Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Ceiling fan with light fixture remote won't turn it off - help!
I have a ceiling fan with a light and now I can't get it to go off. I tried changing the 9 volt battery but that didn't work.
Anybody have any advice?
  • thomasteam Oct 15, 2008
    There is no wall switch only a remote control.
  • Loringh
    Loringh May 11, 2010
    Does it go off when you use the wall switch?
Think we've figured out that a neighbor has the same remote code as we do and we will have to change our code. (This fan is out on our screened porch and the homes are close together here.)
Posted on Oct 15, 2008
How to fix ceiling fan light
Make sure the light wire is connected to the receiver & bottom of fan.You should set the light to the on position when using the remote and leave it that way.
Sep 10, 2015 | Hunter 52" Ceiling Fan With Light And...
Fist, make sure the bulbs are good. Check in another fixture to verify that they indeed work. Since the remote works the fan, dead batteries can be ruled out. The problem will be confined to either a bad receiver in the fixture, or a bad remote.
Since Hampton Bay is a line carried by Home Depot, you may have some luck bringing your remote to HD and trying it out on the display units. You may need to try different address settings on the remote to find one that works if you don't get results the first time. This is usually several two position switches often called "DIP Switches". Change the positions of them one at a time until you find one that works. Try to control a fan first. Once you find a fan the reacts to the commands from the remote, try to control the light. If the light doesn't work - the remote has a bad transmitter or light switch control. You could attempt to disassemble the switch, but most don't have parts that look different when they're bad. You'll probably have to replace the remote.
If the lights work, then the problem is with your fixture. You can remove or simply bypass the radio controller in the fixture and install an after market receiver and remote to control it again. These are sold at Home Depot and work with any paddle fan.
I hope this helps & good luck!
Oct 26, 2011 | Hampton Bay 48670 Flemish Pewter Finish...
I want to install a ceiling fan. My ceiling is 80 year old lathe and plaster design. Will the vibration from fan movement cause my ceiling to crack?
mcdevito75 here, Hopefully your ceiling fan will go where there has been an already light fixture, if so, that light fixture shoud be mounted to the ceiling beam, and your new fan will be mounted the same way. If by chance your new ceiling fan is being mounted where nothing was ever mounted you"ll have to make sure the ceiling fan will mount to a beam, they are every 16 inches apart. This way you:"ll know that vibration from the fan won"t hurt anything.
Jul 21, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Lights flicker on ceiling fan: We have 4 cfl bulbs in a ceiling fan light fixture that have recently started to flicker. They've been there for a while without the problem, so it's not a matter of a new...
It is not a ceiling fan or wiring problem. It is your bulbs. Normal CFL bulbs do not work in dimmers or with remotes. Remotes work on RF signals and cause interference with the bulbs. You may also notice a buzzing sound and the lights may not go out when you turn off the switch. It is a fire hazard, can invalidate your warranty on the bulbs and will shorten their life. Try changing the bulbs to the new dimmable CFL's and see if it helps. It should eliminate your problem altogether.
Mar 15, 2010 | Hampton Bay 52 In. White Redington...
I changed my bulbs and now the fan or the light will not shut off by the remote. The lights dim but that's it.
changing the bulbs shouldn't cause a problem, it could be a difference in the designation of the fixture and the bulb, or be a simple problem with the remote. If you haven't checked or replaced the remote's batteries, you can try checking what the specs are for the fixture (should be on the side of the light-socket), and see how that synchs up with the bulb's specs.
Oct 23, 2009 | Hampton Bay 04345 Cruiser Ceiling Fan
Remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Apr 22, 2009 | Hampton Bay 24002 Ceiling Fan
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
817 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
