Back to:
Tags:
ASUS a716 Case
ASUS A716 KernelIoControl not working for some...
By Lizzy - usenet poster
I want to get some unique number for the PPC. For all HP and Acer PPC
running PPC2003 or above, I have no problem in getting the SD card
serial number by
KernelIoControl(IOCTL_DISK_GET_STORAGEID,)
However, it does not work for Asus A716 (which is a PPC2003), it
return FALSE when executing
What is even worst is I also get a FALSE (i.e. failure) when executing
the folloing IOCTL
KernelIoControl(IOCTL_HAL_GET_UUID,)
KernelIoControl(IOCTL_HAL_GET_DEVICEID,)
Are there any people having similar problems and how to solve this
problem? Many many many thanks in advance.
Best regards,
John. (j@sky-power.com.hk)
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 27, 2006
Not Rated (0)
paulrmc
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
IOCTL_DISK_GET_STORAGEID is a DISK device control code and should be used
DeviceIoControl() and not KernelIoControl()
IOCTL_HAL_GET_UUID and IOCTL_HAL_GET_DEVICEID are optional and may not be
implemented on any specific device.
Steve Maillet
EmbeddedFusion
smaillet at EmbeddedFusion dot com
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ASUS A716 KernelIoControl not working for some IOCTL:
I don't want to Accept this solution
Can you Help with these PDAs problems?
PDAs
i have an insinia bluetooth headset that will not...
PDAs
my sat nav screen froze
PDAs
need directions on how to use my mp3 video player
PDAs
voice downloaded on device cannot replace original
PDAs
MY Cobra Radio's Pull Down Lock Latch for the back...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
