Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Exchange 2003 Activesync only when Email Open
By Hart - usenet poster
Hope this goes well, I am a virgin placing a new topic in. Sorry if I
have done something wrong
Front end - back end exchange 2003 SP2 setup.
front end on a dmz, firewall open for all ports and working correctly
with Owa\oma
All configured on one virtual directory and default website.
SSL and certificate all working correctly on Front End.
Smartphone and imate used for testing and works.
Windows Mobile 5.0 with latest active sync
My Problem is
Trying to configure Activesync so that exchange pushes email correctly
to mobile device. This will only work if microsoft outlook is open on
the client computer. The clients are remote so they are using cache
mode. I have looked fully into this and searched everything but I
cannot find a way to resolve this problem. Very interested to know how
to fix exchange so that is pushes out to the Imate
Love the Google Groups, saved me hassles for years
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Feb 11, 2008
-   I'm having the same problem. The Sprint Mogul I have won't sync with exchange unless Outlook is open on my desktop. i don't have any problems any other time.-   Pumfa
Dec 07, 2007
-   I am having the same problem. I couldnt believe it. I made a user prove it to me. There is no BlackBerry server in this environment. These are new WM5 devices that shipped with the MSFP. ActiveSync also is having problems with an initial sync. In other words if a user performs a master reset, when he syncs again his contacts do not pull back down to the device. It is scanning for changes to the contacts, so if he modifies a contact in outlook it will then sync to the device. Not sure if it is a seperate issue or if the two are related.
-   jditto
Nov 26, 2007
-   Did anyone ever find a solution to this problem? We are having the same issue with our Tre 750 from AT&T.-   BTrent
Nov 08, 2007
-   Hart,
Any news about this problem? I am having the same issue. Exchange 2003 Activesync only works when outlook is open.
Tks,
srponte@gmail.com
-   srponte
Best Solution
posted on May 27, 2006
Very Helpful)
Luisa_K
Rank: Apprentice
Rating: 0%, 0 votes
On 14 May 2006 22:31:52 -0700, "finger"
Sounds like the phone doesn't actually have the MSFP build on it. How
long have you had the phone, when did you install the MSFP build and
does the vendor confirm it's got it?
Was this helpful?
Yes
No
Solution #2
Helpful)
Charlie
Rank: Apprentice
Rating: 0%, 0 votes
Hmm - I thought I posted another response, but I guess not.
As far as the hypothesis, I've never seen the behavior you are seeing.
Exchange does keep a record of adds/moves/changes, but it does so in the
transaction logs, which are then committed to the database. There is no
"separate" database that is used for ActiveSync.
I'm not sure what information you are looking for on how ActiveSync works
via GPRS/SSL. AUTD/Push actually only works over cellular connections. Can
you be more specific?
Does ActiveSync pull across new mail if you initiate a manual sync? Or is
that part of the problem you are seeing?
If the WM5 device does *not* have the MSFP/AKU 2.0 update applied, it is
still using AUTD for notifications. Some carriers have problems with the
way Exchange sends out the sms notifications. There is a hotfix that takes
care of that.
Ben Winzenz
Exchange MVP
MessageOne
Read my blog!
# (RSS Feed)
Was this helpful?
Yes
No
Solution #3
Helpful)
Ross
Rank: Apprentice
Rating: 0%, 0 votes
Hi Ben & Mark,
I work with Finger and just wanted to clarify the problem we're seeing.
I think he swayed a little too much towards AUTD/push, but that's not
the core problem.
We actually have 2 devices - an O2 Smartphone IIm running mobile 2003
and an i-Mate JAMin running mobile 5. Obviously, the former doesn't
even have "push" capability. The root of the problem is this:
- if you are logged into a PC within the network and are running
Outlook, Activesync will fully synchronise mail
- if the above is not true i.e. you do not have an Outlook client
logged into the Exchange server, Activesync goes through all of the
normal motions, but does not get any new mail messages
- there is one exception to the above; if you visit oma via the browser
on the phone and look at your Inbox, then go to Activesync and
synchronise, it does it perfectly
I hypothesise that Activesync queries the Exchange server, which keeps
a small "database" of adds/moves/changes. When Outlook is connected, or
you use OMA, it forces the server to update this database When it's
not, Exchange doesn't update it and, hence, Activesync doesn't get the
message. Unfortunately, we've been able to find little information
about the relationship between Exchange and Activesync when used via
GPRS and an SSL tunnel. Note that Outlook cache mode has nothing to do
with it; we've tried both ways. We're absolutely sure that the firewall
is not cutting us off too. It's gotta be at the Exchange server and/or
OWA gateway (we use FE/BE mode).
Thanks,
Simon Brewer
Was this helpful?
Yes
No
Solution #4
posted on May 28, 2008
Helpful)
phd2it
Rank: Apprentice
Rating: 88%, 2 votes
Here is a possible solution for this issue. I found reference to it on another site and thought I would post it here for others. Apparently there is an issue with virus scanners blocking push when active on a server. This is documented for Symantec and CA that I am aware of and likely some others. To fix it try this in the registry on the Exchange server:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\MSExchangeIS\VirusScan
ProActiveScanning=1
You can read about what some other people went through for this at:
http://discussion.treocentral.com/archive/index.php/t-109210.html
I had the same issue with Windows Mobile 6 and and Exchange 2003 server.
