Question about EliteGroup KN1 SLI Extreme Motherboard
Erratic behavior - system halts with blue screen with error codes
The mother board shuts down the system with various error codes, one of the more common ones I see is 0x0000008e. The last one is 0x0000004e (0x0000008f,0x00031000,0x00008410,0x00000000) It sometimes does not boot properly, other times it will halt after a few minutes, other times after an hour of running. I suspect the mother board is bad. If booted with a linux system it gives crc errors. I have 1G PC3200 RAM (kingston kvr400 DDR). I am running an AMD 64 Athalon proccessor.
    Genius:
  • 1,066 Answers
Sounds like serious memory errors. download and boot to "memtest86" to terst your ram for errors, but it may also be the memory controller.
you can try also to swap slots between the memory sticks and see if it works better with the sticks swapped.
Posted on Mar 11, 2009
Sony vaio vgn fw340j windows vista system halt error 0x00000124 and 0x000009c
If you are asking what it is look here:http://www.pcauthorities.com/pc-errors/how-to-repair-blue-screen-errors/comment-page-11/
Nov 07, 2012 | Sony VAIO VGN-FW340J/B 16.4 Notebook PC
Tip
Laptop keeps shutting down with a Blue Screen
That seems for no reason, you computer shut download displaying a Blue Screen frequently. Learning "what is Blue Screen" and "why it happen" is essential. laptop keeps shutting down with a Blue Screen due to various kind of reasons. However, we can pay attention to the most common causes. With basic learning, you can troubleshoot computer crash problem yourself.
There is a misunderstanding that Blue Screen is a virus. In fact, BSOD is is known as a colloquialism used for the error screen displayed by some operating systems. The cause could be hardware and software relate. Computer experts provide us a result that shows the average causes of Blue Screen.
50% are the results of software incompatible or corrupt.
30% caused by virus. In this case, your laptop always gets freezing.
Other causes should be system bug and hardware failure.
It is difficult to repair the hardware. You have no choice but replace it. Here, we only talk about the system bug and software problem. The diversity of the cause makes us confused. However, fixing registry error is the easiest way to solve the problem. Registry is the database of Windows. It was designed to manager computer setting. Everything happened on your laptop is relate to the registry. Fox example, virus programs install on your computer and modify the registry key making your PC very slow.
Laptop keeps shutting down with a Blue Screen? It is recommended to use a registry cleaner. The program will diagnose errors accurately and clean up them in seconds.
on Sep 15, 2010 | Computers & Internet
Amd athlon 64 3800+ processor sound issues
Check mother board for failing capacitors. This is a common problem. There are replacements part kits to repair.
Computer operate erratic. Crashes. blue screen!
Hope This Helps?
Jun 26, 2017 | AMD Athlon 64 X2 3800+ Dual Core Processor...
System halted shows fatal Error failure to chaque password
fetal is a very serious error for mother boards
first change your ram
and check it that fetal error is solved if not then
replace your processor if not till.
so its mean you have fetal error in mother board. and try to replace it with another board
because if you want to repear it it will not work properly
Jul 18, 2011 | ASUS P5GC-MX/1333 - Motherboard - micro...
Hp d530 memory parity error system halted on shut down
Remove the panel and take the RAM outof the slot. Clean the slot and the RAM card connections . Check the CMOS batttery on the mother board. if the voltage islower than 2.5V replace .
Now start and set up the settings once again as the PC starts.
Use a good registry cleaner to check, a good antivirus to scan , delete all temp files, cookies and defragment.
Aug 28, 2010 | HP Compaq d530 SFF PC Desktop
After erratic behavior ,heat and air went out
BAD BLOWER CAN SHUT ALL DOWN. IF BLOWER WAS LOUD BEFORE SHUT DOWN THAN IT MAY BE TIME TO REPLACE. DOES BLOWER COME ON WHEN TSTAT IS SET TO FAN ON
Apr 20, 2010 | Heating & Cooling
Chassis intruded ? fatal error... system halted in asus p5sd2-vm mother board
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
Sep 29, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Blue screen appers and shut down by itself
your boot files are corrupted please repair your operating system backup your data and plan to reinstall a fresh version of operating system. endeavor to scan your system for virus affections.
Jun 16, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Erratic behavior with Acer Aspire 9300
How about just reinstalling the OS and seeing what happens. If you are running Vista it is most likely just a bad original install. You should have installation discs supplied and you should have been encouraged to make your own reinstall disc when you first run the machine. If you did not then check your handbook to find out how to do it. It will make a disc from the ghost partition on the hard drive. use this to reinstall and take drivers from one of the original discs supplied with machine
Dec 09, 2008 | Acer Aspire 9300 Notebook
EliteGroup KN1 SLI Extreme Motherboard Logo
107 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
