Washing machine Hi my Telmann TEL6TL washing machine broke and i found the problem to be an electrical device inside the machine which has EMI filter written on it? this is just a capacitor (i think) that has 5 wires going into it. i have finally tracked down a company that can sell me a new EMI filter but now am having trouble trying to re wire it?? any one got any idea?? as i said there are 5 wires that are ment to go into it, these are all different colours 1- brown, 2- half brown and half white, 3- half green and half yellow, 4- blue, and the last one is half blue and half white.. can any one help
  • cpri032 Oct 15, 2008
    yea there was a diagram of the circuit but didnt have labels for any wires.. and then even on the supression capacitor where the wires were attached all it has is L2, U1, U3, N4 and the last one had a little picture of a circle with was looked like a symbol for a battery or something...
    turns out blue/white went to L2, Blue went to U1, brown went to U3, brown/white went to N4 (i assumed this was neutral so this is odd), and the green/yellow wire went to the bit with the little symbol... weird i thought.
    even stranger is that before with the old capacitor in it when you turned on the washing machine at the wall the capacitor would spark and then short the circuit (ths kept happening so the i couldnt get the washing machine even to turn on)... when i was trying to find what wires went where i was using the old capacitor (ddnt want to risk braking the new one) and i assumed that when i got it right it would spark when i plugged it into the wall (as it did previously)... turns out when i got it right nothing happened so i hit the power button on the washer and it turned on and now works again WITH THE OLD CAPACITOR...
    very strange
  • evlongmire
    evlongmire Oct 18, 2012
    i have had the same problem with my Samsung washing machine. It used to throw the power safety switch when plugged in (didn't need to be on- just needed to be plugged in with power on).. So i had an electrician look at it and he said the EMI filter was shot and needed to be replaced. I couldn't find one and was about to 'bypass' it (i'm told that the filter does little anyway). ...but then i read your query and thought to try my old EMI once again. Guess what? Now it's working! i don't know what the problem was but i read somewhere that they can get moisture in them and basically s**t themselves... So the solution i recommend- pull out the emi filter (remember where the different wires went!!) then use a hair dryer to completely dry inside and out, both the washing machine and the EMI filter. Then seal up anywhere that water or condensation could get into the filter... Replace and then see if the problem is still there. Good luck and stay safe!!
  • 1,462 Answers
Green and yellow is earth so wire the earth wire to this. brown is live in and blue is neutral in. brown/white is live out and blue/white is neutral out. usually a suppressor capacitor has a diagram printed on it
Posted on Oct 15, 2008
I have Samsung front loader washing machine that stop working suddenly there is no power no nothing and I checked power supply and nothing wrong with power supply .
Your power supply normally connects to an EMI filter immediately upon coming into the washer. If you have a voltmeter and are comfortable with electricity, you should remove the top cover of the washer to access the connections. Unplug the washer and shut off the water while dismantling. Remove the 2 screws at the back of the top portion (lid) and push the lid towards the back to dislodge it.
At this point, you should be able to locate the incoming power cable and see where it connects to the EMI filter. Once you have identified the connections, plug it the washer and verify that there is voltage both before and after the EMI filter. If there is no voltage at the incoming side of the filter, then your cable is broken and should be replaced. If there is voltage on the incoming side of the filter and none on the outgoing side, your filter is open circuited and should be replaced. If there is voltage at all locations, look for wires that may have shaken off during operation. When poking around inside the washer, looking at wires, pull the plug first. If this does not help, take a picture of the schematic diagram that is affixed to the top of the soap dispenser/water inlet box and post it for our reference. I have attached a typical diagram from a older Samsung washer. section-yodzb2tavlblrpvbck4ieuwo-2-1.jpg
Jan 10, 2015 | Samsung WF337AA Front Load Washer
May 08, 2014 | Washing Machines
Telmann TEL6TL washing machine doesnt spinn properly, brake motor not activated
replace whole mechanism if cheeper than replacing unit and dont want to pay a pro
Jun 19, 2012 | Washing Machines
Hi..Telmann tel6tl displays fault code E3..have you any ideas.. Thanks.
This code (E3) means an error code. That the dishwasher electronic control has detected a condition it needs to check. When you see a code, follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping if noted then .
  • Reprogram the Washing Machine.
  • If the code still displays, turn off the power to the Washing Machines at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on for operation.
Thanks for using fixya.
Jul 31, 2011 | Washing Machines
Hi I am contacting you on behalf of a friend who is needing a manual for her second hand Telmann washing machine,as she is having some hiccups with it. Model number TEL6TL If you could please...
I'm so sorry but this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 12, 2011 | Washing Machines
Telmann washing machine TEL6TL
Telemann TEL6tl E2 Problem
E2 on screen means the lid is not closing properly and thus not activating the (hidden) switch that prevents the machine from spinning while the lid is up.
The lid switch in this model is not a direct contact switch between lid and switch , but it switches on and off due to a MAGNET embedded in the lid on the left hand side near the front. You will see a small indentation where the magnet SHOULD BE. My magnet had fallen off, so the lid could not activate the operation switch. I had lost the original magnet( about 1cm X 2cm) so glued another into place.
Machine is now fully operational again, and the job cost .78c.
If your magnet is still in place, the E2 fault could lay with the switch itself , which is fixed to the underside of the top casing of the machine near the front right hand side of the lid cavity. The switch measures 1cm X 3cm heavily black tape insulated. Access is gained by popping the 2 X2cm discs at front top of machine and releasing the 2 small philips screws here and a further 2 at the back top of machine. This operation of replacing the switch is best left to an electrician or washing machine specialist.
Hope that helps
Nov 01, 2008 | Dishwashers
Telmann washing machine 6kg has error 3 and it wont spin help
  • i have found with this washer usually E3 is that the magnet has come out of the top.. under the lid there is ment to be a little magnet black sits in the little gap to the right of the machine lid. without that it wont work properly. hope this helps
Aug 09, 2008 | Washing Machines
Telmann TEL12DWMS Motor hums but does not wash dishes
May 03, 2008 | Dishwashers
Washing Machines Logo
498 people viewed this question
Top Washing Machines Experts