Hope that helps someone.
Comments:
May 28, 2008
- Not sure if anyone solved this issue or not but I have a solution that worked for others. I am testing it on my configuration. I realize it has been a while since this was posted but if anyone else finds it like I did it might help them as well. I was having similar issues and I am using Motorola Q 9c and PPC 6800 handhelds. We are connecting to an Exchange 2003 server. Like others on this post my handhelds wont download mail unless outlook is up for the account in question on a desktop somewhere. One more symptom is if you go to OMA via a browser and view mail it will download to the handheld fine.
After a lot of playing I discovered that this is an anti-virus issue. There is a setting in the registry of the server running Exchange that resolves this issue:
ProActiveScanning=1
You can read more about it on another forum here:
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Dec 07, 2007
Somewhat Helpful)
jditto
Rank: Apprentice
Rating: 70%, 1 votes
Comments:
Dec 07, 2007
- I have a theory that I haven't been able to test yet. I believe this may be due to forms based authentications. If anyone is still reading this thread, please let me know if you are using forms based authentication for OWA.
I found a few articles that may explain this. (They dont describe the exact symptom, but it seems to make sense) Basically Exchange is looking for Kerberos authentication, and Forms based doesnt provide that. So while outlook is open the user is authenticated to Exhcange and activesync will work until the user logs off and is no longer authenticated.
"The /Exchange virtual directory can't be accessed by OMA and ActiveSync if it's hosted in this fashion. Forms-based authentication can only work through the Basic authentication method (the security for the process is supplied by the SSL connection itself); but ActiveSync's virtual directory can only connect to the Exchange Server virtual directory via Kerberos (NTLM) authentication. "
http://searchexchange.techtarget.com/tip/0,289483,sid43_gci1188440,00.html
http://support.microsoft.com/?kbid=817379
Was this helpful?
Yes
No
Solution #6
posted on Jan 10, 2008
Not Rated)
FIGDU
Rank: Apprentice
Rating: 0%, 0 votes
Took me about 4 days to find this and fix mine.
Was this helpful?
Yes
No
Solution #7
posted on Oct 24, 2007
Not Rated)
srponte
Rank: Apprentice
Rating: 0%, 0 votes
I am having the same problem, the smartphone is fine, because when you configure to connect to another exchange it works fine, but in one particular exchange only fully works if outlook is opened...
srponte@gmail.com
Comments:
Oct 25, 2007
- The SmartPhone is working fine, DirectPush is also working, I can tell this because when I configure it to access another Exchange Server, it works correctly.
In the other Server, Outlook must be opened to ActiveSync update the smartphone by air... very odd!!!
In my opinion should be something about Exchange or IIS, maybe a corrupted DLL.
I wanted to reinstall Exchange SP2, to all the DLL be overwritten, but the SP2 does not reinstall if it has been installed before.
Regards,
Sergio
Dec 07, 2007
- I have just found out that somehow the BlackBerry Server is interfering with exchange, the smartphone only works correctly to the users in the BBerry server.
srponte@gmail.com
Was this helpful?
Yes
No
Solution #8
Not Rated)
Brad
Rank: Apprentice
Rating: 0%, 0 votes
I haven't seen anything else added to this request after my mate added
some more information. Is there anybody out there able to head us into
the right direction for active sync to work correctly?
Was this helpful?
Yes
No
Solution #9
Not Rated)
Ranny
Rank: Apprentice
Rating: 0%, 0 votes
Right.
On the phone itself, when you go to ActiveSync, then Menu, Schedule, what
shows for Peak Times? Is it
Was this helpful?
Yes
No
Related Problems
I have an I-Mate JAMin I cannot download the driver to...
whenever i insert any sim this message displays "please...
Recently purchased a used imate JAMin. It is on charger now...
sir my i mat jamin locked i try to unlock but coming one...
no incoming ring tone.all possible activation...
Can you Help with these PDA problems?
not responding to 'pen' taps
Solve
My i-mate JAMin has decided to not respond to inputs via the 'pen'. I have tried a soft boot without... (More)
when irun my pc it takes long time
Solve
when irun my pc toshiba it takes long time confiugrig updates m0re than 15 min
mobile password is not matching
Solve
I can remember my mobile security password but it is not working. How can I operate my mobile now?... (More)
imate jam boot problem
Solve
hi i have a problem in my imate jam I have the same problem after flashing with a corrupt rom. Only... (More)
display in landscape but the touch...
Solve
While trying to re align the screen on my i-mate jamin, the display locked in landscape but the... (More)
Sponsored Links
Describe your PDA problem:
Top PDA Experts
Rank: Guru Guru
Solutions: 684
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more PDA Experts
Top Computers & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(601) 918-0222
I will connect to your Computer and repair the...
PDAs
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
