I want to diasble my router firewall and cant fiquere where its at
  • knvosss May 11, 2010
    what is the brand and model of your router?
    if you are trying to completely expose your computer to the outside world, you want to get into the settings of your router and put your computer on the "dmz" list. i strongly recommend only doing this for troubleshooting reasons and taking it off after you are done. let me know if this helps, or you need further help!
  • 67 Answers
Posted on Nov 03, 2008
    Genius:
  • 1,124 Answers
Disable router firewalls by logging in to the administration interface of your router and looking for a firewall section.
To log type http://192.168.0.1
The administration interfaces differ depending on the manufacturer and model, so your wireless router might not have a firewall section. If it does, click on that section and turn off the firewall.
Step2Forward a port. If the firewall is preventing an external computer from connecting to your internal client, you will need to forward a port to your client. Step3Find your internal IP address. Step4Click on "Start -> Run..." and enter "cmd" into the box. When the command-line pops up, enter "ipconfig" and hit "Enter." Find your IP address in the statistics that are printed out. Step5Refer to your software's documentation to find which port number must be forwarded. Step6Log in to your router's administration interface. Step7Click on "Port Forwarding" or an equivalently named section. The name of the section will differ depending on your router's manufacturer and model. Step8Add, on the correct port, a forward to your IP address. You will have to update this port forward in the future if your IP address changes. If your IP address changes often, ask your network administrator for a static IP address. This will fix your problem. Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Posted on Oct 15, 2008
Not able to sign up for a creating a new account in facebook to connect with my friends
Hi.
If your problem is just cant create a new account in facebook, but you were able to browse the internet can go to other website. This is a firewall issue on the router or the firewall on the operating system. you can add exemption on the firewall both on the router and windows firewall
Jun 10, 2011 | Computers & Internet
I cant get past the routers firewall for certain programs. How do I allow these exceptions? Help!
Your computer has the firewall installed in it, you will need to turn off or configure your firewall settings in your computer, to do that if using windows XP: Start/Control Panel/Switch to classic view/Windows Firewall, turn off firewall.
Windows Vista/7 Start/Control Panel/Windows Firewall turn off firewall. Follow these steps good luck.
Mar 25, 2011 | Linksys Wireless-G Broadband Router
I cant find my security string
Ok here is your solution.
  1. let me know your Windows operating system
  2. check your Security type setting in your router
  3. channel and SSID sharing
  4. disable Firewall in router
Check your windows firewall and some anti virus who cant also block your signal.Go to setup page Belkin using 192.168.2.1
If you cant open it just reset router,go in the back of your router and locate the reset ping.
if you still cant do it just check your physical connection and go to command prompt using RUN and type CMD after ping router 192.168.2.1 and you will get a four answer and zero lose.
if you still cant do it ask me for a remote setup in your pc .
If you are able to open Belkin setup page using 192.168.2.1
Check all configurations and be sure you can setup it to wep64 bit security mode and your problem will be solved.
Sep 18, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How do i block my router from other people...
You can always block your router for your use by setting a SEP private key to your router. Giving this SEP key will vary from router to router. As you havent mentioned the brand name and model number of ur router I cant able to provide an appropriate solution for you.
Aug 01, 2010 | Computers & Internet
Cant connect to any online game servers
Check your router (usually connected between your cable or DSL modem and your PC) and also your software firewall(s). Windows has its own built in firewall, and both Windows and Macintosh have security software's that may have come with your computer, or you might have purchased them afterwards that could also contain a firewall.
Sep 23, 2009 | Computers & Internet
NETGEAR wireless ADSL firewall router DG834G how to set port, coz i think my router just blocked UDP 6100..and i cant use my VENT...pls help
go to the router then go to the nat option then go to the port give ur port number 6100 and give the udp and tcp both
Mar 27, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Networking
It is probably your firewall. What company is your firewall and what operating system is your computer? This will hepl determine what it is.
Good Luck,
Fixer Guy
Feb 03, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i disable the firewall on the router ?
have a thopson wireless modem model 782 cant disable the firewall so i can use bitcomet
Jun 04, 2008 | Paradyne (6211-A1-200) Router
Sining in to hotmail mensager
In the messenger options / tools there is an option to diagnoise and solve problems, you can use that of you can diasble any firewall you have or open a port on the firewall for messenger
the first solution is recomended
Jan 08, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
