Question about Evga GeForce FX 5500 DDR, Graphic Card
It worked in the past, but now it doesn't work at all...
Here is how it started.. My computer was full of dust, and I decided to clean it out. So, I took the shell off my hp pavilion a635w and cleaned it out with that electronic cleaner stuff...as soon as I plugged the monitor connection to the graphics card, it only said entering power saving mode.. BUT>> when I plugged it into the regular plug, it worked but it was in VERY low detail... When I used it before, it worked fine... I tried to fix it, and no one seems to have a solution to it... I have no idea what's going on... It can't be virus', and I tried to reinstall it... but it wouldn't work.. Any one have any solutions!!!???
  • joemalola Oct 15, 2008
    I think my graphic card is glitched, and it just wont work anymore. Really, what started all of this was the fact that this graphics card (a e-GeForce FX 5500 256 MB) was too low for what i had on my computer... If there are anymore solutions, please feel free to type it. I don't think it has anything to do with the connection because i tried that.... :(
  • joemalola Oct 17, 2008
    My graphics card gathered too much dust at the fan and overheated.. Eventually it corroded... Thanks, anyway =)
  • 128 Answers
Pls make sure that your graphics card is well inserted to the slot. check other parts also like ram for loose connections. you can also clean them by removing them and cleaning the metal pins with a pencil eraser, just be sure to take note of the gap when you insert them back to the slot.
Posted on Oct 15, 2008
  • cpenny29 Oct 16, 2008
    replace your video card
Hi my hp compaq d530 cmt doesn't work when i brache the cable of alimentation it signe with red !! help me please .
how did you clean by hand ?
did you move any wiring data or power leads
Test all leads power and data that attach from motherboard to your hard drive,IDE,SATA
make sure all of you your drives power and data leads have secure connections
make sure the CPU central processing unit has a dust free secure seating
make sure your computer ram modules have secure seatings with no dust in sockets
Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
Jul 07, 2012 | HP Compaq d530 CMT PC Desktop
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
My computer shuts down while browsing the internet. Both fans I see are working. What could it be?
Just because the fans are working does not mean they are blowing cool air properly. First undo the case power down and ground yourself by touching the case before you enter with your hands inside. Look and see if the block and fan are full of dust. Computers tend to shut down especially the newer ones to keep your CPU and board protected from over heating.
This may be all it is clean out the debris and place some new heat sync paste purchase at Radio Shack or Amazon.com or a local computer shop they should have some in a tube. Place the heat sync on top of the CPU I place about a dime size in the middle of the CPU top and then place the cooling block back down and tighten or fasten it back down again. Clean it good then try this to see if this works.
John
Apr 12, 2012 | Computers & Internet
Dell 5650 speaker issues
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Dec 22, 2011 | Dell 5650 Computer Speakers
My fan keeps speeding up , then it slow downs what causes this? an how can I fix this?
which fan is doing this? Mostly likely it is caused by dust or overheating. Use a can of compressed air found at any electronics store to clean the dust out from inside the computer. If that doesn't solve the problem I would next try replacing the fan.
thank you,
Lee
Sep 21, 2011 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
Rear right speaker doesn't work, no matter what we tried. We switched the speaker and cables with one of the others, but just that position (surround right) doesn't work.
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Sep 09, 2011 | Spherex Xbox 5.1 Surround Sound System...
2002 Pontiac Grand Prix - I put the key in and turn to start, I hear a click, then it doesn't start - in fact the entire car suddenly goes dead and the key gets stuck in the ignition. I can press the...
The first thing I would do is clean your battery connections very good. you may have to remove the plastic covers off the cable ends to get them cleaned good. Also make sure you get the connection bolts tight.
Sep 04, 2011 | 2002 Pontiac Grand Prix
How do i clean the filter on my vp6325 projector?
If you have a jet air - compressor or blower- use it to clear the filter of the trapped dust within the filter. Once the filter is clean the flow of air to the lamp unit will be improved and so give you longer life on the lamp. A tiny bristle type brush can be used-- the brush of your electric shaver.
Jan 18, 2011 | HP vp6325 DLP Projector
My acer 5420 keeps overheating and shutting down
Clean the insides of your Desktop case.
1. make sure all the fans(CASE FANS, POWER SUPPLY FANS AND CPU FANS) are working dust and lint free.
2.remove dust and dirt build up in CPU heat sinks.
3. remove dust and dirt build up in the motherboard, RAM and
expansion slots.
4. remove dust and dirt build up on CD-ROM's, Hard Disk Drives and expansion bays.
5.apply new thermal paste on your CPU.
Jan 20, 2009 | Computers & Internet
Power cutting out from tower. EMACHINES 550
There maybe to much dust build up on your cpu cooler that causes it to shut down to protect itself it needs clean about every 2 months or less to make it run smoothly.That is one solution the other solution is that your power supply needs to be clean also or replaced.Buy a can of air from your local computer store or walmart etc......
Jul 28, 2008 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
Evga GeForce FX 5500 DDR, Graphic Card Logo
Top Evga Computers & Internet Experts
Tony
David
David
Mike
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
