Question about GE GSS20IEP Side by Side Refrigerator
Water/ice dispenser My water/ice dispenser does not dispense water or ice.The problem started with the ice but now has progressed to the water.The freezer still makes ice. The water has just stopped working altogther, it used to be only when one tried to get ice that the water would not work but now it doesn't work at all.Also the light kind of like flickers as well We have had problems with our water/ice dispenser since we have had the refrigerator. The ice would freeze up and the dispenser doesn't work but just recently the water does not work at all either. I just need to know what to do to fix the water because we use the water all the time. Thanks.
  • 2 more comments
  • Anonymous Oct 30, 2008
    My ice is coming out but the water is not coming out of the dispenser. Please advise. Thx.
  • wenibek Jan 07, 2009
    We have pretty much the same problem. Started that the water and ice dispensers would not work all the time. Eventually they quit working completely, however the ice maker still makes ice. The light flickers too.
    However, we have also experienced the whole fridge and freezer not working twice now. We were able to get the fridge and freezer to work again.
    There is also a clicking sound coming from the back of the fridge - the mother board - for about 5 to 10 minutes and then quits and fridge starts working again.
  • emgru Nov 25, 2009
    I want to remove the water dispenser and filter on my ge profile top freezer refrig as it takes up too much room in the fridge and we don't use it anyway. Can I just remove the screws holding the filter and plastic housing box or will I cause a flood and or damage the ice making function that I still want to use??????
  • idababy12 May 11, 2010
    i fix the problem thanks to your help the wiring harness was unpluged
  • 120 Answers
Hi george i will try to help firts i want you to try this. pull off the bottom grill or kick plate and make sure that the wire harness is connected and not loose they get loose a lot on this brand. now if they are look at the water line conector but the bottom hinge disconect it for there and close the door and ask for wtr at the lever if you get water the you have frozen line inside door if no water then check the resevour inside the refrigerator and make sure is not frozen if it is ok then if you model hasa mother board at the back repl when both ice and wtr go out that is usually the problem i see it every day ok take the model number with when you buy the part sothey can give the right board ok.
Posted on Oct 15, 2008
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
I hope this helps.
Aug 27, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Dispenser
Sounds like a control fault on the microswitch to activate the ice and water line. Access to this is immediately behind the ice dispenser section (just above) on the freezer door. Normal access is two screws located behind the removal drip tray section. Either that or the control board for the ice dispenser as you are not getting water as well. Before taking this section apart though you should hear a buzzing sound when you activate the chilled water, if you do then you may have a water supply problem. Hope this helps.
Mar 13, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Water/ice dispenser
if you take the kick plate off below the doors, youll see a small wire harness on the left hand side. youll see a plastic conection where the wires come together. one or more wires are broken. its a pretty common problem with ge. if you cut the conector off and use butt conectors to reconnect the wire matching the colors you wont have the problem anu more
Nov 25, 2007 | GE CleanSteel GSL25JFTBS
GE GSS20IEP Side by Side Refrigerator Logo
314 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
