Dishwashers Logo
Posted on Oct 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have moved into a rental property with an asko d3350 dishwasher but no manual on how to operate. Where do I get hold of a manual I wonder? Thanks. z.
Anonymous
Level 2:
  • Expert 86 Answers
  • Posted on Oct 15, 2008
Anonymous
Expert
Level 2:
Answers
86
Questions
0
Helped
25400
Points
160
Go to this site an register 4 free, an you will get the manual, heres the link http://kitchen.manualsonline.com/manuals/mfg/asko/d3350.html?s=fpw just click (Get this manual)
2helpful
2answers
Asko d3350 has the f2 flasing and pump just runs
sounds like you have a water leak. The machine is fitted with a leak detection device that runs the drain pump constantly as a safety mechanism. If you want to look your self you will need to pull the machine out and tilt it back and if possible remove the bottom panel, should be 4 screws, this gives you access to the components. If it doesn't come off then you will need to remove either 1 or both of the side panel, its just a number of screws holding them. Then see if you can see where the leak is coming from, you may need to order a new part. Hope this helps.
1helpful
I have a problem with my Asko D3350 Dishwasher, can you help? On startup the diswasher does its normal cycle and pumps excess water out and then fills the dishwasher with water to the correct level of...
Hi Tony,
I have the same machine (D3350) and almost the same problem.
Mine starts each cycle fine - pumps out - fills - rinses - pumps out tht first load and then does not fill again. If I manually fill with a bottle (about 2 litres) for each subsequent cycle then it washes as well as it ever did.
Seeing it fills once it cannot be the water supply, nor the solenoid that operate the water supply. So, my guess is the control panel.
Like you I would love to simply take advantage of the PC Upgradeable featurewshich seemed so attractive at the time of pruchase.
Jason
We have an Asko D3350 Dishwasher and the upper blade does not appear to be spinning and the dishes are not coming clean. Bottom appears to be working fine and dishes on bottom are clean. What could be the...
On my d3350 it is possible to choose which tray (bottom, top or both) is cleaning.
The button is the bottom left, and above it there are two lights. As you push this button, the lghts cycle through lower tray, upper tray and the both trays. You want both lights on.
Also try this - take the spray arm out (it just snaps free) and rinse it out in case there are some blocking materials in the arm which are stopping it from spraying
1helpful
2answers
I have Asko D3350 dishwasher and the Detergent dispenser does not open. We were told to remove the whole dispenser and soak it in water but how do i remove it?
to remove the dispenser is not a 30 second job. You have to remove the door front with a T20 (torx) screwdriver (don't forget the 2 screws in the middle of the door at the bottom) Then you can get to the screws that hold the dispenser in place. Make sure you remove the solenoid from the dispenser BEFORE soaking in water. A more likely issue is either the solenoid on the dispenser has failed and will show signs of burning and/or damage or one of the transistors on the control board may have blown.
6helpful
Hi,\r\n
yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
1helpful
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Help for my asko diswasher
Unplug the washer for ten minutes, see if this clears the problem.
1helpful
Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
D3350 - Code F9
2helpful
2answers
Asko D3350
Steve, according to the codes listed on http://www.repairclinic.com/0078.asp apparently F7 is a bad door latch. It could be just not shutting fully or maybe one of the springs/rods needs looking at.
Is there anything recently that may have happened to the door? Slamming, jarring, etc.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
