Computer device manager shows floppy drive as working and i can deleted the drive driver and reboot the computer and it reinstalls it so i know that computer knows its there but its dissabled and in devise manager i enable it but i still cant use it, the floppy drive icon is not showen in the "my computer file" and when i start up in DOS mode i cant reinable the legacy diskette A: its not selectable but i see it so the computer knows its there, and i cant do f5 to restore default setup in dos i push f5 and the computer just beeps for each time i push f5. how do i reinable this drive if the computer knows its there and shows it to be working properly??....o and i know the drive it self works because i took it out and put it in diff computer to test it and it worked. plz help... my e-mail is eastwood_1985@hotmail.com and john_bowser1985@yahoo.com
I WANT TO DOWNLOAD E-BOOKS FREE FRO MY STUDENT
Posted on Nov 20, 2008
    Genius:
  • 1,124 Answers
Go to your bios and enable or disable your floppy drive.
This will fix your issue
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Posted on Oct 15, 2008
TDK fdd-100 external floppy drive won't mount
check the leads that attach this external floppy drive make sure they have a good secure connection
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
hope this helps you
Oct 31, 2011 | TDK External USB Floppy Drive FDD-100AX...
Starting BIOS recovery... Checking for floppy... Floppy not found checking for cd rom reading k8v-mx.rom not found How to solve this problem
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
May 05, 2011 | ASUS K8V-MX Motherboard
Computers tells me can't install -misssing driver
make sure all leads that are attached to your cd/dvd floppy drives have secure connections and are not faulty or just replace them they are probably old and faulty ?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. also
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Apr 10, 2011 | Targus Computers & Internet
When I started my computer it stated that my NTLDR was missing,how can I recover it ??
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
Check that there are no CDs or DVDs 3 1/2 inch floppy in the CD/DVD drives.your you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
test or replace leads that are attached to your
((motherboard to the hard drive))
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 09, 2011 | Computers & Internet
Computer wont reconize it
since you have not stated what your computer fails to recognize here is a guide
control panel administrive tools ,computer management ,device manager any yellow? ! question marks or red x will tell you that you need to reinstall the driver/s
to do this right click on the ? x ! select reinstall driver
if your computer came with a motherboard disk the drivers could be on it
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in or
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 28, 2010 | Computers & Internet
Its not working properly im trying to install this avid disk
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 22, 2010 | Samsung SC-148 CD-ROM Drive
How to fix code 39 error
To fix this issue. click on the below link.
http://www.fixya.com/support/r3579304-how_to_fix_cddvd_rom_error_code_39
Feb 16, 2010 | Computers & Internet
Phantom Floppy, Unknown Nonexistant, And Broken Optical Drives?
Delete all of the optical and floppy drives in Device manager by right clicking and either choosing delete or uninstall.. Once they are deleted, restart the computer. They should straighten themselves out after rebooting
Nov 16, 2008 | Computers & Internet
Miissing e drive
Try updating or reinstalling iTunes.
Jan 02, 2008 | Computers & Internet
Drive not working properly
Delete the drive from device manager. Reboot. If necessary check for driver updates and try disconnecting disbaling anything that could be conflicting with it.
Sep 07, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
