Explorer and navigate to:
C:\Windows\Start Menu\Programs\Startup
Adjust the size of your Windows Explorer so you can see some of your desktop and drag everything in the Startup folder out on the desktop, and then restart your computer. If this minimizes, or eliminates your problem, put each item back in the Startup folder, one-at-a-time, and restart and re-test your computer until you locate the offending program.
If your computer shut off but the power keep on means that your computer is in hibernate mode
To avoid that, do this:
Go to Start >> Control Panel >> Power Options
Unckeck the hibernatge mode at hiberbate tab.
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Posted on Oct 15, 2008
My laptop worked fine on night then in the morning i started having problems. These are the problem that i am having my with my HP Pavillion 6910us Laptop. 1. My laptop comes on but cuts off after 5 to 6...
Hi
At some point if you can get the computer to stay up for a while, you should go into control panel and check your
POWER settings. The other thing you should try if you haven't already is to shut the computer off and pull out the battery. Then after a minute re-install the battery and see
if that helps.
Good Luck
Joe
ps: If I come up with any ideas I will post.
Mar 04, 2017 | HP Pavilion Dv6910us Notebook
I have a dell latitude laptop my problem is, it takes over 5 minutes to power off. I click shut down screen goes to desktop screen no icons about 5 minutes later it says its shutting down screen goes black...
There may be nothing running in task manager that you can see but there is still something running,My advice is to take it to your local Geek Squad or preferred computer tech you most likely have a virus that is slowing down your computer process.
Sep 24, 2010 | Dell Latitude D531 Laptop Computer PC...
1) difficult connecting to yahoo, computer slow
sounds like virus or spyware at first. get microsoft security essentials and scan you PC i bet it's riddled
the PC should power off if you hold the power button in for 4-6 seconds, rather than use the switch at the wall
Jan 13, 2010 | Computers & Internet
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
White blank screen
<Fn> + <F6> Screen blank
Turns the display screen backlight off to
save power. Press any key to return.
Dec 30, 2008 | Acer Aspire 4315 Notebook
Stand-by button has lost its tautness-on start up pc slow and reverts to black screen for a time
For every piece of software besides windows that starts when you power on your computer, some of the computer performance is sacraficed. this will cause the computer to hesitate , perhaps show a blank or black screen a little longer as the computer starts or comes out of hibernation.
Most of the software you install will have a little box stating something like "start when windows starts" that is checked by default when you install it. always pay attention and read as all of these will slow down your computer if running at startup.
hit CTRL+ALT+DEL once your computer is fully started, this will open your task manager.
select the PROCESSES tab and count or go to the bottom and see how many processes are running right when you start the computer.
Most of these can be turned off, windows only needs about 20 to run efficiently wiuth networking, granted there will be some for the printer also.
write down what you see and and programs that dont need to be running can be set , either in thier preferences or windows settings to not run , thus speeding up the computer..
please post here again after you have checked this and i will assist you if you have more questions.
Oct 21, 2008 | Siemens Computers & Internet
I need Help
An infection could cause the issues your having. I recommend letting a professional help you clean your system. Removing infections is very dangerous and risky. They can cause data loss and you risk making the system worse. I recommend NickLockard.com
http://www.nicklockard.com
Jun 28, 2008 | Sony VAIO Digital Studio PCV-RS420 PC...
Cpu
Your computer shuts down slowly because there are a lot of services that run in the background that have to close before the computer shuts down.
Another reason that it will be slow is because of some programs that stay in residence have to close too.
Running defrag and scandisk will sometimes speed up startup and shutdown.
Dec 26, 2007 | Computers & Internet
Imate jasjam
I would look at some third party applications that clear up the memory while you are on the PDA / JAM. You can also go into the settings function, memory and view running programs.
One of the earlier version flaws of Windows 2003 is that it does not offer a shut down menu on the Today Screen. There are quite a few freeware applications that allow you to shut down running programs. I tend to run one or two programs - maximum at a time. This is not a laptop. I find my touch screen unresponsive if too much memory is in use. It's not really the touch screen but that the computer can't follow my commands, almost like an old 283 or 386 computer.
Take a look for these tool bar/memory manager programs before sending out to service in Mumbai.
Dec 11, 2007 | i-mate JAM Pocket PC
Screen shutting down
Well, Gestion Alim is French for "Power Management." It means that your computer is shutting off power to the video using the ACPI power settings, probably stand-by or hibernation. Bring up the Power Management settings in your operating system (in Windows, it's the Display icon in the Control Panel) and change them to something more reasonable. If you want to disable them completely in Windows, change to "Presentation" and make sure that hard disks and display are both set to "Never" shut-off.
Nov 08, 2007 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
